Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Like Tree3Likes
Thread: Need Guidence in alteration of 70cc bike
    chlorine1's Avatar
    May 2016
    Exclamation Need Guidence in alteration of 70cc bike
    i have heard alot about alteration in 70cc chineese bike so i want to try it out please experts tell me if a put 107cc cylinder instead of 78cc what should i do ...can i put cylinder without altering the engine ?please help
    Thank you!
    scarfase's Avatar
    Dec 2013
    139
    6 Post(s)
    no use , bike will become body massager, lot of vibration, and no beaks, hence broken bones. aisay khorafati khayalat se bacho BACHAY
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    Quote Originally Posted by chlorine1 View Post
    Thank you!
    Don't change the cylinder just bore and install big diameter piston + valve
    Brother had said right it's wise to stay from such things.
    The first step towards knowledge is to know that WE are IGNORANT
    chlorine1's Avatar
    May 2016
    Lightbulb
    Quote Originally Posted by Hassan1991 View Post
    which piston is suitable for a good ride
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    check this thread....
    https://www.pakwheels.com/forums/oth...uest-top-speed
    chlorine1's Avatar
    May 2016
    Red face
    Thanks ! Very informative
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    No problem
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    For 107 cc cylinder you need to either change rod and weight and it's bearings.. Or you need to shave piston top a bit too it doesn't touches head.
    Sent from my Nexus 5 using Tapatalk
    chlorine1's Avatar
    May 2016
    Quote Originally Posted by asjdsm View Post
    should i bore cylinder for hd110?
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Hd 110 piston dia is 52.4mm.. Your 70 dia is 47mm and oversize piston available for 70 is hardly 48-49mm.
    You can't bike stock cylinder.
    Buy 107cc cylinder available in new for 1000-1100rs and hd110 piston. And shave the corners of piston and create small pockets for valves to avoid them hitting the piston and bending when its hot as the conrod for 107cc bikes is a bit shorter then Chonda conrod.
    107cc cylinder is bolt on fit to 78cc chondaz.
    All 4 holes for mounting studs and oil hole and oil return path.
    sajjadali3089's Avatar
    Jun 2016
    Hyderabad
    21
    11
    Dont change 78 into 100 or 110 u can change japani clutch and pressure plet then aftr then piston must be concentrated as required bore ... if u use 100cc then u must use the front spockt and drive spockt it is depend upon on egine primary gear
  12. #12
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    can someone plz tell me, what alterations are required to put 100cc piston in 72cm3 block without cutting piston from the top.
    Like
    1- honda 100 piston
    2- bolt on fit block size ?
    3- rod if required ?
    4- head if required, but should look same from outside in size (undercover) ?
    And if i ask mechanic to put an extra clutch plate in it, can he do that.
    ------------------------------------ALTERATION/MODIFICATION SEPARATE HUMAN FROM BEAST-----------------------------------------
  13. #13
    asjdsm's Avatar
    Apr 2009
    30
    3,474
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by user-xxx View Post
    Like
    1- honda 100 piston
    72cm walay ma ap 110 ka block laga lain. Road price ka atha ha.
    Use road price rod and weights. As they won't require you cutting piston top. Also stock 72cm stroke is 41.5mm and 110 it is 48.5mm (not 100% sure but it is slightly less then that of 78cc which uses 49.5mm).
    Alao use pz22 carburettor. Genuine is preferred.
    Use road prince 110 head.
    Use qingqi 100 silencer for better exhaust expulsion.
  14. #14
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    Like
    1- honda 100 piston
    i installed quigqi 4 stroke piston in mien 70 just bore the piston no other modification is required one thing i installed two seals in the back of the cylinder after then it piston doesn't touches the head
    here's the thread
    https://www.pakwheels.com/forums/oth...t-top-speed-10
  15. #15
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    Thanks for helping bro, but i want to keep it undercover. 110cc kuch bara ho jaye ga.
    is se kuch kam alteration se bhi kam chal jaye ga, mean simple alterations
    Like 100 piston with 78 block or something !
    hmmm also bro the setup that you suggested me ( Road Prince 110CC Block, Piston Head, Road & weight)
    & timing sprocket & chain bhe new use ho gi ?
    Is it bolt on fit, if i bring it ?
    What should be the cost of this setup on RWP murree road ?
  16. #16
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    yr agr yeh simple alteration kron to ho jaye gi.
    1- new 78cm3 head (bored to fit honda 100 piston)
    2- honda 100 piston
    3- carbs to han pz22 and 125
    Is main rod to change nhe krna pry ga?
  17. #17
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    2- honda 100 piston
    Cylinder keu change kr rha ho siraf bigger piston bore kr lo,oversize valve laga lo or pz22 carb bss it will be undercover.
  18. #18
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    ok asa hi krta hun.
  19. #19
    Hassan1991's Avatar
    Mar 2013
    20
    2,279
    38 Post(s)
    ok asa hi krta hun.
    Keep us updated
  20. #20
    f4fraz's Avatar
    Dec 2013
    34
    668
    17 Post(s)
    hello every body
    i read in this topic many similar comments which means normal alter. and i like
    so any body tell us how much these type of alter cost?
    big piston+rings
    oversize valve
    clutch plates
    may be other small things will also included like timing chain seals etc etc
