Results 1 to 8 of 8
Thread: 08 Fireblade
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Default 08 Fireblade
    08 Fireblade - Fireblade
    08 Fireblade - Fireblade1
    What are your views?
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i see the kawasaki effect in those front lites ...cant make the rest of it from those angles...have they finally made it less bulky ?
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Kawasaki never made that cool light.
    Yes the new model is lighter, quicker but maybe just maybe a bit less attractive (in my view).
    chauhdarywaqar's Avatar
    Jul 2006
    27
    3,569
    Shiny.*-)
    Info.
    Honda CBR 1000RR Fireblade
    An all new CBR1000RR was introduced at the Paris International Motorcycle Show on 28 September, 2007 for the 2008 model year. The CBR1000RR is powered by an all new 999 cc (60.9 cu in) inline-four engine with a redline of 13,000 rpm. It features titanium valves and an enlarged bore with a corresponding reduced stroke. The engine has a completely new cyinder block, head configuration, and crankcase with lighter pistons. A new ECU delivers two separate revised maps sending the fuel and air mixture to be squeezed tight by the 12.3:1 compression ratio. Ram air is fed to an enlarged air box through two revised front scoops located under the headlamps. Honda claims power output to be at least 178 hp (133 kW) beginning at 12,000 rpm.
    Honda made a very focused effort to reduce and centralize overall weight. A lighter, narrower die cast frame was formed using a new technique which Honda claims allows for very thin wall construction and only four castings to be welded together. Almost every part of the new bike was reengineered to reduce weight including the sidestand, front brake hoses, brake rotors, battery, and wheels.
    In order to improve stability under deceleration, a slipper clutch is now available with a unique center-cam-assist mechanism. The Honda Electronic Steering Damper (HESD) has been revised this year as well. Another significant change is the exhaust system which is no longer a center-up underseat design. The CBR1000RR now features a side slung exhaust in order to increase mass centralization and compactness while mimicking a Moto GP style.
    For the 2008 model year, the CBR1000RR competes with the Suzuki GSXR1000, the Yamaha YZF-R1, the Kawasaki Ninja ZX-10R, and the Ducati 1098.
    08 Fireblade -793281
    08 Fireblade -793282
    It's not who you are to the world, it's who you are to me. It's not how many times I say I love you... it's how much I really do.
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    accept it man..kawasaki zx series has those lights ...now honda is starting to take hints from the kawasaki guys ...soon the BUSA will start to like a zx-12r (6)
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    But the Busa would still be my first choice and I still boom past you while you would have hardly shifted into the 2nd gear
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    now now...thy shall not test thee kawasaki's temper
    fawi's Avatar
    Jan 2006
    Hyderabad
    26
    3,537
    27 Post(s)
    2 Thread(s)
    thats hot!
    People who are considered Mad by the world are the only ones who make a Difference. e X t r e m i s t "pro-Extremism" War Till Death
