Results 1 to 10 of 10
Thread: 8200cc BOSS HOSS custom bikes
    osakaboy's Avatar
    Apr 2004
    38
    2,278
    31 Post(s)
    Default 8200cc BOSS HOSS custom bikes
    COMPANY DETAILS
    ‘Made in the U.S.A.’, Boss Hoss Cycles, Inc. is located in Northwest Tennessee. Our manufacturing plant, office and warehouse facilities encompass 22,000 square feet on seven acres at 790 South Main Street in Dyersburg, TN. If you’re ever in the area stop in and check us out, whether it is just a quick stop by the showroom featuring cycles and apparel, or a pre-scheduled tour encompassing our entire manufacturing facility. From the size of our facility to the number of dedicated employees on staff, you can see first hand that the Boss Hoss is manufactured in a clean, streamlined facility where its crafters take great pride in the products they produce.
    DEATILS
    Engine
    TypeLiquid Cooled V-8
    Horsepower502 @ 5200 rpm
    Torque567 Ft.Lbs @ 4200 rpm
    BlockCast Iron - 4 bolt main
    CylindersAluminum (110cc)
    Valvetrain2.25"Int. / 1.88"Exh
    Size502 c.i. (8200cc)
    Compression9.6:1
    CarburetorHolly 850 cfm
    Exhaust2.5" with dual mufflers
    Transmission2-speed semi-auto w/rev.
    Final DriveBelt, Gates- Polychain
    Dimensions
    Overall Length108"
    Wheel Base82.0"
    Seat Height28.5"
    Rake33.0 degrees
    Grd. Dlearance4.5"
    Frame Width31.0"
    GVWR1827 lbs.
    Dry Weight1300 lbs.
    Tires/Wheels
    Front130/90-16, 3.50"x16.0"
    Rear230/60, 7.0"x15.0"
    Suspension (Adj. Preload)
    Front63mm inverted forks, 3.5" travel
    RearDual 13.5" coilover shocks
    Brakes
    FrontDual four-piston calipers, 12.6" floating disc
    RearSingle four-piston caliper
    FuelTank8.5 gal.
    Reserven/a
    High/Low MPG18/13
    8200cc BOSS HOSS custom bikes -518188
    8200cc BOSS HOSS custom bikes -518189
    8200cc BOSS HOSS custom bikes -518190
    8200cc BOSS HOSS custom bikes -518191
    I hope there comes a day when cancer goes back to just being a zodiac sign
    osakaboy's Avatar
    Apr 2004
    38
    2,278
    31 Post(s)
    MODEL BHC-3 ZZ4 5700cc
    DETAILS
    Engine
    Horsepower355 @ 5250 rpm
    Torque405 Ft.Lbs @ 3500 rpm
    CylindersAluminum (58cc)
    Valvetrain1.94"Int / 1.5"Exh.
    Size350 c.i. (5700cc)
    Compression10:1
    CarburetorHolley 750 cfm
    Exhaust2.0" with dual mufflers
    Dimensions
    Overall Length106"
    Wheel Base80.0"
    Seat Height28.0"
    Rake33.0 degrees
    Grd. Dlearance4.5"
    Frame Width28.0"
    GVWR1675 lbs.
    Dry Weight1100 lbs.
    Tires/Wheels
    RearDual 13.0" coilover shocks
    Brakes
    RearSingle four-piston caliper, 12.6" floating disk
    Fuel
    Tank8.5 gal.
    Reserven/a
    High/Low MPG25/20
    8200cc BOSS HOSS custom bikes -757469
    8200cc BOSS HOSS custom bikes -757470
    8200cc BOSS HOSS custom bikes -757471
    8200cc BOSS HOSS custom bikes -757472
    Mfuad786's Avatar
    Jul 2005
    35
    573
    2 Post(s)
    Looks like a Two wheeler Truck
    UAEfied
    raja_aftab_yasin's Avatar
    Oct 2005
    35
    5,186
    very heavy bike but this bike height is very low
    baby bike
    NAMAZ ADA KARO ISE SA PHALA KA THUMARI NAMAZA JANAZA ADA KIA JAY
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    @Mfuad786
    It is a 2 wheeled truck!
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    the last time i checked...the biggest engine they put on the bike was a 5000cc v8 ...good to see that they have moved up to 8200cc
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    rkhnsh's Avatar
    Jun 2005
    Peshawar
    27
    3,787
    @sami_voodoo Well sAiD
    Toyota AE86 (????) for life...
    Engine on Fire...Intercooler on Rescue..
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @osakaboy
    Great post, thats a nice bike. And yes, I liked your signature, very true.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    afridino1's Avatar
    May 2005
    houston
    35
    4,146
    nice choppers
    See my updated postings for Houston Auto Show at http://www.pakwheels.com/forumreply_az_TopicID!95584~ForumID!17~pw.html
    osakaboy's Avatar
    Apr 2004
    38
    2,278
    31 Post(s)
    Mfuad786
    raja_aftab_yasin
    sami_voodoo
    foosa
    afridino1
    Thank you for your comments.
    My japanese customer intrested in this bike.
    I am inquiring about prices & avalibility. He is intrested in 8200cc bike . Boss Hoss will send me performa invoice on monday.I will tell u guyz about their asked price later.
    @7thgear
    thank you for your comments & about my signature also.
