Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Suzuki 400cc Engine heating
    kittu99's Avatar
    Aug 2006
    38
    189
    Default Suzuki 400cc Engine heating
    My friend has a suzuki 400cc. He hadnt used it for quite a while now. Recently we took it out for a ride. The bike runs great but heats up after a while if we exceed 60kms/hr. The engine of the bike is perfect. Could anyone suggest what the problem might be?
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    a gsxr 400 ?
    a gs 400 ?
    a gsx across 400 ?
    a gsx 400 ?
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    deadly's Avatar
    Mar 2006
    30
    260
    @ KIttu
    Well,if its Water Cooled Service Your radiator If still problem Occurs Gasket mai problem ho sakty hai !
    If The Desert Could Speak ... It Would BEG for MERCY. [ J E E P ].
    f_alik's Avatar
    Apr 2008
    32
    61
    @kittu
    well like @deadly mention servicing the radiator might solve ur frd`s prb, but there is one more thing, do ur frd have to fill up the radiator each n every time b4 riding the bike ?? if it is then the possible cause will b the damage of seating area of the radiator cap, check that out may b it`s not sealing and the water is leak off from the expasion bottle. OR check the RPM of the cooling fan, cuzz sumtimes the fan is running but not on sufficient RPM to cool the water in the radiator. and abt the head gasket !! ask ur frd to cold start the bike and remove the radiator cap and give race, if ur frd sees water bubbles coming out from the radiator then gasket may b faulty elsewise u dun need to go for the gasket
    rest @foosa can help u quite better.
    No Expectations !!! No Disappointments !!!
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i dont even know if his bike is with radiator or without it
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    -Service the Radiator.
    -Make the Fan direct.
    These bikes heat up when they are old.
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    what if doesnt have a radiator ...like the gsx 400 ...thats why i asked whether its a one with radiator or without it
    deadly's Avatar
    Mar 2006
    30
    260
    @ Foosa
    Bro,If it Doesnt Have a Radiator Then Change gasket
    @ Kittu
    Agar Phir Bhi Problem Occurs Then Engine KHulwao Check Krang Agar Crack Hua There U Got it
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I think his bike has the liquid cooled engine thats why this is happening.
    If the bike has the liquid cooled engine, of course one reason can be the leaking gasket. Check for it.
    Secondly, you should see if there is coolant in the radiator. If you have the coolant overflow problem then go buy a new radiator cap. Also check that the radiator reservoir is properly sealed with the cap. Does this help?
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Same old questions,
    1) Which Bike?
    2) Air cooled or Water cooled?
    3) Position of temp Guage when heated up?
    4) If water cooled then is it reducing water/coolant?
    Exploring Machines is my Passion...
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Bhatti B-) gooda gooda
    Keep a cool head and wear seatbelts!
  12. #12
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @imran bhai...
    SIGH!
  13. #13
    kittu99's Avatar
    Aug 2006
    38
    189
    i am so sorry guys i wasnt able to check the replies. Its a water cooled bike. The radiator is all clean cuz i got it checked and there were some leakages and i got em fixed. One mechanic told me its because of the gaskit. Can the gaskit be arranged? 2nd some one told it might be cause of the current problem.. I am in lahore with the bike. Experts now give ur suggestions.. Thanks a lot to ALl the pak wheelers.
  14. #14
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Is there any mixing of oil and water?
  15. #15
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @kittu99
    What are the symptoms?
    I mean is ur bike reducing water even after short ride?
    As spectra asked is there any symptom of Oil & water mixing?
    Or u r just feeling extra heat on ur legs while riding?
    Does temp gauge rises to red/damger zone?
  16. #16
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @kittu99
    Does temp gauge rises to red/danger zone?
  17. #17
    kittu99's Avatar
    Aug 2006
    38
    189
    lemme check that tommorow if water and oil are gtting mixed. and get back to you guys. 2nd yes it heats up and i can feel the heat coming out plus the gauge goes to the maximum.
  18. #18
    kittu99's Avatar
    Aug 2006
    38
    189
    The water isnt reduced after small ride.
    The water and oil isnt mixing up.
    I can feel the heat coming out of the bike. The gauge goes to red zone after 10 or 15 mins of drive. I have given the fan of the bike which had broken fins to be repaired. lemme check if it solves the problem. Back to you guys again. Thanks.
  19. #19
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @kittu99
    Wat exactly ur bike is as one of our Pakwheeler from Lahore owns a GSX 400 Impulse & his bike is suffering in same problem. However we r working to get it fixed our selves as its not getting fixed by Mechanics.
    SO lets see we will update u if got success
  20. #20
    kittu99's Avatar
    Aug 2006
    38
    189
    Imran may i have your number so i could contact you? Or sms me yours, its 0321-4041978. Thanks.
