Results 1 to 6 of 6
Thread: Brake Caliper Jams Disc At a Specific Point.
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    Default Brake Caliper Jams Disc At a Specific Point.
    My bike has a front disc setup, facing issue of wheel jamming.
    In details, the brake caliper is jamming disc at a specific point only, like the wheel is rotating freely and stuck at one point. I have tried another disc and this second disc is also jamming at the same point, strange? I mean I noticed it by observing tube-nosel position.
    For both disc when tube-nosel reach this point (see image below), wheel is jamming. Wheel jamming gets even worst in longer run may be pads get heated. Before replacing the disc, we did the bleeding to remove any air. In all the process, the brakes is working fine like it stops the bike, grips is ok but that wheel jamming at one point I am not able to figure out, may be drum is out at one point.
    Brake Caliper Jams Disc At a Specific Point -1715101
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
    scott2353's Avatar
    Mar 2016
    43
    same thing happens with me......!!!!!!!!
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    What are the radial runout readings for the rotor, wheel and the axle? One of them might be over limits. Or bad bearings.
    Oct 2009
    33
    771
    31 Post(s)
    Not sure about the exact specifications. But it is GTO 125 original fittings.
    Quote Originally Posted by VCheng View Post
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    rim sidha krwaen aur check karen disc plate sahi ha k nahi , usko b tool lgwaen if needs work , its confirmed rim disbalance issue
    legend will revive soon
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Two possibilities for this.
    1 - disc is warped
    2 - disc mount hub is warped or there is debris or foreign material trapped between disc and hub
    3 - caliper slide pins are worn and sloppy
