Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: how well do you know ur bike ?
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    Default how well do you know ur bike ?
    hi guys lets have a test of your knowledge of not any other bikes but ur own ...below are the things you need to tell us
    Bike Name :
    Model:
    Weight (Dry):
    Tank Capacity:
    Fuel Injection:
    Top speed:
    Transmission:
    Modifications(if any):
    here are my bike's stats
    Bike Name : Kinlon JL-150-2
    Model: 2004
    Weight (Dry): 151 kg
    Tank Capacity:14 liters( 3 liter reserve)
    Fuel Injection:BFI (butterfly fuel injection)
    Top speed:160km
    Transmission:5 speed rotary
    Modifications: recently installed a HONDA CG 150 engine in it...plus new klutch plates...and a gear changing sprocket for faster and smoother shifting
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    rkhnsh's Avatar
    Jun 2005
    Peshawar
    27
    3,787
    SoRry BrO I DONt haV any BiKe
    Toyota AE86 (????) for life...
    Engine on Fire...Intercooler on Rescue..
    Site Banned Follow
    localracer's Avatar
    Jun 2007
    Shan-e-Punjab
    29
    611
    Name: Bajaj Pulsar 180 Dtsi(Digital Twin Spark Ignition) Black
    Model: Aug 2004
    Weight: 139Kg dry
    Tank Capacity: 18 Litres
    Fuel Injection: No Ucal Mikuni BS29 single carb
    Top Speed: 130kmph (True GPS tested) Speedometer shows 145kmph at top speed.
    Transmission: 5 Speed Dry clutch (1 Down 4 Up)
    Modification: UNI Air filter and up jetted.
    Tyres:18 inch rims fr and back.Rear tyre 100/90
    Braking: 240mm disc front and 130mm drum rear
    Maximum Horsepower-16bhp@8000 rpm
    Maximum torque-14Nm@6500 rpm
    Maximum engine speed: 9500 rpm :Idling-1000-1200 rpm
    Ignition: Digital Cdi(with diff. maps for throttle position) with twin NGK spark plugs
    Misc: ExhausTEC(Exhaust Torque Expansion Chamber)-Comapany fitted.
    Over head camshaft.
    Electricals:9Ah Battery,35/35 W headlight
    Enough....................??!!
    humy's Avatar
    Apr 2005
    4,705
    @foosa go look at mine and tell me
    PavementPounder's Avatar
    Feb 2005
    Dubai
    27
    3,566
    all i noe that mines a kawasaki GTO125 n its maroon wid blue sticker
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @ foosa
    I would like to see some pics of your bike please.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @local racer ...i have a different tyre measurement mentioned on my bike's rear tyre...it reads 4-18 ..can it be the same tyre as it is on that bajaj of urs ?
    @humy...its ur bike...u do the honours
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    7thgear
    add me on msn
    scud_pgc@hotmail.com
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Here's the detail of my bikes:
    03 Cg125
    Model: 2003
    Category: Road Bike .
    Engine
    Engine type: Single cylinder 4 Stroke
    Bore and Stroke: 56.5 x 49.5mm
    Compression ratio: 9:1
    Displacement 124cc
    Spark Plug: HERO DP8EA-9
    Ignition system: Electrical CDI system
    Final Drive: Chain
    Starting: Kick Start
    Battery: 12 V-2.5 AH
    Fuse 10A
    Chasis and Suspension
    Trail: 80mm
    Front tire: 2.50-18-4PR
    Rear tire: 3.00-17-6PR
    Power Transmission
    Primary reduction: 4.0555
    Final reduction: 20-.533
    Dry Weight: 96.5 Kg
    Engine Oil: 1 liters
    Fuel tank: 11 liters Reserve: 2 Liters
    Length: 1.900mm
    Width: 730mm
    Height: 1.020mm
    Wheel Base: 1.200mm
    91FZR250R
    Engine Type: 249 cc, 4 Stroke, Liquid Cooled - Inline-4
    Engine Bore and Stroke: 48 mm x 34.5 mm
    Compression Ratio: 12:1
    Valves DOHC, 4 valves/cylinder
    Ignition System: Electronic
    Claimed Horsepower: 45 hp (33.6 kW) @ 16000 rpm
    Maximum Torque: 24.5 Nm (18.1 ft. lbs) @ 12000 rpm
    Type of Lubrication: Wet sump 321.8lbs dry
    Tires: 100/80-17 front, 130/70-18 rear
    Transmission type: 6 speed
    Final Drive: Chain
    Starting: Electronic
    ...........General information.............
    Model: Yamaha FZR 250
    Year: 1991
    Category: Sport
    .........Engine and transmission.........
    Displacement: 249.00 ccm
    Engine type: In-line four
    Stroke: 4
    Power: 45.00 HP (32.8 kW)) @ 14500 RPM
    Torque: 25.00 Nm (2.5 kgf-m or 18.4 ft.lbs) @ 11500 RPM
    Max RPM: 18000
    Compression: 12.0:1
    Bore x stroke: 48.0 x 34.5 mm (1.9 x 1.4 inches)
    Fuel system: Carburettor. MIKUNI BDS26
    Valves per cylinder: 4
    Fuel control: DOHC
    Starter: Electric
    Cooling system: Liquid
    Gearbox: 6-speed
    Transmission type final drive: Chain
    Clutch: Wet plate
    ...............Physical measures.............
    Dry weight: 141.0 kg (310.9 pounds)
    Seat height: 750 mm (29.5 inches) If adjustable, lowest setting.
    Overall height: 1,120 mm (44.1 inches)
    Overall length: 2,010 mm (79.1 inches)
    Overall width: 680 mm (26.8 inches)
    Ground clearance: 135 mm (5.3 inches)
    Wheelbase: 1,375 mm (54.1 inches)
    .........Chassis and dimensions........
    Frame type: Steel
    Rake (fork angle): 25.5°
    Trail: 88 mm (3.5 inches)
    Front tyre dimensions: 100/80-17 52H
    Rear tyre dimensions: 120/80-17 61H
    Front brakes: Double disc. 4-piston calipers
    Front brakes diameter: 320 mm (12.6 inches)
    Rear brakes: Single disk
    Rear brakes diameter: 210 mm (8.3 inches)
    Exhaust system: 4 in to 1 with EXUP valve
    .............Speed and acceleration..........
    Top speed: 190.0 km/h -- (Red line 18.5k, maximum of 20k)
    Power/weight ratio: 0.3191 HP/kg
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    yaar 7thgear bhai ye bayimaani...copy paste to koi bhi maar lay...i created this topic to find out the info the owners have themselves
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Ah...
    Yes I found this info from the net. Oops, sorry.
  12. #12
    adil_dar's Avatar
    Nov 2006
    Gujranwala
    40
    745
    9 Post(s)
    Bike Name : Honda CD 100
    Model: 2006
    Weight (Dry): 98 KGs
    Tank Capacity: 12ltrs
    Fuel Injection: None (its got simple conventional carb)
    Top speed: 98 (max i did, could have touched 100 or 105)
    Transmission: 4 Gears (constant mesh as they call it but never understood this thing)
    Modifications(if any): None (but planning to change its headlight current light is worth nothing) its origional headlight is 12/35 i think coz of its mutireflector beam its light doesnt focus accurately like cd 70 does, any suggestions from your guys? specially foosa.
    (i love pakistan)
    adil_dar@hotmail.com
  13. #13
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Suzuki GP 100
    1984
    85 Kgs
    5 litres?? no idea:s
    Carby
    115 personally verified. Was still pulling a bit. 125 maybe?
    5 speed constant mesh.
    Lowered (dead :p) suspension, deep blue metallic paint, CG125 gauge cluster, Yamaha 100 headlight (in short, it's been molested). Engine rebuilt 5,000 kms ago. New muffler, new brakes. Pulls like a train after 6000 rpm, like a CD70 below... very very sensitive to tuning. 15 HP from the factory.
    Cheers!
    Sami
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  14. #14
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    sami...got a pic of it ?
  15. #15
    Site Banned Follow
    localracer's Avatar
    Jun 2007
    Shan-e-Punjab
    29
    611
    @foosa-Probably that means that ur bike got 18in rims.100/90 on my bike means that my rear tire is 100 mm(?) wide and has a side wall of 90.(profile)
  16. #16
    Sep 2004
    35
    3,701
    8 Post(s)
    @foosa
    Unfortunately the registration papers are lost, so it stands in the porch doing double duty as a stool for my stupid cats. I'll ask my brother to snap a pic and send me one! Ill posst it ASAP. In the meantime, enjoy this link:
    http://youtube.com/watch?v=tMVALT3hIis&feature=dir
    Cheers!
    Sami
  17. #17
    BHAILOGE's Avatar
    Oct 2005
    30
    2,331
    2 Post(s)
    H o n d a C G 1 2 5
    2 0 0 4
    may be110
    8liters+2liters reserve
    CDI
    120km/h Full meter
    4speed manual
    change the tanki,tapes,
    removes indictors,meter,mirros
    how well do you know ur bike ? -763855
    BReady GReddy I'm the way. //TRD wheels are burning all night & day��..
    "life begins at 8000rpms" - Blacktop 20v
  18. #18
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @BHAILOG
    thats a nice bike...but removing indicaters and mirrors are dangerous...wouldnt recommend that (Y)
  19. #19
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @localracer
    yea the rims are 18 inches...but wats that 4 ??? i cant figure it out..damned chinese producers......i need a rear tyre for my bike BAD
  20. #20
    BHAILOGE's Avatar
    Oct 2005
    30
    2,331
    2 Post(s)
    @foosa
    @BHAILOG
    removing they are broken going pindi cycle come into so removing them.........well dangrous never thing about sitting on bike just read ayat ul quersey and then go........whats happens ALLAH knows well........................
