Page 6 of 25 FirstFirst ... 4567816 ... LastLast
Results 101 to 120 of 498
Like Tree12Likes
Thread: Suzuki Sprinter / Sprinter ECO
    xtremist's Avatar
    Jan 2005
    27
    777
    Default Suzuki Sprinter / Sprinter ECO
    well guys there have been so much threads here on this topic, so a noble thought came to my mind tht i should make a STICKY thread which should discuss each and everything of SPRINTER and ECO...
    so ALL STORIES GO HERE and plz dont bother to make any other thread....
    thnx...
    Da OnE aT iTz XtReMez....
  2. #101
    xtremist's Avatar
    Jan 2005
    27
    777
    @ jony
    bro are these weights confirmed? im afraid Junoon's weight isnt this tht you have mentioned...CG 125 is far heavier than sprinter and junoon and your reply says that junoon is heavier than both of them!!
    @ air explorer!
    have a look at this bro...specs of Sprinter...hope they will help you understanding things better ...plz if anybody has junoon specs post them here...
    Suzuki Sprinter 110cc:
    SPECIFICATION
    Engine Type 4 Stroke, Air Cooled, Single Cylinder, OHC
    Displacement 109 cm3
    Bore x Stroke 53.5mm x 48.8mm
    Compression ratio 9.6 : 1
    Carburettor MIKUNI BS22, Single
    Starter System Kick
    Transmisson 4 Speed Constant
    Air cleaner Polyuretnane foam emelent
    Cluctch Wet Multi Plate type
    Primary Reduction 3.666 (77/21)
    Final Reduction 2.500 (35/14)
    Idle Speed 1,500 -+100r/min
    Frame Type Sigle Backbone
    Drive Chain 428, 102 links
    Caster Trail 26/67 mm
    Suspension Front Telescopic coil spring, oil damped
    Suspension Rear Swinging arm coilspring
    Brake Front drum
    rear drum
    Overall length 1,900mm
    Overall width 755mm
    Overall height 1050mm
    Wheelbase 1225mm
    Ground Clearance 165mm
    Dry Mass 119KG
    Tire front 2.50 -6PR tube
    Tire rear 2.75 - 6PR tube
    Fuel Tank 10.5 Litre
    Ignition type Electronic Ignition (CDI)
    Ignition timing 10 BTDC at 1,500 rpm
    Dry Weight 91kg
    Battery 12v9
  3. #102
    Alone_Munda's Avatar
    Oct 2006
    Multan
    32
    255
    @ Vaqas 1..
    @ air_explorer..
    dear would u like to revise the matter about the fuel consumption of both bikes..I mean u should also consider other points (positve or negative..whatever) that a Junoon (100cc) does 55 to 60 Km in a liter (most of its parts are plastic made) and on the other hand a sprinter (110cc) which is heavyier and carrying the material which is most of non-plastic giving plus 60-Km fuel average...,
    and one more point which u must keep in mind that if u drive the bike at over speed or above economy speed (which is almost 60Km/h) than a junoon will give you 48 to 50 km, Whether Sprinter (only in case of over speeding) will give you 55km..otherwise 60 plus is confirmed
    so you can imagine which bike is better...
    i accept that junoon is fine bike but sprinter is also fine in quality and performance.
    @ xtrimest..
    yar plz take snaps (with some digital cam) of ur two mini beasts and put them into orkut's profile..
    ALLAH is my best friend...!!!
  4. #103
    Site Banned Follow
    as2d's Avatar
    Feb 2004
    95
    Suzuki Sprinter  Sprinter ECO -687519
    Suzuki Sprinter  Sprinter ECO -687520
    Suzuki Sprinter  Sprinter ECO -687521
    Suzuki Sprinter  Sprinter ECO -687522
    Suzuki Sprinter  Sprinter ECO -687523
    Ghani Motorcycle Self Start with Remote Control.
    Ghani Motorcylce Kick Start.
    Gi 70 Milage is the only thing u get with Gi 70 that is also 96 Km Per Litre.
    The Suspension is Very Nice. If u drive for longer period of time with 2 person sitting behind...
    Good things about 70 RESALE is good...
    Suspension is better tires are 6 ply wide tires compare to 70cc 4 ply tires...
    And it has a good gear box not like 70s which is very jerky type of gear box.. (All bikes above 70cc have better gear box)
    1 Litre meh 84 Km Guaranteed.
    Self Start & with Remote Control.
    Alloy Rim
    Heavy Duty Front Shock Absorber
    Adjustable Rear Shock
    RPM & Speedo Meter with Gear Indications
    Technical Specifications
    Engine Type: 4-Stroke Air Cooled OHC
    Displacement: 72 CM
    Bore & Stroke: 47.0 X 41.4 mm
    Compression Ratio: 9.1 : 1
    Max Horse Power: 7.0 PS/8500 RPM
    Max Torque: 0.55 Kg-m/6500 RPM
    Overall Length: 1905 mm
    Overall Width: 760 mm
    Overall Height: 1041.5 mm
    Wheel Base: 1219.2 mm
    Ground Clearance: 150 mm
    Dry Weight: 88 Kg
    Starter System: Self
    Transmission: 4-Speed Constant Mesh
    Clutch: Wet-Multiple Plates
    Rim Type: Alloy Rim
    Front Tyre Size: 2.50-17- 6 PR
    Rear Tyre Size: 2.75-17- 6 PR
    Frame Type: Backbone
    Fuel Tank Capacity: 9.0 Litre
    Ignition Type: Electronic Ignition CDI
    Engine Oil: 0.7 Litre
    Ghani is giving 12 Months or 12000 KM warranty on there bikes..
    Honda is giving 6 months or 6000 KM warranty..
    Now choice is urs
    Jini Toadi Oni Sadi.
    Malik Asad
    0300-8477409
  5. #104
    Oct 2006
    Multan
    32
    255
    @ Malik Asad from Islamabad..
    i respect you sir, but yar yahan Yamaha and Suzuki (well reputed bike makers) ki bat ho rahi hai...Ghani ki nahi...
    any way...here the situation was being a bit serious between suzuki members and yamaha lowers...so i think that u provided us a MOMENT OF LAUGH by posting a commercial of ghani bike.its ok...ghani ki commercial parh kar hum sab per farz hota hai ke kam az kam aik martaba HANS dein taky ghani motor bike ki soul ko shanti mil saky..
    take care...
  6. #105
    air_explorer's Avatar
    Aug 2005
    31
    1,316
    @Alone_Munda bro,i didnt say that Sprinter is a junk,I admit from the very start that Suzuki Sprinter is a nice bike no doubt,but really have differences with some pplz saying here that Sprinter is the best,no one like Sprinter,etc..
    @xtremist bro here in Karachi,i think Sprinter have passed almost 3/4 years if I remember correctly but hardly seen few Sprinters.
    thanx
    Valle!! the great with his YZRM1 looks more coool!
  7. #106
    jony96's Avatar
    May 2006
    34
    59
    salam all
    @fahad
    yes these r confirmed! i saw specs of junoon at yamaha's authorised mechanic shop near my house.
    even i was surprised by that. i can get u specs of junoon but it could take 2 to 3 days!
  8. #107
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Well Thing is plastic isnt bad bcoz the read fender always catches rust thats why they have given a plastic one which isnt bad
    Yesterday i bought few things for my bike and gave a visit to suzuki showroom now things are better no more booking needed to get a bike they have like 10 ECO and 10 Normal bikes standing available on cash.. I saw the bikes closely the overall look and finish the sprinter is better..
    Basic difference is few chrome parts the rear shock isnt chromed in eco.. the Air filter box dont have a chrome covers, the break lever isnt chromed.. the guy there i asked him what is the difference between the engines and he said they are 100% same no difference i asked him that i have heard eco isnt same he was like Sir its same and the fuel economy is same as well they didnt change anything..
    I personaly liked finish of Sprinter normal but the round front light is the only thing that i hate about the bike hehe it looks old fashioned even if they wanna give round light they should give one just like CD 100 Crystal light that looks good... i saw one sprinter with front fender changed to black one it was looking nice.. i wonder if there is a light available for the sprinter that we can put on it..
    Btw Extremist hows the Breaks of the sprinter ?
    And why there is a switch on handle bar to turning off the engine ? that cant be done by the key ?
    BTW as far as economy is concern i never drive my CD 70 under 60 to 65 Kmph and it still gives me 68+kmpl :p...
    The reason i want to change the 70 is.
    1. Vibration after 50 KMPH speed
    2. Not Much Road grip and the ride isnt comfertable
    3. and the stupid jerky gear box :p
    4. very low climing ability and with 2 people on bike it just starts to die...
    Speed costs money, how fast can you afford to go.
  9. #108
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ alone munda
    hahahahaha
    well said
    @ malik sahab
    pra g if u post a new topic no 1 will stop u pra g ok?
    @ all
    yesterday i talks w suzuki slaes officer (the same man who had dealt w me for the GS150, n now is freind)
    he says zahid bhai ab Allah ka bara karam hai,
    suzuki has got a new GM from cars dept.,
    he is gr8 and a entrapreneur
    his steps r gr8
    some time back v used 2 go out evrytime for marketing etc.
    now v sit in office n customers r coming n coming,
    complaints do come in eco, but these r minors n can b in cg125 etc also,
    whereas sprinter is fine, people love it, its running specially n sound,
    he said suzuki is changed now and their policies will be different, n in near future u ll c that the 2nd most common bike ll b suzuki,
    last but not the least:
    about gs125
    he said that sprinter eco is competitior of almost all the bikes:
    but the people who wan power but hav limited source for 1st time buying n spending for fuel now prefer 110sprinter, it has power n style almost close 2 cg, whereas the people who hav some power 2 buy a good bike prefer GS150 instaed of gs125
    so v don find scope for gs125
    bcz the sprinter 110 is covring gap v well.
    n guys i think the same thing, gs 150 w its heavier image and self starting system is the prefered choiice haan.
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
  10. #109
    xtremist's Avatar
    Jan 2005
    27
    777
    @ malikg
    well good to hear positive things abt suzuki here...
    wesay abt the NOT SELLING issue of GS 125, i think the blame should be given to SUZUKI itself.... yaar khud hee dekhoo....why dont they make some good advertisement for tht bike?
    i mean they should make a separate advertisement of GS 125 and show its plus points....people dont even know tht GS 125 is a 5 speed bike...i have many friends of mine who dont know....they should make some ATTRACTIVE ADVERTISEMENT to promote its sales....
    yaar itnee zaberdast bike hai GS 125 and i prefer it over CG 125 (may be CG is faster) but still i like it bcoz its something new with great design and 5 speed....
    malikg why dont u talk to sales department of suzuki to make some good add abt GS?
  11. #110
    xtremist's Avatar
    Jan 2005
    27
    777
    @ vakas!
    well bro brakes are good....specially my front brake gives my a feeel of DISK BRAKE...believe me it is very good..i know its no match for disk but still very impressive in drum class..
    well the switch which you are talking abt...well bro its a tradition of suzuki....Suzuki has given a switch on its right handle (above throttle) which is actually an operator or you can say IGNITION SWITCH of engine...
    if this switch is off, to agar aap nay key insert ker k IGNITION ON ker bhi lee hai aur kicks lagaa rahay ho even then the bike will not start until or unless you put this red switch ON....bcoz its the ON OFF of engine..you will find this feature in each and every bike of suzuki in world...its not a very impressive feature (i mean very advantageous) but just a TRADEMARK you can say or a tradition of suzuki....but i like it coz its different...
  12. #111
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ xtre
    ya they must do that haan,
    well weight n quality wise gs125 is far better than cg125
    so . . .
  13. #112
    xtremist's Avatar
    Jan 2005
    27
    777
    yeh exactly..
    next time i visit suzuki showroom i'll specially talk to the admin abt this matter....they can increase the sale of GS 125 through it....
  14. #113
    xtremist's Avatar
    Jan 2005
    27
    777
    @ vakas!
    If you are interested in buying a bike in a few days, i'd recommend to go for Sprinter, not ECO....add 4k more and you'll get a better looking bike...wesay i think you also personally prefer Sprinter over ECO
  15. #114
    xtremist's Avatar
    Jan 2005
    27
    777
    Yesterday evening (Saturday) I went to Suzuki showroom (FJ Suzuki) and as said by Vaqas bhai (in Rwp) same is the case here in lahore...things are pretty much now in control of Suzuki...Sprinter Ecos are available in large quantity but it doesnt mean Sales/Demand have reduced so much....when i was at showroom, already there were three persons,....two getting ready to get their hands on ECO and one on GS 150....and when i was abt to leave another one came...but i think he was for SPRINTER...
    so sales issue is going great for Suzuki....
  16. #115
    seagoat's Avatar
    Sep 2005
    Sargodha
    45
    149
    Eco is the best bike with price tag 49800.
  17. #116
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ SEAGOT
    100 percent right
    UR
  18. #117
    xtremist's Avatar
    Jan 2005
    27
    777
    @ seagoat!
    indeed it is dude...theres no comparison of 70 with Sprinter (performance/quality wise)... one must prefer it over 70 and other 100cc category bikes...
  19. #118
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    Finally, I got my Sprinter ECO today, Mashallah it is far more GooD than Honda70. It was a good ride from commetti chowk Rawalpindi to my home in Islamabad. Its all bcz of this forum that I bought this instead of Honda70.
    Well here I want to ask some question & one problem.
    (1) What should be done in runnning and upto how many Km's & speed?
    (2) The salesman told me that there is no such thing as running with the Suzuki motorcycles and u can start "Double sawari" from here and from low speeds at the beggining. Its the problem with honda only. Because of this on islamabd highway I came on 60km/h on some places and on the average 50km/h. What do u think of this(running) ???
    (3) My Motorcycle clutch is too hard tp pull and I Hurt my wrist pulling it from time to time until I reached home. Can it be fixed so that it can be pulled without applying extra force.
    (4) What tyres pressure should be kept?
    (5) What is the fuel having Octane no 91. in owners manual its recommended. Which companies petrol should I use for my Sprinter(PSO, Shell, Caltex)?
    Any Precautions I should take now with my Zero meter.
  20. #119
    xtremist's Avatar
    Jan 2005
    27
    777
    @ bilal!
    well bro first of all Congrats to ur new rise MashAllah!
    yeh very good and wise choice of yours to get Sprinter in preferance of 70...
    well bro you can have DOUBLE SAWAREE....theres nothing wrong with it...but make sure you dont go over 50kmph during running (Maximum) in 4th gear... dont rev it up at all or you will not maintain your bike's fuel average...
    you can adjust your clutch from the NUT or you can say SCREW right on the right side of your clucth bar...see it and you 'll find it... adjust it wherever you find it best,,
    but i'd recommend k abhi aisay hee chalaao...chaltay chaltay khud hee naram par jaayay ga...
    you should keep tht speed limit upto 1000kms and then get it tuned...
    remember change the oil first time on the completion of first 500 kms....then change it with the interval of every 1000to 1500 kms...
    well i prefer TOTAL over all petrols...i dont know if its available in islamabad...but among them, i think you should consider CALTEX
  21. #120
    VWPassat's Avatar
    Dec 2006
    Multan
    34
    155
    What about its comparison with Yamaha 4 stroke? Which is better?? What's the difference?
