Results 1 to 19 of 19
Thread: Hey guys what is this? Suzuki FXR 150
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    Default Hey guys what is this? Suzuki FXR 150
    I was searching Yamaha FZR 250 and found this bike. Looking very very nice. Does anybody have futher knowledge of this bike???
    jiyo aur jeenay do
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i heard and know about suzuki TXR 150...but never FXR 150 here is a pic of suzuki TXR 150 which was launched in malaysia only
    Hey guys what is this? Suzuki FXR 150 -774700
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    Born2Race's Avatar
    Jun 2006
    23
    10,107
    5 Post(s)
    itna sa silencer?
    Thy name's 'Fahad'. Powered by D16™​.
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    here are the pics
    Hey guys what is this? Suzuki FXR 150 -774701
    Hey guys what is this? Suzuki FXR 150 -774702
    Hey guys what is this? Suzuki FXR 150 -774703
    Hey guys what is this? Suzuki FXR 150 -774704
    Hey guys what is this? Suzuki FXR 150 -774705
    jiyo aur jeenay do
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    I can provide you with the link
    http://images.google.com.pk/imgres?imgurl=http://w1.bikepics.com/pics/2003%255C08%255C29%255Cbikepics-63781-320.jpg&imgrefurl=http://www.bikepics.com/suzuki/fxr150/&h=269&w=320&sz=23&hl=en&start=18&um=1&tbnid=-h9gZLjTwsDjaM:&tbnh=99&tbnw=118&prev=/images%3Fq%3DSuzuki%2BFXR%2B150%26svnum%3D10%26um% 3D1%26hl%3Den%26sa%3DG
    jiyo aur jeenay do
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    Blue one in the first pic is looking coooool
    jiyo aur jeenay do
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    more pics
    Hey guys what is this? Suzuki FXR 150 -774706
    Hey guys what is this? Suzuki FXR 150 -774707
    Hey guys what is this? Suzuki FXR 150 -774708
    jiyo aur jeenay do
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    this bike is Malaysian
    jiyo aur jeenay do
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    FXR150
    Capacity 147 cm³
    Cylinders 1
    Engine combo air/oil cooled DOHC 4 stroke
    Power almost 20 PS (15 kW)
    Weight 118 kg dry
    Drive chain
    Fuel Economy 60mpg
    Specifications
    Dimensions and dry mass
    Overall length 1985 mm (78.1 in)
    Overall width 665 mm (26.2 in)
    Overall height 1095 mm (43.1 in)
    Wheelbase 1325 mm (52.2 in)
    Ground clearance 160 mm (6.3 in)
    Dry mass 118kg (260 lbs)
    Engine
    Type Four-stroke, oil cooled, DOHC, TSCC
    Number of cylinder 1
    Bore 62.0 mm (2.441 in)
    Stroke 48.8 mm (1.921 in)
    Displacement 147 cm³ (8.99 cu. in)
    Corrected compression ratio 10.7:1
    Carburetor MIKUNI BS29
    Air cleaner Polyurethane foam element
    Starter system Electric and Kick
    Lubrication system Wet sump
    Transmission
    Clutch Wet multi-plate type
    Transmission 6-speed constant mesh
    Gearshift pattern 1 down 5 up
    Primary reduction ratio 3.500 (70/20)
    Final reduction ratio 3.428 (48/14)
    Gear ratios, Low 3.000 (33/11)
    2nd 1.857 (26/14)
    3rd 1.368 (26/19)
    4th 1.095 (23/21)
    5th 0.923 (24/26)
    Top 0.800 (20/25)
    Drive chain RK428HO, 132 links
    Chassis
    Front suspension Telescopic, coil spring, oil damped
    Rear suspension Swinging arm, coil spring, oil damped, spring pre-loaded 4-way adjustable
    Steering angle 35º (right and left)
    Caster 24º
    Trail 85 mm (3.35 in)
    Turning radius 2.6m (8.5 ft)
    Front brake Disk brake
    Rear brake Disk brake
    Front tire size 80/90 17 44S, tube
    Rear tire size 100/90-17 55S, tube
    Electrical
    Ignition type Electronic ignition (CDI)
    Ignition timing 9º B.T.D.C. at 1500 r/min
    Spark plug NGK CR8E or DENSO U24ESR-N
    Battery 12V 14.4 kC (4Ah)/10 HR
    Generator Flywheel magneto
    Fuse 20A
    Headlight 12V 25/25W x 2
    Turn signal light 12V 10W
    Brake light/taillight 12V 18/5W
    Speedometer light 12V 1.7W x 2
    Turn signal indicator light 12V 1.7W x 2
    Neutral indicator light 12V 1.7W
    High beam indicator light 12V 1.7W
    Capacities
    Fuel tank including reserve 15.0 L (4.0/3.2 US/lmp gal)
    reserve 3.4 L (0.9/0.8 US/lmp gal)
    Engine oil, without filter change 1000 ml (1.1/0.9 US/lmp qt)
    with filter change 1100ml (1.2/1.0 US/lmp qt)
    with overhaul 1300 ml (1.4/1.2 US/lmp qt)
    jiyo aur jeenay do
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    according to research i did ...its a 2 stroke 150cc ...which was released only in malaysia...very lil info is available
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    yar its 4 stroke, not 2
    but jo b hai cool bike hai
    Hey guys what is this? Suzuki FXR 150 -774711
    jiyo aur jeenay do
  12. #12
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    foosa bhai yeh display pic kaisay lagatay hain?
    jiyo aur jeenay do
  13. #13
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    I tell you one thing, i rode a Honda CBR 150 (Brand New) , better looking then this one, had a bad drive ! not impressed at all, when it starts the Single Cylinder cant do justice with that sport exhaust, the sound is bad, the ride is bad, better buy a normal honda 125, its far better
  14. #14
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    @us000, on top of this page, there's
    "You are signed in as us000"
    on top of it there is :
    Forum Links : Profile - Search - Members Directory - Top Posters - Subscriptions
    Click Profile and then you can upload your avator
  15. #15
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @us...i was talking about the TXR...i think FXR is a 4 stroke upgrade
  16. #16
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    yhanks c123k and fosa for providing info. No doubt, I have seen CBR 150 in ma university and i found it scrap.
    jiyo aur jeenay do
  17. #17
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    I havnt any experince of single cylinder Super bike but have experince of the Yamaha FZR 150 (V-Twin) its very nice bike in 150CC category.
    BTW Suzuki FXR 150 is looking good (Y) & if its realy produces 20 PS out put then it will be like Hawk on road.
    Exploring Machines is my Passion...
  18. #18
    Site Banned Follow
    localracer's Avatar
    Jun 2007
    Shan-e-Punjab
    29
    611
    20Ps and 118kg.This thing will fly!!
  19. #19
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    As you have mentioned it yourself, its not a Japanese original. Looks are not bad at all, I wonder what Suzuki will do if they come to know of it...
    A particular Korean brand started producing its bike in Korea under the name Yamuda last year. Their 125cc bikes were in the colour scheme and style like those of the Big Four. Suzuki was the first one to challange their production with that colour scheme...I'll post pics of those bikes soon..
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
