Results 1 to 3 of 3
Thread: cd 200
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    Default cd 200
    is cd 200 single carb or doubble carb
    i seen it has 1 carb but goin into both heds seperetly so is it possibl to put 2 individual carbs
    (@rs4lyf3
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Yup its single Carb. BTW why u wana add 2nd Carb to it?
    Exploring Machines is my Passion...
    jamaal's Avatar
    Nov 2003
    48
    178
    putting in 2 carbs is easy....
    installing 2 manifolds and cables is hard...
    you may get a 5-10% rise in HP with a 20-25% rise in fuel consumption....and the headache of syncing 2 carbs
    if you want to get a little more umph from ur sloth....try re-jetting and make the timming a bit advanced...look out for overheating though...
    ..share your decesion and result...
