Page 340 of 521 FirstFirst ... 240290330338339340341342350390440 ... LastLast
Results 6,781 to 6,800 of 10402
Like Tree9839Likes
Thread: Yamaha RX115 Owners & Fan Club
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Default Yamaha RX115 Owners & Fan Club
    ​Hi, guys I am a great lover of yamaha rx115 bike. once i had a new YAMAHA RX115 when i used to study in fc college lhr in 1988. i had it for only two years and then my parents sold it after two years of usage that was a great bike there was no competitor of rx115 and after 20 years there is also no competitor of it. now i bought a 82 yamaha rx115 its working good. now a days there is a new bike yamaha rx135z is in market in malaysia,indonatia and thailand,they love 2 stroke bikes so why dont DYL IMPORT yamaha rxz135 from malaysia if its impossible dyl should assembled it in pakistan. i am sure if YAMAHA rxz arrive in pakistan it can burn the market and there will be no competitor of it bcoz YAMAHA RXZ is road king, I need ur suggestions plz have ur say,thanks
    Yamaha RX115 Owners & FAN CLUB -572164
    Yamaha RX115 Owners & FAN CLUB -412858
    Yamaha RX115 Owners & FAN CLUB -412859
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  2. #6781
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Quote Originally Posted by rx1one5 View Post
    hi i need a suggestion from friends in Rx family.alteration in chain sprocket will i get the performance and if yes what kind of performance would i get what sprocket should be in RX i am using dt 125 calender and 135 clutch bucks tell me in details.
    FAHEEM BHAI CAN TELL ABOUT SPROCKETS
    tell me dt cylinder in rx performance
    legend will revive soon
  3. #6782
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    i suggest u go for the default sprocket size (16T front and 37T rear)... that's what i am running on my RXZ
    gives me both; perfect shoot and long ...
    but if u want better top speed then go for 16T front and 39T; this was my old setup.
  4. #6783
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by voodoo View Post
    @rx1one5 as @voodoo said thats true 16/37 is perfect match on dt,piston and having 135,s clutch box
    rather 115,s original sprockets are 15/38 but u have alter the engine with big boaring n heavy clutch box thats why 16/37 will give u better pick n top
    rather if u install 16/39 then pick will be mind blowing and the all 5 gears will be done within 1km of distance......
    so if u would use ur bike as a daily commuter then go for 16/37
    i tell u all the formula of secondary reduction ratio
    orig ratio of 115 is =2.53(15/38)
    orig ratio of 135 is =2.46(15/37)
    orig ratio of rxz is =2.87(16/46) 6speed version
    lower the ratio increase top but will decrease the pick
    and
    higher the ratio will increase the pick and will decrease the top
  5. #6784
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @hid 115 has only 2 piston in over size 0.50mm and 1.00mm
    due to lack of over piston sizes, people used to install yamaha dt125,s standard piston 56mm as least over sized bore possible in 115,s block
    so u can also assume over size piston in original block of 115...
    so performance on this over size match depends on accurate boring and also would required a good piston....and if u need extra performance then clutch box should also be replaced.....one can use rxk135,s clutch box for extra power
  6. #6785
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    faheem bhai what about sleave?
    i heard rx still makes 140 on sleeve easily?
    today i saw rx from v close felt it alot
    the orignal gear shifter is v v different to me
  7. #6786
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by hidalgo View Post
    depands on liners quality, the ports finish, boring, carb and its adjustments and there u go but it would not even near to original block
    on sleeve u can hear much noise on high rpm,
    the sound of bike would not crispy
    the pick would decrease
    congrats for that initial feel of rx
  8. #6787
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    rx looks slim but its really hard core
  9. #6788
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    hmmmm true lot of guys would deceived by its slimness
    or is ki smartness ka raz hay k yeh 3rd gear main bgher kisi extra effort k cg125 ko cross marti hay or cg par letay hoy shokeen hazrat ko uth bethnay pay majboor kerdeti hy
  10. #6789
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Talking hidalgo's future vision
    Yamaha RX115 Owners & FAN CLUB -359017
  11. #6790
    uzair115's Avatar
    Nov 2011
    319
    4 Post(s)
    2 Thread(s)
    Thumbs up yES RX 115
    or is ki smartness ka raz hay k yeh 3rd gear main bgher kisi extra effort k cg125 ko cross marti hay or cg par letay hoy shokeen hazrat ko uth bethnay pay majboor kerdeti hy[/QUOTE]
    thats y i luv yamaha rx115
    "the elevator to success is out of order.You will have to use the stairs...one step at a time." Joe Girard
  12. #6791
    N0m1's Avatar
    Mar 2011
    22
    2,056
    11 Post(s)
    3 Thread(s)
    Quote Originally Posted by RX115 View Post
    Hahaha.Kya misal di hay.
    Han rx slim hay or dekhny main long lagi thi mujhe.Height bhi amazing hay RX ki.
    I Am the Feel
    I Am The Yamaha!
  13. #6792
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    good but meter is looking extra front light is huge else is good
  14. #6793
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Default nicly done
    Yamaha RX115 Owners & FAN CLUB -359018 Yamaha RX115 Owners & FAN CLUB -359019
  15. #6794
    uzair115's Avatar
    Nov 2011
    319
    4 Post(s)
    2 Thread(s)
    @ faheem bhai may ne apne dost ko rx ki vdeo dikhai thi jo apne bnai thi or jb us ne throtle ghomtay huway dekha tou he shock n i roxxx
  16. #6795
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Yamaha RX115 Owners & Fan Club - 359018 Yamaha RX115 Owners & Fan Club - 359019
    its king engine broooooo nice mod
  17. #6796
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    rx100 frame is bit changed then 115?is n t it ?
  18. #6797
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    Quote Originally Posted by uzair115 View Post
    lolx throtle ko to abhi spin kiy hi nahi us video main just ishara kia tha coz its on running
  19. #6798
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    rx100 indian frame is almost same as japanese rxk135,s frame
    rxs100 uk model frame is 100% same as rx115
  20. #6799
    uzair115's Avatar
    Nov 2011
    319
    4 Post(s)
    2 Thread(s)
    lekin phr bhi woh kafi dum bta rai thi yehi may us ko dikhana chata tha
  21. #6800
    Founder Follow
    HanifBhatti's Avatar
    Jul 2003
    60
    45,311
    54
    981 Post(s)
    71 Thread(s)
    Zabardast Topic (Y)
    Formerly known as Libra. Founder Pakwheels.com
Tags for this Thread
