Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 52
Thread: modification on my bike
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    Default modification on my bike
    wat r da simple modifications wich can b done on a bike
    (@rs4lyf3
  2. #21
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    kahaN CHALE GAI SARE BIKER BOYZ
    (@rs4lyf3
  3. #22
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    abi ye gari ke modification ke baat hoti to aap sab toot parte
    (@rs4lyf3
  4. #23
    yankee_137's Avatar
    Mar 2007
    Islamabad , Ottawa
    24
    2,817
    @badboykool
    yar yahan almost saray hi car fanatic hain.
    not much into bikes thats why no is helping u.
    “When the power of love exceeds the love for power, the world will finally know peace"
  5. #24
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    why on earth would you want to modify such an OLD bike, get a new bike, then modify it.
    that cd175 gives me the creeps, man.
  6. #25
    moizladak's Avatar
    Feb 2005
    30
    136
    hey abt the modification u can do it as u like .. u can do some modification in the engine .. like a bigger range piston ... or change it with a cd 200 head,cylinder,piston and a weight rod ... other then that some electrical work can make bike go lite .. i means smooth and quick in pick up .. its up to u ... even if u get a cd 200 carboratour in ur pic and make a free flow cylencer it would perform .. good .. some other work culd also be done ... its up to ur wish and the money u spend ................... but in my opinion .. just drive some other cd 175 and see where is ur bike lacking from the other ones ..... CD 175 is for pleasure and smotth riding in my opinion not for speed ....
  7. #26
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    yaar change the plugs...since you are in karachi get a good exhaust system as well as it increases the performance...other than that i heard there is this thing called MINI TURBO found in karachi dont know if its real or not but if the stories are true than get one of that...what it does is that somewhere in the fuel lines it saves up droplet of petrols and then at higher RPMS punches it all at once giving a lil boost...but im not sure about this coz i've never seen one of these things...well thats enuff from me coz i dont have much experience with hondas
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
  8. #27
    razaksyed's Avatar
    Jun 2004
    Kabul
    47
    1,003
    if you are reallty serious about it, then you could do some work on your bike to look different.
    Widen the rear suspension to allow a wider tire fit in, you would also need to widen the fender and cut it half. Enhance front clearance by adding chopper style forks and as you did that, try to find a pair that would fit a wider tire. The gas tank would look hidious with this modification so you would need to replace it with a bigger one say Honda 400 etc and finish it up with a combination of paint and chrome / trims. the same you may wanna do to the side covers / tappey. You would also need to redesign your seat....
    Actually it wont work until you make a drawing and plan the modification. For Exhaust pipes, there are so many ideal you may want to steal some ideas from American Chopper Show on TV
    And hey replace the headlight with the one from a classic bike (round one) say Triumph 500 Twin or Matchless and dont forget to put a chromed eye lash on it
    best of luck
    Matchles G3L 1941, Triumph TRW 1951, Matchless G3LS 1952, Triumph T 100S 1968, Matchless G2 1958, BSA B-31 1952.......... I am insane!
  9. #28
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    razak...bro i think you are giving the ideas keeping indonesia in mind
  10. #29
    chanda's Avatar
    Sep 2006
    Rahimyar khan
    26
    1,289
    6
    2 Post(s)
    mien hooon na
    "THE BEGINING IS ALWAYS TODAY"
  11. #30
    poppatTURBO's Avatar
    Dec 2004
    Multan
    38
    1,720
    @ badboykool
    change the sprokets, get the old piston out, get the chamber bored and put a new bigger piston like say of honda 250 of police bikes. add disk brake to the front. if u wannt to install a new wider tire, u';ll hav to widen the length of the rear swing-arm and suspension to fit it. make the front forks more declined in angle like 5-10 degreess more to giv it a classic hog look. add a new exhaust pipe. it can easily be made from any heavy bikes mechenic shop. they can custom made it for u. Since it has 2 cylinders so it will be a simple but custom made 2-into-2 or U can have 2-into-1 Xhaust to ur specifications like give it a slashed tail look like kawasaki eliminator series or u can have long tail pipes like harley fatboy 1200. redesign the fuel tank as the present one is too lame. have some good fabricator design it 4 u..believe me everything is done in Pakistan and mechenics here r very well talented and know their work. u'll have to invest a hefty amount of time in modifying ur bike.
    im posting a few pics 4 u sodat u can get the idea of modifications xteriorly.
    modification on my bike -752223
    modification on my bike -752224
    modification on my bike -752225
    modification on my bike -752226
    Suzuki GS150 2005...Im Lovin' It :-)
  12. #31
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    my two cents: GET A NEW BIKE! dont waste any money on this several years old bike.
  13. #32
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    thx guyz fo ur replys but i need som simple modifications widening da bak tyre is 1 o dem my engine is runnin good so i don wan interfere wid it i was thinkin if i can put splitfire sparkplugs usd on modified cars ne idea if dey can b used on bikes n i was plannin of changin da cylincers n once i did use wide 1s lik on cb 180 but dey din giv much difference n i herd free flowin cylincers weeken da engine n im plannin to put a bigger cb 200 carburator on it ne oder simple modifications plx
    (@rs4lyf3
  14. #33
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    ne idea if i can use split fire or bosch spark plugs on ma cd 175
    (@rs4lyf3
  15. #34
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    n i don think so derz ne thin as a turbo or ne thin simmilar wich wod boost perfomence for bikes in karachi n if der is plz let me know
    (@rs4lyf3
  16. #35
    jamaal's Avatar
    Nov 2003
    48
    178
    trying to figure out why you would want to modify a bike you advertised for sale on Tuesday (todays Saturday)!!!
    Whats the twin cyl bike standing on the right. Is this the modification candidate?
  17. #36
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @badboy
    yaar how much simpler can we get about bike modification :s...me ..poppat turbo and razak pretty much summed up all you can do with ur bike and still ur saying...u need SIMPLE MODIFICIATIONs ?
  18. #37
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    thx bhai fo ur help il try doin som of dem,u sad i shod change da plugs wich oder plugs shod i use to boost perfomens n if i can use splitfire spark plugs on it
    (@rs4lyf3
  19. #38
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    da 1 on da rite is da 1 its ma current project in action to soop dis cd 175 up n if i don sell it it b sooped up
    (@rs4lyf3
  20. #39
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    bro im gonna do some modification on my bike as well
    its a 150cc...and im gonna put a cd200 piston in it with all the boring and stuff to go with...i will tell u about the spark plugs after consulting from my mechanic
  21. #40
    humy's Avatar
    Apr 2005
    4,705
    @foosa...bro who is ure mechanic?
