Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: confession corner
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    Default confession corner
    everyone knows that nobody is perfect...and neither is their machine...so in this thread you have to point out at least 2 problems about ur bike...common dont be shy..i'll start with mine
    BIKE: Modified 150cc Sports
    1. it has one of the worst power to weight ratio
    2. rear brake is horrible...
    3. light positioning is horrible...i cant see beyond 6-8 meters at night
    well those are about it...
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    Bilaltq's Avatar
    Mar 2004
    Select City
    26
    10,311
    10 Post(s)
    Refrain from posting off-topic replies [Mod Edit]
    This comment was made by a person with a tested IQ of negative 9.
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    Well I have spent just 3 months with my black sprinter and found only one problem with it.
    THE ROCK SOLID HARD SEAT
    SPeEd ThRiLls
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    my DELUXE is only 3 months old,
    for the last 2,3 days, i am issuing this stupid problem that the key is hard to insert into the IGNITION switch.
    i actually have to push it very hard now, and even that doesn't work at times, so i take the halfly inserted key out, try to insert it again.. which is a pain in the a** :-(
    anyway to get it fixed.
    will they fix it, as my bike is still within warranty. and if yes, do i need to take my bike back to the showroom i bought it from?
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @abbasjin
    I think u just needs to spray WD40 in the lock & will be smooth.
    Exploring Machines is my Passion...
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Not a bad idea for another nice thread..
    Well heres' about my bikes..
    For FZR..
    1. My FZR (being an old model) is too heavy for a 250.
    2. The front forks will need some attention soon, new fork oil and perhaps new seals too.
    3. Battery is bit weak but I am being lazy.(Here the problem is with me I guess :-))
    For CG125..
    1. I hate its front brake. Ever since I have purchased it I have never been able to get it the way I wanted, the lever gets so stiff if you tighten the brake.
    Thats all that is..
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    also, as a confession and question, my bike's engine turns off if i keep it idle without any reving at signal/stops etc.
    is this due to the cold weather? or what? i hate kick starting the bike again while in the middle of a traffic queue.
    the turning-off issue rose after the 2nd tunning.
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    the turning-off issue rose after the 2nd tunning. i know the bike's engine turns off if its cold and u dont rev it much after starting, but when the engine's hot and everything's ok, why does it turn off by itself?
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    well thats a common one abbas...when the engine is cold...it turns off if not given a lil throttle continously...and ur solution is that keep the engine running for at least 3-5 mins before taking it out..keep giving it some throttle until you hear a continous GRRRRRRR sound from the engine instead of GR GR GR GR GR
    fawi's Avatar
    Jan 2006
    Hyderabad
    26
    3,537
    27 Post(s)
    2 Thread(s)
    i bought a new 70cc bike 4 year back! and now it seems like the bike of DHOODH WALA :d
    HUN TAI DOODH WALAI DI MOTORCYCLE JAIFJI HO GAYI HAI :d tai main ki ki dassaan! :d na hi pocho tai changa hai (READ IN PUNJABI)*
    People who are considered Mad by the world are the only ones who make a Difference. e X t r e m i s t "pro-Extremism" War Till Death
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    tay ki hoya jay tuadi CAINCLE MOTOR doodh malai wargi haygi..kuch tay saanoun wi daso ...punjabi is like my 4th language ...so ignore any mistakes
  12. #12
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    foosa, u didn't say anyting my bike's ignitition switch issue, where the key bocomes stupid to insert into the ignition, i've chedk the 2nd key, the issue is in ignition.
    also my bike turn off at home when its cold, its ok.
    but when i've covered like 10 kilometer with it, and when i suppose its OK to leave it running idle without revving it much, while waiting on a signal in queue. it still turns off at time :-/ is the petrol from tank to engien decreased or what?
    my bike is giving me 41.5 KMs SOLID for 1 Litre
  13. #13
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Abbas I think your problem is low rpms. Increase the idle rpm of the bike from the cable that extends from the throttle and your problem should be solved.
  14. #14
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @ABBAS
    i dont wanna say anything about that......say thanx to brilliant honda engineering
    and as 7th said...the problem can also be solved by increasing rpms from the wire/page connected to throttle wire
  15. #15
    AbbasJin's Avatar
    Aug 2007
    Rawalpindi
    30
    376
    will increasing the rpm affect MILEAGE? (decrease??)
    or the bike in other way?
  16. #16
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i dont think that should have a major effect on the mileage...contact ur bike mechanic and ask him to increase the rpms to at least 1.5...i keep mine at 2
  17. #17
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    I am having the same prob as Abbas's. my sprinter's engine also often turns off at traffic signals I suspect there could be something else wrong with our bikes instead of just idle RPM speed becoz I tried to increase idle RPM speed but it seems to have no effect
    SPeEd ThRiLls
  18. #18
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    hmmmmm ... well dat doesnt make sense...coz cold and low rpms are the major cause of this problem...and generally heating the engine up and increasing the rpms solve the problem...another problem could be the fuel line...some dust or other material might be blocking the fuel supply to the engine hence shutting it down..
  19. #19
    hasan4u's Avatar
    Sep 2007
    Rawalpindi
    35
    127
    Humm this could be the problem as we had very dry weather BTW that what is the best lubrication for the drive chain and at what frequency?
    SPeEd ThRiLls
  20. #20
    Site Banned Follow
    localracer's Avatar
    Jun 2007
    Shan-e-Punjab
    29
    611
    Oye chhad yaar apan tan BUSA lena,jadon sasta ho jave ga..
