Results 1 to 20 of 20
Thread: Problem with roadprince 70 charging
    abubakker.akram's Avatar
    Sep 2016
    17
    Default Problem with roadprince 70 charging
    My cd 70 battery is not charging the voltage coming in to charge battery is a lot less.any solution ?
    Hassan1991's Avatar
    Mar 2013
    20
    2,282
    38 Post(s)
    Voltage is coming or nor?
    The first step towards knowledge is to know that WE are IGNORANT
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    change the rectifier and see
    Rectifier is the battery charger in motorcycle
    Sep 2016
    17
    Quote Originally Posted by Hassan1991 View Post
    Yes voltage coming is juat 7.9v max. Less voltage.
    Sent from my SM-G925F using PW Forums mobile app
    Sep 2016
    17
    Quote Originally Posted by amjad635 View Post
    How do rectifier look like ? The one with a heat sink or black rectangular ?
    Hassan1991's Avatar
    Mar 2013
    20
    2,282
    38 Post(s)
    Quote Originally Posted by abubakker.akram View Post
    One with Heat sink.
    Sep 2016
    17
    The engine runs on a.c power and this converts a.c into d.c to charge battery and power front light and back light etc ? How come all the lights are running ok and only power to battery is less ?
    Sep 2016
    17
    One with Heat sink.
    Hassan1991's Avatar
    Mar 2013
    20
    2,282
    38 Post(s)
    First tell me how you had checked the voltage??
    You should unplug battery before checking the voltage next thing is a bulb does take all 12 volt I mean to say it's 12 volt bulb but voltage are divided between headlight,backlight and battery so bulb will work fine
    Sep 2016
    17
    I have checked by multemeter after removing battery and starting the bike.
    hamikhan's Avatar
    Jun 2014
    Other
    1,261
    39 Post(s)
    Bro accelerate bike then check voltage
  12. #12
    Hassan1991's Avatar
    Mar 2013
    20
    2,282
    38 Post(s)
    I think so it's rectifier fault....but first try to install anyother bike's rectifier just to be sure.
  13. #13
    Sep 2016
    17
    Quote Originally Posted by hamikhan View Post
    I have checked .initially the voltage was 4.5 then at top accceleration voltage was 7.9
  14. #14
    Sep 2016
    17
    Ok bro .thanx alot i will let u know what happened
  15. #15
    Sep 2016
    17
    Bro is there a voltage regulator or capacitor type thing in bike.i have seen faulty capacitor outputs a reduced voltage. What is the black rectangular a inch and a half long solid thing ? Whats its purpose.just curious
  16. #16
    Hassan1991's Avatar
    Mar 2013
    20
    2,282
    38 Post(s)
    That's cdi(capacitor discharge ignition).....It regulates the ignition current produced by the magnet coil and forwarded it to the big coil which boosted the current.
  17. #17
    Sep 2016
    17
    Found the problem.battery was faulty .the reason the voltage shown on multimeter is that there is no capacitor to normalize voltage and the multimeter just read the basic reading .if capacitor is added the voltage would be shown proper on multimeter.thanx all of u for help
  18. #18
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    check wiring, if okay, test another rectifer, else replace stator. all cheap
    haters gonna hate, potatoes gonna potate
  19. #19
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    I think replacing rectifier will easily solve the problem. rectifier is not much expensive to buy as spare.
  20. #20
    Sep 2016
    17
    Quote Originally Posted by alizain5 View Post
    Bro was a battery problem.
