Results 1 to 6 of 6
Thread: 2007 GSX-R1000
    taha123's Avatar
    Aug 2006
    27
    41
    Default 2007 GSX-R1000
    To the team of Suzuki engineers responsible for the GSX-R1000, Own The Racetrack is not just a slogan, it is a way of life.
    It is a life dedicated to making the most successful open-class motorcycle in the history of production-based racing even better. By applying the latest technology and the most recent hard-fought racing experience. And keeping the GSX-R1000 well ahead of the would-be competition.
    The Key is the motorcycles' ability to do precisely what the rider wants, when the rider wants, how the rider wants. Accelerate. Brake. Corner. Repeat. Make it easier for the rider, and the results will show. With better lap times on the racetrack, and more fun on the road.
    It is called Total Performance. It is what makes the 2007 Suzuki GSX-R1000 the Top Performer. And it is why Suzuki riders Own The Racetrack.
    2007 GSX-R1000 -490944
    New Engine
    New 999cc 4-stroke, 4-cylinder, liquid-cooled engine for increased power, torque and acceleration with forged aluminum alloy pistons, chrome-moly shotpeend connecting rods, hollow camshafts, and a secondary balancer shaft for reduced vibration
    New more compact fuel injection system features the Suzuki Dual Throttle Valve System (SDTV) - with twelve smaller holes for improved fuel delivery and steeper angle for secondary injectors
    New intake and exhaust ports are reshaped and eight percent larger with larger titanium exhaust valves tappets, more aggressive camshafts, and iridium spark plugs
    New Idle Speed Control (ISC) system for improved cold starting, consistent idle quality and reduced emissions
    New high volume Suzuki Advanced Exhaust System (SAES) with equal length head pipes feeding a unique under engine chamber leading to two compact aluminum/titanium mufflers on each side
    The new mid-pipe includes a Suzuki Exhaust Tuning (SET) system for maximum torque throughout the rpm range and an oxygen sensor used by the engine management system and combined with the under-engine catalyzer for reduced emissions
    New larger 48mm ventilation holes between cylinders reduce pumping losses and the crankcase breather system now features a reed valve to prevent pressure waves in the airbox from reaching the crankcase
    New self adjusting hydraulic clutch minimzes changes in clutch feel over a long race
    Back-torque limiting clutch allows smooth downshifts, plus a rack and pinion operating system provides more positive clutch feel
    New engine management system is four time more powerful than the previous system and allows the rider to choose from three engine settings to match riding conditions with a handlebar mounted switch
    New larger radiator utilizes a trapezoidal shape seen on works racebikes with 10% more cooling capacity. The oil cooler now works with a larger oil pump.
    New Chassis
    All new aluminum alloy twin-spar frame is built using five castings for lightweight, unmatched handling and performance, increased production precision, and reduced weight.
    New braced aluminum-alloy swingarm is more rigid and features an innovative new link system which pivots on the swingarm itself for increased traction and reduced side loads.
    New DLC coated 43mm forks and rear shock now feature high and low speed compression damping along with adjustable rebound and preload settings
    New forks feature larger 56mm outer tubes below the triple clamp for increased rigidity and fork offset is changed from 30mm to 28mm. Front wheel travel is also increased from 120mm to 125mm.
    New electronically controlled steering damper uses a solenoid valve to move a tapered needle reducing or increasing oil flow to adjust damping force.
    New adjustable rider footpegs can be moved into three different positions to suit rider preferences
    New 310mm front brake discs are attached to the carrier with increased mounting points for improved heat transfer away from the disc.
    Rear disc works with a single piston caliper and is mounted above the swingarm for reduced braking effect on the rear suspension
    New wind tunnel developed bodywork features an aggressive new style, reduced frontal area and a taller windscreen for optimum aerodynamic peformance
    New vertically stacked headlight features an updated shape with a compact projector bulb and when combined with the sleek bodywork and tailsection offer maximum rider mobility and improved styling
    A new easy-to-read instrument cluster includes a step motor controlled analog tachometer, digital LCD speedometer, dual tripmeters, clock, convenient gear position sensor, rpm indicator light and a new LCD engine mode indicator displaying which performance setting has been selected by the rider
    Close-ratio slick shifting six-speed transmission with an adjustable back torque limiter for smoother downshifts.
    Bridgestone radial tires mounted on cast aluminum wheels featuring thin spoke design with optimized wall thickness to reduce unsprung weight
    Specs
    Engine: 999cc,4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
    Bore Stroke: 73.4 x 59.0mm
    Compression Ratio: 12.5:1
    Fuel System: Fuel Injection
    Lubrication: Wet Sump
    Ignition: Digital/transistorized
    Transmission: 6-speed, constant mesh
    Final Drive: #530 chain
    Overall Length: 2045mm (80.5 in)
    Overall Width: 720mm (28.3 in.)
    Overall Height: 1130mm (44.5 in.)
    Seat Height: 810mm (31.9 in.)
    Ground Clearance: 125mm (4.9 in.)
    Wheelbase: 1415mm (55.7 in.)
    Dry Weight: 172 kg (379 lbs.)
    Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, high & low speed compression and rebound damping
    Suspension Rear: Link-type, gas/oil-damped, fully adjustable spring preload, high & low speed compression and rebound damping
    Brakes Front: Dual hydraulic disc
    Brakes Rear: Single hydraulic disc
    Tires Front: 120/70-ZR-17
    Tires Rear: 190/50-ZR-17
    Fuel Tank Capacity: 18 liter (4.8 gal.)
    Color: Blue/White, Black/Orange, Yellow/Silver
    xtremist's Avatar
    Jan 2005
    27
    777
    yeh man....OWN THE RACETRACK is not only a slogan....its wut GSXR is....i have read many reviews of this bike's previous models already (k5,k6) and im totally impressed with it...see urself
    press NEXT button for next review...
    http://www.reviewcentre.com/review222595.html
    Da OnE aT iTz XtReMez....
    tommy99's Avatar
    May 2005
    31
    56
    Its sure is a beauty..........thts wat i want.....
    gem_guy's Avatar
    Dec 2004
    Burnin Rubber in
    27
    6,137
    waah waah...
    Nice bike!
    RX-7? An RX-7? Really? I hope you know it's just a sports car with a washing machine under the hood.
    poppatTURBO's Avatar
    Dec 2004
    Multan
    38
    1,720
    ghata GSXR 1000 (Y)
    Suzuki GS150 2005...Im Lovin' It :-)
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    no offense against the gsxr-1000 but i'd still prefer a gsxr-600
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
