Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Like Tree13Likes
Thread: How to change engine oil in honda Cg 125?
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    Default How to change engine oil in honda Cg 125?
    This might be a silly question but recently bought a honda 125 & its time to change the engine oil for the 1st time, which is not a big task & want to do it myself but unlike yamaha Royal this bike don't have a bolt underneath the engine. The only bolt (big one i think it might be 24) i can see is near the gear lever. Anyone can you please show me the exact bolt to remove the oil?
    Thanks in advance.
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,402
    8 Post(s)
    Quote Originally Posted by ftb7007 View Post
    Thanks in advance.
    Open that bolt it is the drain bolt
    Sent from my ALE-L21 using PW Forums mobile app
    A real driver knows exactly what's in his car.
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,402
    8 Post(s)
    Clean the filter and make sure to take out oil as much as you can by leaning it, tighten the bolt and put in fresh new oil also clean the air filter
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    @raja2013 thanks brother
    akash190's Avatar
    Feb 2011
    Kharian
    22
    1,402
    8 Post(s)
    Welcome, clean air filter with petrol and later lube it with engine oil just 3-4 drops or less
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Ahl doesn't give oil drain nut/bolt underneath engine in newer model you have to open centrifugal oil filter cap to drain oil (it is located on left side of engine near gear shift stick) you will have to use compressed air to drain all oil otherwise small amount of oil won't make its way out do warm up bike before draining oil
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Guys filter ka b koi me b koi oil hota ha ?
    Sent from my SM-A500H using PW Forums mobile app
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Quote Originally Posted by umarjutt View Post
    Can't get your point.!
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Quote Originally Posted by hassantahir2 View Post
    Me ny kal cg125 lia ha ... engine oil k ilawa b koi oil hota ha ic me change krny k lea ?
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Nope koi oil nahi hota. Sirf engine oil hi hota ha. Ussay time pe change karein.
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Ok bro.. any suggestions for new bike ....
  12. #12
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    First 500 km aram se chalaien rpm ko 5-5.5 k ander rakhein. 1st oil 200 km pe 2nd 500 km pe aur 3rd 1000 km pe change karein.
  13. #13
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Atlas honda wala oil use krun ? And wo wheels ki wire kuch log keh rahy thy tite krani parti hn kuch time bad . Wo b zrori ha ? Or hi octane patrol kb use krna chye
  14. #14
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Hi-octane use karnay ki koi zarorat nahi CG normal petrol pe zyada acha chalta ha.
    Oil ma to yehi suggest karu ga k atleast running me AHL ka oil use karein baad me koi b acha oil use kar lein.
    Rim ki wires/spokes 1000 km per check karwa lijiye ga abhi koi zarorat nahi.
  15. #15
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Ap k pas cg 125 ha ?
  16. #16
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Ji (2011)
  17. #17
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Ji.
    This is my bike .ap bije ki tuning wegra me kya kya krty hn ... or muge kya kya krna chye ... just oil and filter ?
  18. #18
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Tunning me mechanic ko carbeurator kholnay nahi dena... Baki tappet adjust karein g a y aur filter saaf, nut bolts tight, aur air fuel mixture set. Tunning Honda walon se hi karwaiye ga.
    Aur aap Faisalabad se hain to ma aap ko Farid honda centre recommend karu ga wo tunning k liye achay hain.
  19. #19
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    Faislabad walo se lia ha janah colony se .. uni se he kraon ga ? Can i see your bike pic ha ap k pas ?
  20. #20
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Bike abhi meray sath nahi ha... Aur pictures b koi nahi hain.
