Results 1 to 17 of 17
Thread: Buell 1125R
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Default Buell 1125R
    Buell 1125R: The no-excuses V-twin sportbike from the U.S. of A.
    By Lance Oliver
    n the sportbike world, a Buell has always been the quirky choice.
    Over the years, Buell engineers have massaged the Harley-Davidson Sportster engine beyond recognition, refining it and extracting more power. They came up with innovative solutions to vibration and cooling issues. Then, with the XB line, they made their motorcycles even more unique by putting the fuel in the frame, the oil in the swingarm and making the wheelbase ultra-stubby.
    And lots of people wondered, This is interesting stuff, but when is Buell going to build a sportbike with a more powerful liquid-cooled engine?
    Buell 1125R -549976
    The answer is now, and the motorcycle is the Buell 1125R.
    Development of the 1125R began four years ago. When Buell, now a wholly owned subsidiary of Harley, got the go-ahead to look outside the company for a new powerplant, several manufacturers were considered. But the choice quickly narrowed to BRP-Rotax. The Austrian company has built motorcycle engines for Aprilia and BMW, as well as engines for personal watercraft, snowmobiles, and other vehicles.
    The fuel injection system uses two huge, 61mm throttle bodies. Buell made the four valves per cylinder as large as possible, even using the smallest available spark plug to take up less space. The engine is solidly mounted in the frame, so three balancers are used to control vibration.
    Buell claims output of 146 horsepower at 10,500 rpm, measured at the crank, and 82 foot-pounds of torque.
    The Helicon engine is a dry-sump unit, but Rotax grafted an oil tank onto the left side of the engine, so although the swingarm retains a family resemblance to the XB line, it does not do double duty as an oil tank.
    Similarly, the 1125R's frame resembles the XBs', and still holds the fuel, but it's all new. Fuel capacity is increased to 5.6 gallons and ducts in the frame divert hot air that has passed through the side-mounted radiators into the engine area and away from the rider.
    Production has not yet begun, but Buell dealers should get at least one 1125R each by the end of the year, the company says.
    In today's sportbike market, where 1,000cc fours, 1,200cc twins and 600cc fours are all platforms for Superbike and Supersport racing efforts, the Buell 1125R is still a distinctive choice. It's just no longer a quirky choice.
    Buell 1125R -549977
    Buell 1125R -549978
    Specs
    Engine Liquid-cooled V-twin, four valves/cylinder
    Displacement 1,125cc
    Bore x stroke 103mm x 67.5mm
    Carburetion Electronic fuel injection, dual 61mm throttle bodies.
    Compression ratio 12.3:1
    Transmission Six-speed
    Final drive Goodyear aramid-reinforced belt
    Tires 120/70-ZR17 front; 180/55-ZR17 rear
    Front brake Single 375mm floating rotor, 8-piston caliper
    Rear brake Single 240mm fixed rotor, two-piston caliper
    Front suspension 47mm Showa inverted fork, adjustable compression and rebound damping and preload; 4.72 inches of travel
    Rear suspension Showa monoshock with external reservoir, adjustable compression and rebound damping and preload; 5 inches of travel
    Seat height 30.5 inches
    Lean angle 48 degrees, soft contact; 50 degrees, hard contact
    Rake /Trail 21 degrees/3.3 inches
    Wheelbase 54.6 inches
    Fuel capacity 5.6 gallons
    Dry weight 421 pounds with fluids minus fuel
    MSRP $11,995
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    wahaj_skyline's Avatar
    Dec 2004
    27
    848
    3 Post(s)
    Anth Anth Anth
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    hmmmm ... too xpensive for what is being offered...get a busa in that price ...also dont like the styling...but wat do you xpect from a country that makes ugly choppers..nice effort though
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    wasifali89's Avatar
    Aug 2006
    Dubai
    27
    5,077
    foosa
    nice opinion
    (1)Austin of England, a35, 1958, 850cc,,, (2) Mercedes benz , w202, C - 180 ,,, (3) 2003 HONDA CITY,,,, (4) Triumph TRW 500cc, 1952,,,,
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    @foosa
    Did you just call choppers ugly? I doubt if you have love for machines..!!
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    yup u heard me right...choppers...ugly...cruisers ugly....SPORTS ...LOVELY
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    specially that one
    Sep 2004
    35
    3,701
    8 Post(s)
    (6)
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i do like this one though...guess who owns it
    Buell 1125R -846029
    Sep 2004
    35
    3,701
    8 Post(s)
    Has the owner got anything to do with F1?
  12. #12
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    he has everything to do with the f1 now shhhhhh
  13. #13
    sher_butt's Avatar
    Jan 2008
    31
    337
    buell is the subsidery company to HARLEY-DAVIDSON ..
    hav visited its showroom back in 2006 in saudia arabia .... on main KHOBER-DAMMAM highway
  14. #14
    salman_ksa's Avatar
    May 2006
    Ad-Dammam
    27
    9,331
    @foosa, that's Kimi's bike
  15. #15
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    salman...thought i told sami to SHHHHHH and make it look like a secret ...but thanx for blowing it up
  16. #16
    salman_ksa's Avatar
    May 2006
    Ad-Dammam
    27
    9,331
    @sher_butt, Here are some pics of that showroom
    Buell 1125R -846213
    Buell 1125R -846214
    Buell 1125R -846215
    BTW pics are almost 3 years old.
  17. #17
    salman_ksa's Avatar
    May 2006
    Ad-Dammam
    27
    9,331
    @foosa, You are most welcome :p
