Results 1 to 3 of 3
Thread: GS 125 Oil change
    invincible2k's Avatar
    Feb 2009
    35
    Default GS 125 Oil change
    i have bought new GS 125 in December 2008 now i want to know which oil brand is better using in GS 125 caltex or Shell any suggestions i m new in this bike world technically don't know much so need assistance and suggestions
    asad01's Avatar
    Sep 2008
    Abbotabad
    53
    326
    6 Post(s)
    I can not say which one is better because I have never used Shell oils. I use Caltex's Havoline Motor Oil, it comes in a One litre, black plastic bottle, the oil is reddish in colour. It's grading is :
    SAE 20W-50
    API SG
    Make sure you get the original, large Caltex filling stations are a better place to get the oil.
    If you choose Shell, then get it from a large Shell filling station.
    After the first tuning, stick with the same oil. If you decide to change the oil brand or type have both the old oil and the oil filter replaced. Never mix a different type/brand of oil to refill existing oil. Never use the open oil available at filling stations, it is not meant for engines that rev up to 10,000rpm (like motorcycles).
    You can use any lubricant from SAE 10W-40 to SAE 20W-50. API rating must be SF or SG (for all motorcycles). NEVER use Havoline Formula or any other oil with API ratings of SL or any other, which are for Cars (dry clutch).
    Asad
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    same
    CalteX
    100ml pack simply
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
