Results 1 to 10 of 10
Thread: 2009 FZR6
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    Default 2009 FZR6
    First of all i would like to say
    Light is copied from Suzuki, Graphics on the white models are copied from Kawi (ZX14R Special Edition)
    Now the Features
    Key Features:
    ALL-NEW FOR 2009
    * A rider in the market for an entry level or commuter 600cc bike doesn’t have to compromise performance or style to get value: introducing the new 2009 FZ6R! It’s a great combination of performance, handling, and exciting sport bike style, but also with a low seat height that’s both adjustable to fit a wider variety of riders and also narrower where it counts to make it even easier to put both feet on the ground.
    * The newly designed engine delivers smooth power just the way today’s rider needs it, brisk acceleration with plenty of torque that makes it a pleasure to get around town, with lots in reserve for when you want more. This is certainly not a “no frills” motor. It’s based on the awesome, previous-generation R6 motor, fuel injected and tuned for real world street riding with no-hassle reliability and all-day comfort.
    * Even if your primary goal is commuting to school or work, you want to be able to get out and have fun riding some twisty back roads. The FZ6R is ready to put a grin on your face! The newly designed diamond-shaped frame made of high-tensile steel pipes, using the engine as a structural member of the chassis, becomes the foundation for handling performance. It’s designed to provide the right rigidity balance to contribute to smooth cornering performance.
    * When it comes to putting power to the pavement, the new FZ6R uses nothing less than quality radial tires, 120/70R 17-inch front and 160/16R 17-inch rear. And this bike’s excellent stopping performance is due to dual 298mm front discs and a 245mm rear disc, both with comfortable to use controls.
    Engine:
    * With its heritage firmly rooted in the power plant from an earlier generation R6, the engine in the FZ6R has been carefully updated to meet the demands of today’s motorcyclist. This new engine optimizes the entire flow from the intake of the fuel-air mixture to combustion and exhaust. The cylinder head, crankcase, intake and exhaust system, and clutch and shifter have been completely redesigned, creating a power unit with an entirely new character, even though it shares bore and stroke dimensions and compression ratio with the previous FZ6.
    * The 600cc liquid-cooled 4-stroke in-line 4-cylinder engine is ready to respond with smooth, linear performance when the rider twists the throttle. Maximum output is achieved at a spirited 10,000 rpm and maximum torque is obtained at 9000 rpm. Bottom line: Its outstanding “torquey” low to mid rpm engine performance is just right for someone who enjoys commuting to work or school or riding the canyons on the weekends.
    * Lightweight forged aluminum pistons are used. Because the aluminum alloy is heated and formed under pressure without having to melt it completely as in conventional casting techniques, the strength of the original metallurgic matrix of the aluminum is maintained. As a result, a forged piston is stronger than a cast one and can thus be designed for lighter weight, which contributes to a reduction in vibration. In fact, many riders will be surprised at how smooth this motor is.
    * The 32-bit ECU controls the four-hole, two-direction, high-dynamic-range type fuel injectors for superior injection control. By delivering the precise fuel-air mixture needed for conditions, the engine can deliver better power and better fuel economy.
    * Much like many of today’s high end sport bikes, the FZ6R has a 4-into-2-into-1 midship exhaust. Not only does it provide a throaty, yet comfortably quiet exhaust note, the system also includes 3-way catalytic converter technology to reduce exhaust emissions.
    Chassis/Suspension:
    * With its exciting sport bike looks, onlookers will know this isn’t just another middleweight bike. There’s no mistaking Yamaha’s high-performance heritage in this new FZ6R.
    * The seat has separate front and rear sections, and the rider’s seat features an innovative height adjustment mechanism. The seat can be set 20mm – just over 3/4 of an inch – higher for taller riders, a change that can make a big difference on an all-day ride
    * The overall chassis rigidity has been designed to provide both excellent handling and all-day comfort. In order to further enhance the smoothness and comfort of the ride, the front-end dimensions a have been optimized, including a caster angle of 26° and trail of 103.5mm, contributing a bike that has great steering feeling, making the bike even more of a pleasure to ride.
    * The front suspension has sturdy 41mm inner tubes, matched to a die-cast aluminum upper triple clamp and forged-steel under bracket, providing superior cushioning performance and good front-end feel. Wheel travel is a generous 5.1 inches to help soak up those bumps in the road.
    * The rear suspension is lightweight and contributes to the centralization of mass, and the mono-cross suspension provides excellent wheel travel, a full 5.1 inches. Superior road hugging performance has been achieved with optimally designed damping-force valves and oil channels.
    * This bike boasts hydraulic discs front and rear. The 298mm diameter front discs are lightweight for reduced unsprung weight, while the single rear disc is 245mm, and the brakes feature semi-metallic pads. The brakes have been designed to offer great feel and superb braking ability.
    * FZ6R mounts tubeless radial tires on cast aluminum wheels. While their lightweight construction helps centralize mass, they also help contribute to agile handling.
    Additional Features:
    * The new meter panel gives the rider plenty of feedback, including a digital display speedometer, analog tachometer, odometer/tripmeter, fuel gauge, and water coolant gauge.
    * Body work has an exterior coating for superior shine.
    Now the Specs
    Engine
    Type 600cc liquid-cooled 4-stroke, DOHC 16 valves
    Bore x Stroke 65.5mm x 44.5mm
    Compression Ratio 12.2:1
    Fuel Delivery Fuel injection
    Ignition Digital TCI
    Transmission 6-speed; multi-plate wet clutch
    Final Drive Chain
    Chassis
    Suspension/Front Telescopic fork, 5.1-in.travel
    Suspension/Rear Single shock, 5.1-in travel
    Brakes/Front Hydraulic disc, 298mm
    Brakes/Rear Hydraulic disc, 245mm
    Tires/Front 120/70 ZR17M/C 58W
    Tires/Rear 160/60 ZR17M/C 69W
    Dimensions
    Length 83.5 in
    Width 30.3 in
    Height 46.7 in
    Seat Height 30.9 in
    Wheelbase 56.7 in
    Rake (Caster Angle) 26.0°
    Trail 4.1 in
    Fuel Capacity 4.6 gal
    Fuel Economy** N/A
    Wet Weight 467 lb (CA: 470)
    Now The Pics
    2009 FZR6 -560349
    2009 FZR6 -560350
    2009 FZR6 -560351
    2009 FZR6 -560352
    2009 FZR6 -560353
    Living in Denial
    Ducati's Avatar
    May 2008
    Johannesburg
    86
    5,444
    4 Post(s)
    So its a Fazer trying to look funky
    -Allah meherban tau gadha pehlwan
    wasifali89's Avatar
    Aug 2006
    Dubai
    26
    5,077
    it looks touring type
    (1)Austin of England, a35, 1958, 850cc,,, (2) Mercedes benz , w202, C - 180 ,,, (3) 2003 HONDA CITY,,,, (4) Triumph TRW 500cc, 1952,,,,
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    They say its for the beginners. Which means it doesnt breaks your neck when you twist the throttle
    Living in Denial
    cowboys's Avatar
    Apr 2008
    Rawalpindi
    29
    378
    price of this machine
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    $6,990 and $7,090 the prices are differed by the colour i believe
    Living in Denial
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    nothing is copied from suzuki or kawasaki ...its a brand new Fazer from yamaha...and thats it
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    Maybe in FoosaWorld thats it
    Living in Denial
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Fazer. One of the all time favorites by Yamaha! Nice machine!!
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    umar219's Avatar
    Jul 2008
    27
    206
    fazer is da best brand of yamaha n nothing is copied in it
