Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: My Type Bike...Whats Yours?
    nak
    nak is offline
    nak's Avatar
    May 2006
    Peshawar
    86
    3,521
    Default My Type Bike...Whats Yours?
    This is the bike which I'm dying to get a hold on..InshAllah will buy this bike and take a road trip all around Australia..Its a Yamaha Midnight Warrior..share yours too, I mean fantasies :p
    My Type BikeWhats Yours? -530786
    My Type BikeWhats Yours? -530787
    My Type BikeWhats Yours? -530788
    My Type BikeWhats Yours? -530789
    My Type BikeWhats Yours? -530790
    Engine
    Type 102-cubic-inch (1670cc) air-cooled 48° V-twin; pushrod OHV, 4 valves/cylinder
    Bore x Stroke 97mm x 113mm
    Compression Ratio 8.36:1
    Carburetion Twin-Bore electronic fuel injection; throttle position sensor
    Ignition TCI
    Transmission 5-speed close-ratio; multiplate wet clutch
    Final Drive Belt
    Chassis
    Frame Aluminum monoshock
    Suspension/Front 41mm KYB inverted fork; 5.3-in travel
    Suspension/Rear Single shock; adjustable preload and rebound damping, 4.3-in travel
    Brakes/Front Dual hydraulic disc, 298mm
    Brakes/Rear Hydraulic disc, 282mm
    Tires/Front 120/70-ZR18 Radial
    Tires/Rear 200/50-ZR17 Radial
    Wheels 5-spoke cast
    Dimensions
    Length 93.9 in
    Width 36.8 in
    Height 44.1 in
    Seat Height 28.1 in
    Ground Clearance 6.1 in
    Wheelbase 65.6 in
    Dry Weight 612 lb
    Fuel Capacity 4.0 gal
    http://www.pro-pakistan.com/
    ________________________________________________________________________________________________________________________
    Nearly all men can stand adversity, but if you want to test a man's character, give him power...(Abraham Lincoln)
  2. #41
    BMW7Series's Avatar
    Feb 2006
    22
    8,951
    i luv 2008 SUZUKI HAYABUSA.......
    Maa Da Laddlaa Vigar Gaya.... Chevy Aveo Ly K Nikal Gaya.
  3. #42
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @adil_dar
    Its only desire & its not nessacery that all desires come true how ever as far current fuel prices are concern i no doubt its very dificult to afford fuel for CD 70
    Exploring Machines is my Passion...
  4. #43
    ezaz's Avatar
    Apr 2008
    Peshawar
    36
    87
    @nak
    Well well, it is merely the AGE bro, it's the ATTITUDE that drives one to opt for a kind of ride.
    Still this is wot i may live anothr life for.
    My Type BikeWhats Yours? -856410
    My Type BikeWhats Yours? -856411
    My Type BikeWhats Yours? -856412
    My Type BikeWhats Yours? -856413
    My Type BikeWhats Yours? -856414
    Therez something about a hot engine between my legs that calms me down or I'll die with a HARD ON.
