Results 1 to 3 of 3
Thread: Do i have to change/edit my frame of my CG 125 2016, for my cafe racer built?
    pashagee333's Avatar
    Nov 2016
    Default Do i have to change/edit my frame of my CG 125 2016, for my cafe racer built?
    Asalam u alaikum! I'd really love to know.
    rd3php's Avatar
    May 2015
    67
    No you can build a nice cafe racer on stock cg frame
    Newbie Follow
    hakjaved's Avatar
    Apr 2013
    Post
    You can definitely build on the current frame, but do keep in mind that if you'd like yours to be a "true" cafe racer, the rear seat loop should be present and that would have to be welded on. Of course that isn't too difficult, you could source a rear seat loop from Aliexpress (ready-made available) or have it made locally from steel tubing similar to the one used in the CG frame. The tricky part would be getting a seat to fit onto that new setup since I assume you wouldn't want to use the stock (fat) CG 125 seat, but instead have a thinner cafe racer style seat made with the rear hump and the works. You could work out a new bracket system to secure the seat to the frame properly! Shouldn't be too difficult..
