Closed Thread
Results 1 to 7 of 7
Thread: yama Janoon Vs Suzuki 150
    princesaqib's Avatar
    Dec 2005
    Gujranwala
    30
    1,996
    2 Thread(s)
    Default yama Janoon Vs Suzuki 150
    which 1 is a better option to buy please compare on all basis
    thnk you
    xtremist's Avatar
    Jan 2005
    27
    777
    lol!!! believe me im still laughing while typing...JUNOON should be compared by Sprinter....not 150 bro...
    Sprinter is better than junoon.. (except looks)...
    Da OnE aT iTz XtReMez....
    xtremist's Avatar
    Jan 2005
    27
    777
    here is the detailed comparison of junoon and sprinter...(junoon has limited spex,sorry for tht)
    SPRINTER:-
    Specification:
    Engine Type 4 Stroke, Air Cooled, Single Cylinder, OHC
    Displacement 109 cm3
    Bore x Stroke 53.5mm x 48.8mm
    Compression ratio 9.6 : 1
    Carburettor MIKUNI BS22, Single
    Starter System Kick
    Transmisson 4 Speed Constant
    Air cleaner Polyuretnane foam emelent
    Cluctch Wet Multi Plate type
    Primary Reduction 3.666 (77/21)
    Final Reduction 2.500 (35/14)
    Idle Speed 1,500 -+100r/min
    Frame Type Sigle Backbone
    Drive Chain 428, 102 links
    Caster Trail 26/67 mm
    Suspension Front Telescopic coil spring, oil damped
    Suspension Rear Swinging arm coilspring
    Brake Front drum
    rear drum
    Overall length 1,900mm
    Overall width 755mm
    Overall height 1050mm
    Wheelbase 1225mm
    Ground Clearance 165mm
    Dry Mass 119KG
    Tire front 2.50 -6PR tube
    Tire rear 2.75 - 6PR tube
    Fuel Tank 10.5 Litre
    Ignition type Electronic Ignition (CDI)
    Ignition timing 10 BTDC at 1,500 rpm
    Dry Weight 91kg
    Battery 12v9
    JUNOON:-
    Specification:
    Engine: 4 stroke OHC
    Displacement: 97.1cm3
    Bore and Stroke: 50 x 49.5mm
    Compression Ratio: 9.0:1
    Fuel Consumption: 55 KM/L
    Transmission: 4 speed constant mesh
    Starting: Kick starter
    Frame: Backbone
    Ground Clearance: 160mm
    Dry Weight: 86KG
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,289
    16 Post(s)
    Suzuki 150 is best but janoon have killing looks
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Looks...... Junoon
    Overall Build quality....... Both Equal
    Warranty....... Suzuki 1 year. Yamaha 6 months.
    Fuel consumption... Suzuki 150. 35 to 38 Kmpl and Junoon 50Kmpl+
    Engine Quality.... Again equal
    Engine power..... Suzuki 150
    Other advantages.. Suzuki 150 is a self start bike..
    Resale Value.... Suzuki 150 will be hard to sell and Junoon might sell but with lose..
    If u talk about overall bike u cant compare a 150cc bike to a 100cc bike its like comparing a 800cc car with 1300cc...
    150 is a better option if u want good power and ok fuel economy and Junoon gives good economy and ok performance...
    Speed costs money, how fast can you afford to go.
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    @ admin
    100% same things r being discussed in so detailed topic GS125 & GS150
    plz close this,
    @ vakas
    yeh consumption ka pata kahan se chala ?
    150 has almost close 2 cg125
    @ prince saqib
    if u want a detaileds overview
    plz visit GS125 & GS150 topic
    plz stop it man
    STOP IT BOLAY TOOOOOOOOOOO
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    Go to the following link for a detailed discussion:
    https://www.pakwheels.com/forumreply...mID!22~pw.html
Closed Thread
