Page 23 of 26 FirstFirst ... 132122232425 ... LastLast
Results 441 to 460 of 501
Like Tree8Likes
Thread: ALL BIKERS HELPLINE...........
    Adeelasghar8627's Avatar
    Sep 2007
    29
    174
    Default ALL BIKERS HELPLINE...........
    ~............WE ARE HERE JUST TO SERVE YOU....~ Suzuki,Yahmaha,Honda,kawasaki etc.....any kind of machine's problems are solved here..... NO RULES...........JUST ASK US!!! True Muslim's Oth to help orthers.... True biker's spirit .....To help our brothers..... So Do join us in helping each orther.......... kindly discuss about ur two wheeler ride its the plat form to help each other about machines problems i want to do some thing 4 my bike bros IF SOMEONE HAVE ANY ISSUE ABOUT THIS TOPIC THEN HE CAN CALL US AT:
    CHAUDHRY ADEEL ASGHAR 03224334458
    Mohammad Hareem Ullah Khan 03219539147
    FI AMAN ALLAH.....
    engine oil meri ragon main dorta hai
  2. #441
    malabar's Avatar
    Jun 2009
    India
    37
    304
    @sherrry: Do a Compression test.Notice for Excess valve chattering,tappets getting loose etc.Make sure carburetter not tuned for Running Lean(For higher mileage).Moreover ,don't expect analog speedo meters to be correct 10-20% Optimistic Speeds it Will Show Purposefully
    How To Do Compression test(Your Mechanic Mostly knows this):
    http://dansmc.com/compression_test.htm
    Get GNU/Linux Guys/Gals! http://getgnulinux.org
  3. #442
    bilalzubairy's Avatar
    Oct 2008
    31
    1,581
    4 Post(s)
    2 Thread(s)
    @sherrry
    First of all go to a good meter shop located at mclord road i have forgotten name of the shop. Will let you know tomorrow. and get it serviced and adjusted... they will test it on a motor and it should give a speed round about 65-70 km/h...
    Then get it installed it on your machine and test it... if it is doing some problem then check the sprocket located in the front wheel hub and if it is also alright then consult the same mechanic i recommended to princesaqib. He will tune up your bike to give speed as it will be the problem of the engine...
  4. #443
    sherrry's Avatar
    May 2009
    46
    162
    Quote Originally Posted by bilalzubairy
    @sherrry
    thanks brother...thanks alot..
    ///HONDA CG 125,PROOF THAT YOU DON,T NEED WINGS TO FLY///
  5. #444
    sherrry's Avatar
    May 2009
    46
    162
    @sherrry
    bhai shop ka bta do name.....
  6. #445
    Oct 2008
    31
    1,581
    4 Post(s)
    2 Thread(s)
    @sherrry
    Yaar there is no name of the shop...
    main par "Hafiz shocks wala" baitha hua hay just in front of janaz ghah on litten road... behind his shop in a small gali there is Shahid and zeeshan sitting doing bike works... shahid do work for small bikes and zeeshan is mechanic of heavy bikes...
  7. #446
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @Sherry
    I m 90 % sure that ur Bike's Original Speedo meter is giving almost accurate reading & u r just confused coz previously u have been using a non branded meter & now u r comparing original one wid that non branded.
    Exploring Machines is my Passion...
  8. #447
    Oct 2008
    31
    1,581
    4 Post(s)
    2 Thread(s)
    @all
    Guys check this link out "http://mtmis.punjab.gov.pk/"...
    Now no need to go to FIA or some other place to verify the ownership/legal status of the bike/car...
    Just enter the registeration number in the link above and you will get the engine#, chasis# and the owner of the vehicle...
  9. #448
    saadjahangir's Avatar
    Sep 2009
    29
    18
    hello
    i am Saad from karachi. i want to buy a bike 400cc or 600cc can u guys help me with this as i dont have any idea of the heavy or sports bikes. help me plzzzz
    03453425657 this is my cell number if there is any bike in ur eyes for sale plz let me know plz
    regards
    Saad Jahangir
  10. #449
    princesaqib's Avatar
    Dec 2005
    Gujranwala
    30
    1,995
    2 Thread(s)
    @all
    can any one plz tell me the tappet adjustment gap of GS 150 plz?
  11. #450
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @princesaqib
    It shud be given in owners manual have u check that ?
  12. #451
    Oct 2008
    31
    1,581
    4 Post(s)
    2 Thread(s)
    @imranbhatti
    Will performance plugs work fine with the GSX or not...??? Which plugs do u recommend for it...???
  13. #452
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    SUre u can try perfomance plugs as well. BTW i m using Stock Plugs didnt exactly remember its Code ( Ithink its CR 8E) but its the same as used in CG 125 Deluxe & easily available every where
  14. #453
    Dec 2005
    Gujranwala
    30
    1,995
    2 Thread(s)
    @imran
    yup checked throughly nothing in there was the proper measurement or reading the suzuki gujranwala says "hath se he kartay hain aap lay aain bike to kar dain *** hath se" but this time i a doin it my self
  15. #454
    enigmatool's Avatar
    Sep 2009
    39
    236
    @saqib dear
    go to some car mechanic jo daihatsu cuore ka kaam krta ho.
    unkay paas ek set hota hay 4 ya 5 keys ka ek ring main . jis say wo cure kay tappits set krtay hain, unsay set udhaar lay kr ap kisi bhi senior mechanic say adjust krwa lo. hope your prob solved.
    as far as plugs r concerned, deluxe wala plug heavy bike main laganay say wo 3 ya 4 din main he plug farigh ho jain ***.
  16. #455
    Dec 2005
    Gujranwala
    30
    1,995
    2 Thread(s)
    @enigmatool
    bhai mechanic he main khud houn so any 1 plz tell me the gap and i have some gauge jis say adjust kiye ja saktay hain tappents but dnt know the exact gap of those
    and jahan tk plugs ka sawal hai to i always recomend and go for denso spark plugs or nippon denso plugs its the same thing
    and enigmatool bhai aap wo black horse walay brake shoes ka keh rahay thay can u tell me any specific shop jahan se milain coz not availble in my city infact yahan kuch bhi nahi milta
    siwaye khanay peenay ki cheezo k
    and i also want a white light bulb for my gs wo bhi nahi mila
    so tell me nxt time lahore se leta aaoun ga
  17. #456
    hashmi21's Avatar
    Oct 2009
    29
    7
    Salam every 1,
    I need to buy a simple bike for daily usage. Can any1 guide me which make and model would be the best. I dont want any fancy bike, just simple 70 cc
  18. #457
    Oct 2008
    31
    1,581
    4 Post(s)
    2 Thread(s)
    @hashmi21
    In my opinion go for Pak Hero 70 CC bike...
  19. #458
    hashmi21's Avatar
    Oct 2009
    29
    7
    thx a bunch...some pp also suggested me of unique...any opinions on that ..??
  20. #459
    haseeb114's Avatar
    Jan 2007
    28
    2,203
    3 Post(s)
    Plz answer my questions !!!!!!!
    I want to install hid light in cd70 and cg125!!! i will buy a pair which are available for cars and install them in both bikes.
    1.which hid should i purchase?? means its power..so i can get best light without energy loss !!!
    2.will it effect the battery ?????
    3.can it run on default battery ??? or need to change it???
  21. #460
    tanveerch100's Avatar
    Oct 2009
    london
    46
    AoA
    hello guys i am new to this site the reason i m here is to get and opinion about buying a new bike for my younger brother he had an old honda 125 90 model which i owned originally and now he is having a lot of trouble with it lately so he has asked me to get him a new one and i am a bit confused about what to buy next i have considered allot of bikes but it has come down to suzuki gs150 or piaggio 125 and i don't know what to buy out of these two because i m not in pakistan and my younger brother is not into bikes that much so i just need a word of advise from you guys what to go for and if it is inappropiate on this topic i sincerely appologize for that i hope you don't mind than you very much for the oppertunity in advance and i looking forward to hear from you guys. ALLAH HAFIZ
