Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 43
Thread: My Type Bike...Whats Yours?
    nak
    nak is offline
    nak's Avatar
    May 2006
    Peshawar
    86
    3,521
    Default My Type Bike...Whats Yours?
    This is the bike which I'm dying to get a hold on..InshAllah will buy this bike and take a road trip all around Australia..Its a Yamaha Midnight Warrior..share yours too, I mean fantasies :p
    My Type BikeWhats Yours? -530786
    My Type BikeWhats Yours? -530787
    My Type BikeWhats Yours? -530788
    My Type BikeWhats Yours? -530789
    My Type BikeWhats Yours? -530790
    Engine
    Type 102-cubic-inch (1670cc) air-cooled 48° V-twin; pushrod OHV, 4 valves/cylinder
    Bore x Stroke 97mm x 113mm
    Compression Ratio 8.36:1
    Carburetion Twin-Bore electronic fuel injection; throttle position sensor
    Ignition TCI
    Transmission 5-speed close-ratio; multiplate wet clutch
    Final Drive Belt
    Chassis
    Frame Aluminum monoshock
    Suspension/Front 41mm KYB inverted fork; 5.3-in travel
    Suspension/Rear Single shock; adjustable preload and rebound damping, 4.3-in travel
    Brakes/Front Dual hydraulic disc, 298mm
    Brakes/Rear Hydraulic disc, 282mm
    Tires/Front 120/70-ZR18 Radial
    Tires/Rear 200/50-ZR17 Radial
    Wheels 5-spoke cast
    Dimensions
    Length 93.9 in
    Width 36.8 in
    Height 44.1 in
    Seat Height 28.1 in
    Ground Clearance 6.1 in
    Wheelbase 65.6 in
    Dry Weight 612 lb
    Fuel Capacity 4.0 gal
    http://www.pro-pakistan.com/
    ________________________________________________________________________________________________________________________
    Nearly all men can stand adversity, but if you want to test a man's character, give him power...(Abraham Lincoln)
  2. #21
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @nak,7thgear
    So wat is the best recomended age to ride a sports bike :O
    Exploring Machines is my Passion...
  3. #22
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^starting age or ending age?
    A kid having license can start with a 125cc or a 250cc, there is no limit for upper age, at least till 60.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  4. #23
    born_2b_wild's Avatar
    Jul 2006
    5,339
    33 Post(s)
    HARLEY DAVIDSON ..
    My Type BikeWhats Yours? -797331
    Live To Ride ..... Ride To Live
    https://www.facebook.com/seeyouinmyrearviewmirror
  5. #24
    CarAddict's Avatar
    Sep 2006
    35
    452
    Well this is what i want
    My Type BikeWhats Yours? -797335
    Allah he Allah kiya karo, dukh na kissi ko diya karo. Sub ko achay replies kiya karo
  6. #25
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    ^^...with reference to ur ID...ur not supposed to be in the bikes sexion ..J/K...i see u are intrested in V-RODs..seen any in pakistan lately ?
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
  7. #26
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @caraddict
    V Rod is a monster man, you'd be the coolest of dudes to ride that in Pakistan..
  8. #27
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    I wana be King wid B King
    My Type BikeWhats Yours? -798100
    My Type BikeWhats Yours? -798101
    My Type BikeWhats Yours? -798102
    Check Details
    http://www.suzukicycles.com/Products...8/Default.aspx
    Specs
    Engine: 1340cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
    Bore Stroke: 81.0 x 65.0mm
    Compression Ratio: 12.5:1
    Fuel System: Fuel Injection
    Lubrication: Wet sump
    Ignition: Digital/Transistorized
    Transmission: 6-speed, constant mesh
    Final Drive: #530 chain
    Overall Length: 2160mm (85.0 in.)
    Overall Width: 810mm (35.2 in.)
    Overall Height: 1040mm (40.9 in.)
    Seat Height: 815mm (32.1 in.)
    Ground Clearance: 110mm (4.3 in.)
    Wheelbase: 1515mm (59.6 in.)
    Dry Weight: 235 kg (518 lbs.)
    Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, adjustable rebound damping and adjustable compression damping
    Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, adjustable compression & rebound damping
    Brakes Front: Dual hydraulic disc
    Brakes Rear: Single hydraulic disc
    Tires Front: 120/70-ZR-17
    Tires Rear: 200/50-ZR-17
    Fuel Tank Capacity: 16.5 liter (4.2 gal)
    Color: Gray/Silver, Black/Matte Black
  9. #28
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Never heard of it, its such a monster.
  10. #29
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @7thgear
    Its new entry & is claimed to be most fastest & power full production bike in naked/Street category.
  11. #30
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    that b-king thing is a killer ...good job suzuki (Y)
  12. #31
    Hamie's Avatar
    Jan 2008
    41
    37
    Honda CD-70 is also a cool bike if u know what i mean...
  13. #32
    salman_ksa's Avatar
    May 2006
    Ad-Dammam
    27
    9,331
    I always liked naked bikes Specially Triumph Speed Triple(y)
    My Type BikeWhats Yours? -799463
  14. #33
    Atif1350's Avatar
    Oct 2007
    27
    hi guz can u tell me hoe 2 add pics to da topic ,i also want 2 share ma ride.
  15. #34
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @Atif1350
    Click to Reply Post link on right bottom of page (as u already did) the reply page will be appear here u can find the link for attachement on left bottom side of text box click that link & browse to pick required picture from ur system then submit.
  16. #35
    nak
    nak is offline
    nak's Avatar
    May 2006
    Peshawar
    86
    3,521
    @imranbhatti
    I'm not a big fan of covered/kitted bikes a.k.a sports bikes, I'm more of a street/naked bike guy...
    Here you go, my new love affair!! The all new 2009 Yamaha VMAX
    Engine-Type 1679cc liquid-cooled 65° V-4, DOHC, 4 valves/cylinder...produces ~200bhp
    My Type BikeWhats Yours? -856035
    My Type BikeWhats Yours? -856036
    My Type BikeWhats Yours? -856037
    My Type BikeWhats Yours? -856038
    My Type BikeWhats Yours? -856039
    My Type BikeWhats Yours? -856040
    My Type BikeWhats Yours? -856041
    My Type BikeWhats Yours? -856042
    My Type BikeWhats Yours? -856043
    My Type BikeWhats Yours? -856044
    My Type BikeWhats Yours? -856045
    My Type BikeWhats Yours? -856046
    My Type BikeWhats Yours? -856047
  17. #36
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @nak
    Its true beast.
  18. #37
    adil_dar's Avatar
    Nov 2006
    Gujranwala
    40
    745
    9 Post(s)
    O Allah Almighty
    please give me courage to bear the gas expenses of my beloved ride,,,,, Ameen
    My Type BikeWhats Yours? -856105
    My Type BikeWhats Yours? -856106
    do i need to give the specs of this bike?
    (i love pakistan)
    adil_dar@hotmail.com
  19. #38
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @adil_dar
    No need to mention the specs of this bike as we already know the slogan "Aik litre me 80 Km se bhi zayada chale"
    BTW have u bought this ?
  20. #39
    adil_dar's Avatar
    Nov 2006
    Gujranwala
    40
    745
    9 Post(s)
    bhatti sb
    didnt need to buy, this one is owned by younger brother. guess what, had to sale my CD 100 to keep the budget in limits
    when i see the desires of you people i hate my self and all internal combustion engines that depend on petrol.
    (i love pakistan)
  21. #40
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    east or west
    beast or rest
    dar is the best\
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
