Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 88
Like Tree24Likes
Thread: Guidance needed for fitting engine to bicycle
    mtokeyboard's Avatar
    Mar 2012
    137
    Default Guidance needed for fitting engine to bicycle
    Dear brothers , your help and guidance is needed in fitting the engine to cycle.
    It is a 45cc chinese engine, avaialable from neela gunbad lahore in rs 6000. It has a clutch and a race as controls.
    Made for cycles, there are too clamps for fitting onto rods nears pedals of cycle.
    Now the problem is that i dont have much space in my little cycle onto which i wish to fit it.
    1.please guide me bt how to fit it on the carrier (or by removing the carrier)
    2. If i fit engine by rotating it , such that its plug faces towards uppet side instead of facing to the front , will ot cause provlem in engine working ??
    3. If i wield additions rods after removing carrier will they tolerate weight of 10 kg of engine ?
    Thanks bhaiyoGuidance Needed fitting cycleengine to cycle  -1683022Guidance Needed fitting cycleengine to cycle  -1683023Guidance Needed fitting cycleengine to cycle  -1683024Guidance Needed fitting cycleengine to cycle  -1683025Guidance Needed fitting cycleengine to cycle  -1683026Guidance Needed fitting cycleengine to cycle  -1683030
  2. #21
    Mar 2012
    137
    Quote Originally Posted by Hassan1991 View Post
    Right....and I'm confused about mounts,does they came with engine or you had to made them?
    No.
    Mounts khud tyar kernay hongay !
    Ab ek or option bhi hai keh dusri cycle per try kiya jaye jis per engine wothout mouting modification fix ho jaye !!
    Sent from my QMobile Z10 using PW Forums mobile app
  3. #22
    Mar 2012
    137
    Quote Originally Posted by saboor73 View Post
    What about fuel tank ?
    Fuel tank engine say thora oper attache hoga...!! Final drawings share kru ga
  4. #23
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Bhai bottle kasi raha gii
    The first step towards knowledge is to know that WE are IGNORANT
  5. #24
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Quote Originally Posted by mtokeyboard View Post
    No.
    Dosari cycle konsi koe reference pic?
    Mounts are the most difficult parts.
  6. #25
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    I got an idea about mounts....
    The first step towards knowledge is to know that we are "IGNORANT"
  7. #26
    Mar 2012
    137
    Dusri cycle jo usual sohrab ki cycle hoti hai (baba cycle)
  8. #27
    Mar 2012
    137
    What is the idea !!??
  9. #28
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    This cycle will look better than "baba cycle "
    Here's the diagram....you can use 86 corolla front control arm bushes as when they came into my mind then I get the idea
    And in the place of u-bolt you can weld 2 bolts
    Sorry for my awesome diagram + writing
    Guidance needed for fitting engine to bicycle - 58a73390c4f579e660e27b3b150f0e14
  10. #29
    Mar 2012
    137
    aa gai smjh !!!!!
    it say 2 faiday hongay meray khyal mei,
    1. U bolt ki wjah aay engine ko agay pechay set kerna asan hai.
    2. Bush say engine ki shock absorption bhi hogi ???
  11. #30
    Mar 2012
    137
    Yeh good idea hai kyu keh U bolt ka to socha hi nahi mai nay.
    Thanks !!!
  12. #31
    Mar 2012
    137
    Ab monday ko final pics upload kru ga
  13. #32
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    aa gai smjh !!!!!
    1.Han gii bolts ki vaja sa ager rubber bush kharab ho jata hai to usa replace kr sakta haien
    2.Han gii rubber bush engine ki vibration ko absorb kr la ga just like mounts keu ka ager ham mounts nae banata to engine ki vibration ki vaja sa welding break ho jae ge
    Shukr bhai apko samaj aa gae varna mari writing kuch zeyada hi peyari hai
  14. #33
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Your welcome and Take your time build it nice and slow
  15. #34
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Amazing project on the way...
    Subscribed!!!
    I Am the Feel
    I Am The Yamaha!
  16. #35
    omar4494's Avatar
    Aug 2005
    1,255
    15 Post(s)
    very good project. will give you a lot of learning. My question is very basic. Do you think that the frame of cycle is strong enough to bear 50km/h abuse?
  17. #36
    biloo's Avatar
    Sep 2004
    33
    1,289
    16 Post(s)
    Quote Originally Posted by omar4494 View Post
    I had a speedo meter in my mountain bike when i was a kid . My top speed ever was 60km/h , as far as i can remb it wasnt a big deal for the frame plus i have seen Sohrabs clinging on to bikes and suzukis at 60km/h doing perfctly fine.
    Sent from my SM-N910G using Tapatalk
  18. #37
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    ^^^Test that bicycle with GPS device which shows 60km\h unless it's not a sports one.
    My Phoenix (having gear set installed) had not ever crossed even 40km\h on GPS.
    The cheapo speedos are faulty. @Sohrab, It's called 'Baba caycle', which is quite true. It's way stronger than such bling bling bicycles.
    I Am the Feel
    I Am The Yamaha!
  19. #38
    Hassan1991's Avatar
    Mar 2013
    20
    2,271
    37 Post(s)
    Quote Originally Posted by N0m1 View Post
    The cheapo speedos are faulty. @Sohrab,It's called 'Baba caycle', which is quite true. It's way stronger than such bling bling bicycles.
    "Baba cycle Zindabad"
  20. #39
    Mar 2012
    137
    Well the project couldnt be completed on the bicycle with front and rear shocks, because with rear shocks and engine mounts ,the shocks were under too much stress.
    So i have fitted it on phoenix bicycle. I am posting pics here :
    Guidance needed for fitting engine to bicycle - 8983c01dbe0fc0bc8a15bfda11dfaea9
    Guidance needed for fitting engine to bicycle - 55c9bf7fb5ffd0d7f342e42fe7f37477
    Guidance needed for fitting engine to bicycle - f3c437e0bd67f440971523b77c561e2c
    I have yet to fit the petrol tank properly oj the rear :-)
    Sent from my QMobile Z10 using Tapatalk
  21. #40
    Mar 2012
    137
    I thank u for helping out , really with the talk u open up mind
