Results 1 to 2 of 2
Thread: How the single tyre rule will work in MotoGP?
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Default How the single tyre rule will work in MotoGP?
    Details of the single tyre rule that will be introduced in MotoGP for the first time in 2009 have finally been confirmed.
    The new rule, which was exclusively revealed by MCN back in August, will see riders eligible to run only 20 slick tyres supplied by Bridgestone on a race weekend. The specs will be pre-determined by Bridgestone, with two specs of four front tyres and two specs of six rear tyres available.
    In the case of wet conditions, eight tyres will be made available with four fronts and four rears available. And for any testing, riders can only use eight tyres per day, with the allocation split between two fronts and two rears in two different specs.
    How do you see this development?
    SOURCE
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    nightsurfer's Avatar
    May 2005
    32
    7,364
    3 Post(s)
    A similar kinda rule increased the number of crashes in formula1 by quite a bit. It was an absurd rule.
    Honda City 1999 1.5L NEO MT | Honda City 2009 1.3L AT
