Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By Hassan1991
  • 1 Post By archon2001
Thread: Break in period!!
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    Default Break in period!!
    I know this topic has already been discussed thousands times but one question is stucked in my mind & never got a clear answer to it.
    My question is, Most of the new bike owners are told that DO NOT ride double (2 persons) while bike is in running period as it will put additional weight on the bike new engine and i am certainly unable to understand this logic as every person weight is different so my how come double sawari is going to harm or destroy the engine?
    Thanks in advance 😊
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    Quote Originally Posted by ftb7007 View Post
    Thanks in advance 😊
    Your mixing it actually they want to say that don't take too much work from your ride while it's running is not complete.
    As it's in running period the piston,valves,bearings etc etc are not in optimum working condition they are hard, rough not smooth the way they should be and taking load which increase friction.....and because of that friction engines temperature increases which further results in seiz
    The first step towards knowledge is to know that WE are IGNORANT
    shoaib992's Avatar
    Apr 2013
    24
    71
    2 Post(s)
    In running period what is the logic of changing oil at 300km and then 500km kindly explain?
    Success Is A Mindset.
    ftb7007's Avatar
    Apr 2016
    Peshawar
    45
    3 Post(s)
    @Hassan1991 So what actually is the maximum weight to put on honda Cg 125 during break-in?
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    if you weight about 70 to 80kg then it's better to drive it alone but again brother you can even drive with two persons sitting at the back but for shorter distance and slowly.
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    Quote Originally Posted by shoaib992 View Post
    As i said it's friction
    engine will take no time to heat up due to friction, as in running the strength of that friction is stronger so it's better to change engine oil earlier
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    There is certainly no issue in pillion riding in new bike's, its just a local Pakistani mechanic self created illogical funda.
    Non of the manuals of any manufacturers of motorcycle mention such thing's.
    Enjoy yr new ride with yr friend or family without being afraid of its break down. First 1k km is the best time to test yr bike shocks,electric etc.
    Just don't rev very hard , do not ride on constant speed and don't touch red line while in first 1k km running period.
    Sent from my ALE-L21 using PW Forums mobile app
    Help others so that u can be Helped
    shoaib992's Avatar
    Apr 2013
    24
    71
    2 Post(s)
    Thanks hassan
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    Quote Originally Posted by archon2001 View Post
    How say's new bike need running they have been tested before give to customers actually running is needed after engine rebuild
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    Thanks hassan
    Your welcome
    archon2001's Avatar
    May 2007
    Select City
    44
    2,223
    6
    72 Post(s)
    3 Thread(s)
    Quote Originally Posted by Hassan1991 View Post
    Let me say in easy Pakistani English initial 1K km break in period is called running period in our society.
  12. #12
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    yes it is and there are alot misunderstanding regarding running in people minds
  13. #13
    engr.omersharif's Avatar
    Feb 2015
    31
    259
    2 Post(s)
    I have seen pistons being cast by poor labours on crude machines in pakistan. Every made in pak motorcycle needs a break in period. At every step of manufacturing a random sample is drawn and inspected for defects. It is not possible to inspect 100% products due to resource constraints and production size. Care is taken but you cannot take out human error.
    Sent from my SM-J700H using PW Forums mobile app
