Results 1 to 10 of 10
Thread: 1985 Yamaha Swap (2 stroke to 4 stroke)
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    Default 1985 Yamaha Swap (2 stroke to 4 stroke)
    AOA,
    I have my eyes on an old yamaha that a relative is planning to get rid of. It is a 1985 2 stroke.
    edit : Its a 100cc deluxe
    Is there any 100cc or above engine that will fit the yamaha frame?
    rxlover's Avatar
    Apr 2016
    43
    Solution
    If its the yb 100 then you can fit the yd 100 engine which is a 4 stroke
    It has the same fitting as the engine is built around the same chasis
    Sent from my DROID RAZR M using PW Forums mobile app
    rxlover's Avatar
    Apr 2016
    43
    Btw if you do swap the engine plz contact me for the 2 stroke engine of that bike
    I need spares for my yb 100
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    its a 100cc deluxe
    haters gonna hate, potatoes gonna potate
    rxlover's Avatar
    Apr 2016
    43
    Yep its a yb 100.. It can easily take the 4 stroke yamaha yd 100 or yamaha junoon engine as all have same chassis
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    Quote Originally Posted by rxlover View Post
    you think ybr engine can also fit? 5 gears and starter motor are nice things to have
    @Xulfiqar
    Hassan1991's Avatar
    Mar 2013
    20
    2,280
    38 Post(s)
    Quote Originally Posted by margallar View Post
    @Xulfiqar
    Ybr's engine is vertical while yb100's is horizontal,both engines have different angles....mounts of both engines are different and as ybr's engine is vertical so it have mount at front while yb100 chassis doesn't had such mount so if you want it to fit you need to cut weld on chassis
    The first step towards knowledge is to know that WE are IGNORANT
    rxlover's Avatar
    Apr 2016
    43
    @Xulfiqar
    Many engines can fit your frame if you have a good dentor...
    It is just a matter of time and money!!!!
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    the yb100 engine you mentioned will do. Fewer alterations are better....denter only knows about joining metal, not metallurgy. I have no trust on those oxy-acetylene welds
    rxlover's Avatar
    Apr 2016
    43
    You are right brother it is better to stick as close to stock as possible.. (p.s its a yd 100 4 stroke engine)
    Sent from my LG-LS980 using PW Forums mobile app
