Results 1 to 4 of 4
Thread: MTT Super Motorbikes
    netsurfer's Avatar
    Jul 2005
    34
    269
    Default MTT Super Motorbikes
    MTT Super Motorbikes -485976
    Engine:
    Rolls Royce Allison
    250 series gas turbine
    Power
    320 HP @52,000 rpm
    (286 HP @ rear wheel)
    Torque:
    425 ft/lbs @ 2,000 rpm
    Output RPM:
    6,000 rpm
    Compressor Speed:
    54,000 rpm
    Weight:
    500 lbs
    Frame:
    aluminum alloy
    Fairings:
    carbon fiber
    Rake:
    27 degrees
    Seat Height:
    31.5 in
    Wheel Base:
    68 in
    Wheels:
    17" carbon fiber, Dymag
    Tires - Front:
    120 60ZR17, Pirelli
    - Rear:
    200 50ZR17, Pirelli
    Brakes:
    3x320 mm floating system- 4 piston
    calipers, Brembo
    Shocks:
    mono-shock adjustable
    oleopneumatic, Ohlins
    Front Forks:
    55 mm inverted
    Fuel:
    diesel, kerosene
    Fuel Capacity:
    8.5 gallons (34 liters)
    Lubrication:
    dry-sump/3.5 quarts turbine oil
    Transmission:
    2 speed automatic
    Rear View:
    rear mounted camera with LCD color
    display plus side mirrors
    Seat:
    single or double
    Colors:
    infinite custom colors
    Price $150,000 USD
    netsurfer's Avatar
    Jul 2005
    34
    269
    sharang_17's Avatar
    Oct 2006
    Jammu
    28
    152
    Its an awesome bike buddy,saw it some days back on Discovery channel.It makes a very strange sound when it moves,that's becz of the gas turbine engine...
    KillaMuf's Avatar
    Jul 2006
    Philadelphia/Karachi
    28
    299
    Gas turbine engine, basically meaning a JET engine. Fastest bike! its awsome!
    Land Rover Series 3 88inch.......PakWheels FTW!!!
