Results 1 to 14 of 14
Thread: Main Diffrence between CBR600RR & CBR1000RR
    Titans's Avatar
    Aug 2006
    26
    370
    Default Main Diffrence between CBR600RR & CBR1000RR
    Can anyone plz kindly tell me the main diffrence between the CBR600RR & CBR1000RR...other than the extra 400cc...is it sum body changes or wat ?
    It will be greatly appricited...as i am getting a bike in Summer 08 Inshahallah
    CBR600RR
    Main Diffrence between CBR600RR & CBR1000RR -512611
    CBR1000RR
    Main Diffrence between CBR600RR & CBR1000RR -512612
    OmanRasheed's Avatar
    Jun 2006
    24
    133
    cbr600 is 600cc
    cbr1000 is 1000 cc
    simple
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Powersports Model Comparison Tool
    Honda CBR 1000RR
    ENGINE
    Engine Type 998cc liquid-cooled inline four-cylinder
    Bore and Stroke 75mm x 56.5mm
    Compression Ratio 12.2:1
    Valve Train DOHC; four valves per cylinder
    Carburetion Dual Stage Fuel Injection (DSFI)
    Ignition Computer-controlled digital transistorized with three-dimensional mapping
    DRIVE TRAIN
    Transmission Cassette-type, close-ratio six-speed
    Final Drive #530 O-ring-sealed chain
    CHASSIS / SUSPENSION / BRAKES
    Front Suspension 43mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
    Rear Suspension HMAS Pro-Link single shock with spring-preload, rebound and compression-damping adjustability; 5.3-inch travel
    Front Brakes Dual full-floating 320mm discs with four-piston radial-mounted calipers
    Rear Brake Single 220mm disc with single-piston caliper
    Front Tire 120/70ZR-17 radial
    Rear Tire 190/50ZR-17 radial
    DIMENSIONS
    Rake 23.45 degrees
    Trail 100mm (3.9 inches)
    Wheelbase 55.2 inches
    Seat Height 32.3 inches
    Dry Weight 388 pounds
    Fuel Capacity 4.8 gallons, including 1.06-gallon reserve
    OTHER
    Emissions Meets current CARB and EPA standards. California version differs slightly due to emissions standards.
    Available Colors Light Silver Metallic, Red/Black, Black/Metallic Gray, Blue/Orange/White/Red
    Model ID CBR10RR
    FACTORY WARRANTY INFORMATION
    1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan
    Honda CBR 600RR
    ENGINE
    Engine Type 599cc liquid-cooled inline four-cylinder
    Bore and Stroke 67mm x 42.5mm
    DRIVE TRAIN
    Transmission Close-ratio six-speed
    Final Drive #525 O-ring-sealed chain
    Front Suspension 41mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travel
    Rear Suspension Unit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability; 5.1 inches travel
    Front Brakes Dual radial-mounted four-piston calipers with 310mm discs
    Rear Tire 180/55ZR-17 radial
    DIMENSIONS
    Rake 23.7 degrees
    Trail 96.3mm (3.8 inches)
    Wheelbase TBD
    Dry Weight 345 pounds
    Fuel Capacity 4.8 gallons, including 0.9-gallon reserve
    OTHER
    Available Colors Black, Pearl White/Silver, Red/Black, Ultra Blue Metallic/Silver
    Model ID CBR600RR
    1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
    Honda CBR 1000RR 2007
    Main Diffrence between CBR600RR & CBR1000RR -741364
    Honda CBR 600RR 2007
    Main Diffrence between CBR600RR & CBR1000RR -741365
    Note:- 400cc Is Closed By Honda Company .
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    Titans's Avatar
    Aug 2006
    26
    370
    @r1
    thx for the info and pics buddy...but i like the 2006 Models better lol...
    There's no cosmetic (body) changes in the 2006 and 2007 models right ?
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    cant give anymore info...r1 wrote it all
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    Titans's Avatar
    Aug 2006
    26
    370
    Thx for the info and pics buddy...but i like the 2006 Models better lol...
    There's no cosmetic (body) changes(between CBR600RR & CBR1000RR) in the 2006 models right ?
    I think they look the same but obviously perform different...
    Titans's Avatar
    Aug 2006
    26
    370
    Anybody....?
    Please
    Titans's Avatar
    Aug 2006
    26
    370
    Anyone ?
    Xtrapreneur's Avatar
    Mar 2007
    35
    295
    maybe a couple of hundred thousands difference between the two?!!!
    Biker_Isb's Avatar
    Mar 2007
    40
    101
    I used to own a honda cbr600rr but now i have a honda cbr954rr. The major difference i felt was the power. Although the 600 is very fast but 1000 is more powerful and it has the same weight as of 600. The front lifts out after 8000 RPM without pulling the clutch on the bike.
    Ride Safe - May Allah safe us all from unforeseen accidents. Amin
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @biker
    u mentioned it has the same weight as the 600cc...is the frame of 1000 lighter than that of 600??
  12. #12
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    CBR 600=345 pounds.
    CBR 1000= 388 pounds.
    @Titanic, If its your First bike then a 250cc, 4 cylinder will be enough, why a 600cc or a 1000cc ? Those bikes are killers, can kill in a split second.
  13. #13
    Biker_Isb's Avatar
    Mar 2007
    40
    101
    Foosa,the frame is usually the same(weight, slighty different). The technology factor is far better in 1000cc because they make machine which are light weight and have more power.
  14. #14
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    thanx for clearing that out...one of my frend once said that the difference is of the frame, that the frame of 1000 is lighter than 600 hence the weight balancing..anyways both are really fast machines
