Page 115 of 521 FirstFirst ... 1565105113114115116117125165215 ... LastLast
Results 2,281 to 2,300 of 10402
Like Tree9839Likes
Thread: Yamaha RX115 Owners & Fan Club
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Default Yamaha RX115 Owners & Fan Club
    ​Hi, guys I am a great lover of yamaha rx115 bike. once i had a new YAMAHA RX115 when i used to study in fc college lhr in 1988. i had it for only two years and then my parents sold it after two years of usage that was a great bike there was no competitor of rx115 and after 20 years there is also no competitor of it. now i bought a 82 yamaha rx115 its working good. now a days there is a new bike yamaha rx135z is in market in malaysia,indonatia and thailand,they love 2 stroke bikes so why dont DYL IMPORT yamaha rxz135 from malaysia if its impossible dyl should assembled it in pakistan. i am sure if YAMAHA rxz arrive in pakistan it can burn the market and there will be no competitor of it bcoz YAMAHA RXZ is road king, I need ur suggestions plz have ur say,thanks
    Yamaha RX115 Owners & FAN CLUB -572164
    Yamaha RX115 Owners & FAN CLUB -412858
    Yamaha RX115 Owners & FAN CLUB -412859
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  2. #2281
    YamahaYB100's Avatar
    Sep 2010
    28
    1,165
    16 Post(s)
    Im using and fixing them since 19, (my first bike was a non running Kawaski ELX100 - which I rebuilt myself using the repair manual, a simple tookit and an old dining table).. and Ive repaired quite a bunch of expensive 2 stroke machines - I was known as the insane person who loves deadly 2 strokes, I used to gun my rebuilt RGV250 alongside big bikes. These single RX engines are stupidly easy to rebuild, For cylinder builds, most of the time it is cheaper to just buy a used cylinder, as firstly proper porting takes a good part of 1 or 2 days, not to mention a good pressure cast cylinder sleeve is very expensive to buy (quite more than what the lathe shop charges you for a whole sleeve job) - then getting some dry ice or nitrogen for the sleeve to shrink and carefully reaming out the old sleeve from the barrel and heating it in an oven while measuring the very cold sleeve and very hot barrel. Then carefully pressing it in the hot barrel - once cooled it will hold the sleeve super tight like original. Its expensive but worth it for a machine whose cylinders are hard to find. (the above mentioned RGV250 is an example)
    I'll give you an example, sleeving an RX cylinder this way may cost you about Rs 7000/- to Rs 9000/- (cheaper to buy a used jap cylinder)
    The sleeve job you will get from the dumbas$ shops have port aims all wrong and very sharp edges like glass, and the sleeve becomes loose if you just heat up the cylinder with a torch this causes siezure and the wrong port aim and sharp edges cause bad compression and broken rings
    impressive dear but lhr ya khi main kon is tarah se sleeve lagata hai?
  3. #2282
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    this is the real question u did ask to @xulfiqar coz we all cudnt do it byself due to some reasons
  4. #2283
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
    I am only responsible for what I say, not for what you understand..
  5. #2284
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  6. #2285
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  7. #2286
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  8. #2287
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    I port the cylinder liners myself and then have a precision machine shop (not in radio pakistan lathe market) lend me some time on the presses and tooling.. i dont know anyone in Khi who does it this way other than myself.
    but believe me - once you widen the exhaust, stagger and aim the transfers to the centre and back of the cylinder and clean out the boost port, aiming it straight to the tip of the plug - the bike will scream like you have never heard before - you will literally feel it rev harder at all ranges. The inlet ports should aim downwards, for them to be effective - (remember air has weight and the crankcase port reed design uses this principle to ram air into the crankcase because air self compresses into the crankcase under its own weight - more than just suck it) - anyways.. too much, I left 2 strokes a long time ago.. its a deadly addiction.
  9. #2288
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    why do you guys use the weak and stupid looking original philips screws on the engine - put some socket (allen) screws on it - it will look much nicer and are tough, the best part is that you dont need an impact driver to remove and install, a simple allen key or allen socket with a ratchet works best.
    My RX had all allen screws - down to the last tiny button head screw holding the main gearshaft bearing - and even the little screws on the oil pump
  10. #2289
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  11. #2290
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  12. #2291
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  13. #2292
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  14. #2293
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    the allen screws are hard steel and do not round off like these soft philips screws - it has got nothing to do with performance or engine weight - its about using high quality fasteners rather than cheap soft screws that the factory did - and using an impact driver on weak structures can easily fracture them..
    btw allen screws are heavier than normal philips screws - hence they increase weight
  15. #2294
    Apr 2006
    Select City
    14,246
    7
    295 Post(s)
    11 Thread(s)
    9
    Removed!
  16. #2295
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @kamran nice show off......i think u r into shinny ones.....lol
  17. #2296
    SAIFARAIN's Avatar
    Aug 2010
    197
    Sorry kamran,, i was in office and both the phones were on silent mode....
  18. #2297
    SAIFARAIN's Avatar
    Aug 2010
    197
    Faheem bhai a few days back u too were calling on my cell but i could not rcv and forgot to call back u,,,
  19. #2298
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by SAIFARAIN View Post
    its ok yar sab chalta hy i just required to ask about ur plan about restoring it....but when i saw ur ad then i didnt call u again,thats it,
  20. #2299
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @kamran i recently bought a sleeping king.....need to restore it,i will do but in slow mode
  21. #2300
    SAIFARAIN's Avatar
    Aug 2010
    197
    Quote Originally Posted by rx115 View Post
    yes brother i m thinking to get a restored 135 bike,, as i have no time to visit markets and mechenics too,,,and the main thing of the rx is that it should be in propper balnce,, otherwise rx is useless,, i hope u catch wht i wn2 explain...
Tags for this Thread
