Results 1 to 6 of 6
Thread: Bike Customization Help Needed
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    Default Bike Customization Help Needed
    I want to know from all you knowledgeable guys that if want to change my suzuki sprinter's rims with alloy rims how much it will cost me and where can I find it ? I think that suzuki SD also has alloy rims so can I use them on my bike? Also do I have to change my tires too? Any help will be appreciated.
    SPeEd ThRiLls
    Alone_Munda's Avatar
    Oct 2006
    Multan
    32
    255
    Well...three to four thousands for rims...plus two to three thousands for front disk (complete set)
    these prices are for original japaness rims which was installed in SD110 (which u mentioned in ur question)..
    such rims will perhaps available easily from special tyres and rims shops instead of suzuki showroom..lolz..
    ALLAH is my best friend...!!!
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    can I use drum brakes with alloy rims?
    SPeEd ThRiLls
    Oct 2006
    Multan
    32
    255
    yaar...if u want to put those particular japness rims..than u can use drum brake in rear wheel... , because fron allow rim is not such hub to carry drum brak....here are snaps of those rims...you can see the difrent shap of front rims....
    there is not place to put drum brake in fron rim..
    Bike Customization Help Needed -777119
    Bike Customization Help Needed -777120
    Oct 2006
    Multan
    32
    255
    some differnt kina rims which r used in some local chines bikes....(i forget the name, but perhaps 70cc LIFEN...) that bike also have such rims...but not worth seeing and gud looking...but very light weight than japinees black rims...
    these rims are with drums brakes....and definently low cost..
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    Humm...so a search might be needed to reveal some other options as well....but thanks for your views anyways
    SPeEd ThRiLls
