Page 9 of 25 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 498
Like Tree12Likes
Thread: Suzuki Sprinter / Sprinter ECO
    xtremist's Avatar
    Jan 2005
    27
    777
    Default Suzuki Sprinter / Sprinter ECO
    well guys there have been so much threads here on this topic, so a noble thought came to my mind tht i should make a STICKY thread which should discuss each and everything of SPRINTER and ECO...
    so ALL STORIES GO HERE and plz dont bother to make any other thread....
    thnx...
    Da OnE aT iTz XtReMez....
  2. #161
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ bilalahmad
    bro, it is no prob, n it can b a big prob
    HAHAHA
    problem bolay toooooooooooo
    its better u make it ok from any local mechanic but without HATHORA
    @ all
    SUNNY MONEY ORDER LE AAO
    SUNNY SHAZIA KO LE AAO
    yaar ye sunny thakta nahee, eco itni araaam dai hai ?
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
  3. #162
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    Whats the duration of oil change in the Sprinter. Someone on this forum said that after 800kms, its very rapid, My friend who is very expert with engines says that oil should be changed after 1500kms and rapid oil change reduces engine life. I also personally donot believe on rapid oil change and I will change after 1500kms. Some people also change after 2000kms and even once a year in my case for my old Honda 70.
    I have changed the oil on 400kms and when I will go for first service after 1000 will they change my oil? When should I change it?
  4. #163
    xtremist's Avatar
    Jan 2005
    27
    777
    @ bilal!
    bro its ok if you change it after every 1500-2000 kms...i also do the same with my bike....and you changed it on 400 for the first time...now change it when you have completed 2500 or 3000 kms... when my bike was on running,i changed first oil on 500 and second on 3000 as suggested by suzuki...
  5. #164
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    @xtrem
    What do u suggest about these things. Please guide me::
    (1) Air Filter
    (2) Oil Change
    (3) Oil filter
    (4) Plugs
    One guy on this forum said that
    (1) Air Filter Must be replaced after 2000km
    (2) Oil Change must be after 800KM
    (3) Oil filter after 4000km....
    (4) Plugs should be after 5000 Kilometere....
    But I think he is very very rapid in this regard.
    I want ur guidance Xtrem bro.
  6. #165
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Bilal i would like to talk with that friend of yours who thinks rapid oil change can reduce engine life hehe :p...
    Now with oil changes there is a big difference between a engine of car and a motorcycle engine...
    Now whats the difference, a car engine normally have a RPM of around 8 and a bike have an rpm of 12-14 now bcoz the Bike engine is a high revolution engine the oil loses the viscosity or u can say its thickness way before a car engine and bcoz our bikes here uses the same engine oil in gears as well i mean in all our local bike the mobil oil also lubes the gears and gears makes the engine oil contaminate then we have a wet clutch plate system now wet clutch plate system means the clutch is dipped in the oil and that also contaminate the oil way sooner than car engine..
    car engine have separate oil for gears and a dry clutch plate system so if ur changing ur bikes oil like car than i m afraid it might last but when u will go for a rebuild u might have to change a lot more things than a person who is changing oil regularly and on time..
    Engine life totally depends on oil if u can afford change your oil after every 1000Km and the max u can is 1500 Km above that isn't recomended....
    When u go for 1st tunning change ur oil and a new engine bcoz its new the grinding of new parts produces more contamination than an old engine thats why u have to change the oil of new engine 2 or 3 times before the running completes...
    Always use good oil i use Castrol GTX people say caltex havoline is good but i have experienced bcoz the bike engine produces a lot more heat the Havoline starts to fail at around 800km the oil starts to reduce a bit plus if u push ur bike really hard u can smell the burning oil...
    Now the choice is yours i would recomend you should change your oil on 1000. then u should change it at 1600 Km bcoz the suzuki engine breaks in late u should change it at 2000 KM and after that every 1500 Km and Oils if u can find Total Quartz 5000 Oil that will be best 1 liter casts 230 but its the best oil and latest but the 1 liter pack is hard to find if u can find that than go for GTX and than Havoline... always use 20w-50w oil in the bike
    Speed costs money, how fast can you afford to go.
  7. #166
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ bilal
    bro it depends upon the usage,
    well bike engines should b given oil change after max 1200kms,
    wat do u think, or if u r a slow gear accelerator then
    1500
    well ur bike ll tell u
    then note that reading down n inform ur self that it ll find changes on . . . kms,
    but for next time dothat before 100kms atleast
    hahaha
    easy step
    SUNNY MUNNAY KO LE AAO,
    SUNNY BILAL KO SAMJHAAAO
  8. #167
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    What do u suggest about the change of these things. Please guide me::
    (1) Air Filter
    (2) Oil filter
    (3) Plugs
  9. #168
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ bilal
    air filter:
    i think it is washed haan ?
    ok for every 1000kms
    oil filter:
    i think every 2000kms or as suggested by the Specialist
    plug:
    as suggested by the Specialist after checking the old 1.
  10. #169
    xtremist's Avatar
    Jan 2005
    27
    777
    @ bilal!
    about the air filter,i think its a very important thing for smooth running and must be cleaned..i change the air filter of my bike after every 2 tunings...
    about oil filter, get it changed whenever you get the oil changed,,thats wut i do..
    and about the plug, it goes for about 3000-4000 kilometers easily...but get the plug from SUZUKI itself...dont use other ones...
  11. #170
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    My ECO has done 950kms, I have done 110km/hr with double sawari today. I will go for first service tomorrow. By the way, is thier any differrence in fuel consumption of Normal Sprinter(54000 wali) and Sprinter ECO?
  12. #171
    xtremist's Avatar
    Jan 2005
    27
    777
    hain?? wtf? you have already done 110kmph....yaar kuch to khyaal karoo....the speed limits during running highly effect the FUEL CONSUMPTION of bike....
    btw i dont think theres any difference...
  13. #172
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    Yaar bus 900 kafi hay na, aur kitni running hugi. Yeh ju loog kehtay hain keh Engine khulu aur speed har gear mein top tuk lay kar jao. is say kya huta hay. Kya bike ki permanent fuel consumption barh jaye gi kya?
  14. #173
    xtremist's Avatar
    Jan 2005
    27
    777
    well yes 950km is enuff for 1st tuning...
    and i recommend that when you get it tuned for 1st time,start reving up ur bike....take it to 50-60kmph in 2nd gear....dont hesitate...its not 70..it will go easily there.i know you'll call me mad but i have taken my bike to 80kmph in 2nd gear many times,specially after 1st tuning,coz somebody told me that khainchnay say bike kee performance khultee hai..if you do it for abt 500km,you'll start feeling that its performance has started boosting up...its important for best performance....during this REVING PERIOD,bike will consume a little more petrol but dont worry....coz the average fuel consumption of bike is almost set now as running is almost complete
  15. #174
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    So Bilal what sort of consumption ur getting from your bike ?
    hows the starting in the morning ?
  16. #175
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ all
    don tell anything 2 vakas without getting Rs from him,
    he just ask us many things n sells those details out, bcz u can c he is not using these details for himself,
    he still has a 70cd
    hahahaha
    @ vakas
    theek hai bhaai theek hai
    yaad rakhna ab aap
  17. #176
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Malik yaar Main ta honda he lai sa :p
  18. #177
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    Today I visited the Suzuki showroom Commetti chowk,Rwp for first tuning. I saw that they have also added the Normal Sprinter to the catagory of ECO. There are printed advertisements for it there, just like ECO saying that it also does 73km/litres. So,now its confirmed that there is no difference in the Engine of Normal Sprinter and ECO. And they both can do 65+ if driven with normal speeds. Mine also giving 65km/litres now. NowI have completed running willl it maintain it after running.
  19. #178
    xtremist's Avatar
    Jan 2005
    27
    777
    @ bilal!
    yeh i know company claims same mileage for both...
    if somebody remembers than about 2-3 years ago,when SPRINTER was very new and there were no GS,suzuki used to advertise sprinter on TV...there was a good add having a logo of 73 KILOMETER WAALEE when the husband teases his wife by saying this line...remember??means both have same mileage (ECO AND SPRINTER)
    bilal bhai now you can drive ur bike however you want...no fears...take it to 90-100 quite often (if you have roads)...iss say engine khulay ga
  20. #179
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Nice Bilal now running is over hows ur bike running ? u had a 70 previously so why dun u give us a complete review of the bike ?
    xtremist u know why i didnt changed my bike to Sprinter well bcoz my plans are to buy a car sooner or later so if i bought Sprinter the market i have seen the max i might get was 38 and the Suzuki showroom guys when i insisted to answer my resale questions realisticaly they said after a year u will get 35 to 36 hmmz and i m getting 48 on my almost 11 month used 70 hmmz big difference right.. anyways i dont like 70 at all hehe other than fuel,resale and reliablity but kia karein majbouri hai i cant have a bike forever..
  21. #180
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ VAKAS
    well Allah kaamyaab karay or tarakki day
    but u ll miss ride of a gr8 bike,
