Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Fork oil suggestions??
    jamaal's Avatar
    Nov 2003
    48
    178
    Default Fork oil suggestions??
    Need to know references on fork oils available in Karachi.
    Auto trans fluid as per some tech gurus makes the oil seals swell and break.
    Looking for 5w20
    Thanks
  2. #21
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @bike_junky
    If u are sure that subject ATF is of 20w than i would prefer it on shell advance 2T as the Two stroke lubricants are more tends for efficient burning instead of bearing continous varying preseure while in case of ATF atleast it can beare more presure build inside suspension than of 2T oil.
    Exploring Machines is my Passion...
  3. #22
    bike_junky's Avatar
    Feb 2008
    766
    17 Post(s)
    Thnaks Imran bhai!
    I never thought of it that way. Previously it has happened twice that the mechanic used ordinary oil and that was really thick oil and the bike was very bumpy.
    As regards my search Mobil 1 synthetic ATF is 7.5wt and ppl use dexron and Mobil 1 as ATF due to their light weight. Fork oil is really expensive as compared to ATF in foreign countries.
    I already poured warco ATF in my bike forks, but didn't felt a lot of difference in damping. I think either springs are hard and not compressing on jerks, or still the used fork oil is thick.
    I will look for some thinner oil from some car shock repairer and will also change ball bearings (golian) in under handle bar joint, that also make thak thak noise on jerks.
    Would you please tell what else can go wrong in addition to springs and oil for shock softness and how to check.
    I mean bushes or some thing else.
  4. #23
    ak666666's Avatar
    Jun 2008
    50
    83
    Which oil can I use in my cd70 front shocks? What weight?
