Results 1 to 6 of 6
Thread: Race Tuning kawasaki gto 125
    Roshaan's Avatar
    Aug 2005
    25
    286
    Default Race Tuning kawasaki gto 125
    [b]RaCE tuned kawasaki gto125[/b]
    I was planning to buy a gto125 and race tune it this time wen i go to lahore, i am not really sure that i will be able to as i will have only 2 months in these holidays.
    Engine
    -Racing piston
    -Oversized piston rings
    -Big bore Aluminium cylinder w/larger cooling fins
    -bigbore aluminium cylinder head w/larger cooling fins
    -Racing crank, piston rod and bearings
    -Port polish
    -Titanium Valves and springs
    -Engine chrome plating/anodising
    -Aluminium/titanium bolts
    Clutch
    -Racing Clutch
    -Aluminium flywheel
    Gearing
    -5 speed Customised gear ratios
    Ignition
    -Racing ignition coil
    -Racing iridium spark plugs and wires
    -Retard timing
    Exhaust
    -Custom build 2t titanium expansion chamber and silencer
    Carburettor and Fueling
    -Synthetic engine oil
    -Custom fuel and oil filter
    -2xcarburettors
    -Carbonfibre reed valves
    -Customized air box
    -Racing air filter
    Weight reduction
    -Customised lightweight mudguards
    -Custom lightweight front forks
    -Short lightweight handlebars
    -Custom longer adjustable aluminium swing arm
    -Cutoff framework
    -Custom shocks
    -Custom sprockets and chain
    -Lightweight racing seat
    -Alloy wheels
    -Front and rear disk brakes
    -Aluminium /titanium bolts
    -Removal of-Drum brakes
    -Chain Guard
    -Stand
    -Stock meter
    -Stock intigators
    Appearance
    -Custom Xenon Headlights
    -Custom indiglow meter (rpm, speed, temp. fuel, battery, oil)
    -Custom handlebar grips, levers
    -Custom Brake lights and indicators
    -flame thrower kit
    -Custom Paintwork
    -Neons
    Other
    -Racing tyres
    Could this actually be done in lahore? If yes how much will it cost?
    Roshaan
    burdman's Avatar
    Dec 2006
    Chicago
    26
    730
    Lahore is the city of endless possibilities, anything can be done. Why not just get a sport (heavy) bike insead?
    Texas Raised
    Roshaan's Avatar
    Aug 2005
    25
    286
    srry for replying late. A good heavy bike would cost me about 4 lack and i dont have that kind of a budget. I dont think any of the parts would be available in pakistan. would they?? like 60 mm carbs, forged piston, knife edged cranks and expansionchamber exhausts...??
    Roshaan
    burdman's Avatar
    Dec 2006
    Chicago
    26
    730
    probably not....just import them with your bike
    Texas Raised
    Jehanzeb's Avatar
    Sep 2004
    46
    193
    You are spouting random performance parts that have no relevance to the GTO 125.
    Most of the parts you mention are not worth the money/performance ratio since these can only be custom fabricated.
    On top of that just because it is a custom part does not necessarily mean higher performance.
    A 60 mm carbuerator is not meant for the GTO and parts like these below will cost more than the bike itself:
    Also, the GTO has a single cylinder engine. You wont be able to use this on the GTO:
    -2xcarburettors
    Get a Yamaha Rx-115. They are fast.
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    The best deal to modify GTO 125 in Lahore is to go to Boby Autos adjecent to Modren Autos (Dealer of kawasaki Spare parts) on Mcleod road.
    As per my information & experience he is the best mechanic for stock & modified GTOs in Lahore. & as far as u r targetting some performance parts & modifications most of them are not possible in GTO as its a two stroke bike & some mentioned jobs which can be applied to GTO might not be done in pakistan due to resource limitations.
    Exploring Machines is my Passion...
