Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: 2008 Kawasaki Ninja ZX-14
    chauhdarywaqar's Avatar
    Jul 2006
    27
    3,569
    Default 2008 Kawasaki Ninja ZX-14
    2008 Kawasaki Ninja ZX-14 -530188
    Every champion knows sustained dominance is only possible with constant improvement. Such is the case with Kawasaki’s Ninja® ZX™-14. Since its debut in March of 2006, this motorcycle has ruled the open class sportbike roost with nearly non-stop magazine comparison victories. Even though the 1,352-cubic-centimeter Ninja ZX-14 won lavish praise for its massive torque, effortless power, agile handling and comfortable ergonomics, Kawasaki engineers were not willing to leave the door open to potential challengers.
    The 2008 ZX-14 retains all the great features that made it a legend, plus more bottom-, mid- and top-end power. Changes to the engine and exhaust system allow it to comply with strict Euro-III emissions and tightening noise regulations. To meet noise standards, the engineers focused on reducing internal mechanical noise instead of muzzling the exhaust system. The result wasn’t a power loss, but an overall improvement of the engine character and an actual increase in the ZX-14’s legendary peak power! Yes, you read that correctly. Emissions and noise levels are lower, peak power is higher, the mid-range hit is stronger and smoother and low-end torque has been increased.
    2008 Kawasaki Ninja ZX-14 -530189
    GENERAL INFORMATION
    Manufacturer: Kawasaki
    Model Year: 2008
    Model: Ninja® ZX™-14
    Price: *$11,699.00
    ENGINE
    Engine: 4-stroke, liquid-cooled, DOHC, 4-valves per cylinder, inline-4
    Displacement: 1,352 cc
    Bore x Stroke: 84 x 61 mm
    Torque: 113.5 ft. lbs. (154 Nm) @ 7,500 rpm
    Compression Ratio: 12.0:1
    Carburetion: DFI® with Mikuni 44 mm throttle bodies (4)
    Ignition: TCBI with digital advance
    DIMENSIONS
    Length: 85.4 in.
    Width: 29.9 in.
    Height: 46.1 in.
    Weight: 485 lbs.
    Wheelbase: 57.5 in.
    Fuel Capacity: 5.8 gal.
    Seat Height: 31.5 in.
    DRIVETRAIN
    Transmission: 6-speed
    Final Drive: X-ring chain
    Suspension
    Front: 43 mm inverted cartridge fork with adjustable preload, stepless rebound and compression damping adjustments; 4.6 in. travel
    Rear: Bottom-link Uni-Trak® and gas-charged shock with adjustable preload, stepless rebound and compression damping adjustments, adjustable ride height; 4.8 in. travel
    BRAKES/WHEELS/TIRES
    Brakes:
    Front: Dual semi-floating 310 mm petal discs with dual radial-mounted 4-piston calipers
    Rear: Single 250 mm petal disc with 2-piston caliper
    Tires:
    Front: 120/70 ZR17
    Rear: 190/50 ZR17
    Rake: 23°
    Trail: 3.7 in. (94 mm)
    2008 Kawasaki Ninja ZX-14 -530190
    It's not who you are to the world, it's who you are to me. It's not how many times I say I love you... it's how much I really do.
  2. #21
    Jul 2006
    27
    3,569
    A must read article ZX-14 VS. Hayabusa. I read the whole thing & Was really happy with the results.
    http://www.motorcycle-usa.com/Articl...ArticleID=3504
  3. #22
    Jul 2006
    27
    3,569
    Take a look at this. ZX-14 VS. Hayabusa.
    2008 Kawasaki Ninja ZX-14 -795560
    Source: www.motorcycleusa.com
  4. #23
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    simply amazing (L)...
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
