Results 1 to 12 of 12
Thread: Problem with roadprince 70 charging
    abubakker.akram's Avatar
    Sep 2016
    17
    Default Problem with roadprince 70 charging
    My bike roadprince 70 battery is not charging.i have checked the battery charging voltage.its 4.5 when race is at initial and goes maximum at 7.9 which is alot less to charge a 12v bike battery.any recomendations ?
    Hassan1991's Avatar
    Mar 2013
    20
    2,283
    38 Post(s)
    Check the capacitor (I always forget what that component is called).....also check the coil.
    The first step towards knowledge is to know that WE are IGNORANT
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Check if battery is ok. I suspect some cells with battery are dud
    And hm that means new battery
    Sent from my Nexus 5 using Tapatalk
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Quote Originally Posted by abubakker.akram View Post
    Check if the battery charger is giving current to battery. In my case when i brought ravi 70 i have same problems but it went away on around 1200kms.
    Sep 2016
    17
    The current is 7.9v maximum.so its alot less to charge a 12v battery .what should i replace ? Dont know the parts
    Sep 2016
    17
    The battery is ok.and working the vlotage coming is very less
    Sep 2016
    17
    Where is the capacitor located .what is the black component rectangular in shape?
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by Hassan1991 View Post
    Hassan Its called Rectifier component which charges battery
    Hassan1991's Avatar
    Mar 2013
    20
    2,283
    38 Post(s)
    Yes rectifier....thanks
    I always forget the names of electric components.
    Sep 2016
    17
    How do rectifier look like can u explain please ?
    Sent from my SM-G925F using PW Forums mobile app
    Hassan1991's Avatar
    Mar 2013
    20
    2,283
    38 Post(s)
    It's duplicate thread try stick with one thread
  12. #12
    Sep 2016
    17
    Sorry i am newbie and this forum is a little hard for beginners. Just on other thread now
