Results 1 to 13 of 13
Thread: my honda 175cc
    roadrasher's Avatar
    Aug 2009
    25
    6
    Default my honda 175cc
    im having prob wth my bike.....plz tell me about any gud mechanic in lahore.....by the ways...its an inheritance for me....how does it look?...plz tell
    my honda 175cc -612224
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    nice bike...2 years back was thinkin to buy it..as i was getting very good deal
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
    hash4u's Avatar
    May 2005
    38
    24,379
    18
    406 Post(s)
    13 Thread(s)
    13
    wait for imran bhatti's advice
    asifshah's Avatar
    Apr 2007
    50
    330
    salaam:
    seems in a pretty good condition. 1977~78 model?
    can you describe what sort of problem you want to address to?
    regards
    "May his dream for Pakistan come true." by Ms Dina Wadia, writing in the visitor's book at Jinnah's Mazar.
    roadrasher's Avatar
    Aug 2009
    25
    6
    1976 ka model hai......bohat genuine condition me hai......i felt its real power twice....bt old hai is lye kharabi kar rahi hai......plz tell anyone who could give me gud advice....
    roadrasher's Avatar
    Aug 2009
    25
    6
    wsalam
    well uncle asif...im too young to call u bhai.....i fix my bike myself....in technical language its head is old.....i have got two of them in reall excellent condition......but i failed to set the right exhaust roker timing....and due to which it makes too much noise and sometimes miss fires really badly......Well i hope if u can help...
    thnx
    khanmomar's Avatar
    Aug 2008
    57
    527
    3 Post(s)
    2 Thread(s)
    Nice bike! Please keep it in good shape.
    The best 175 mechanic in the 70s was Mr Saeed and Haji sahib. I hope they are well and working in the back of Dayal Singh Mansion.
    yamaha135's Avatar
    Mar 2009
    34
    403
    Quote Originally Posted by roadrasher
    wsalam
    thnx
    the exhaust rocker can be adjusted back to stock specs by removing left hand side engine cover, the small circle one that says "honda" its held by 3 screws.. after removing it you will see the stator, on the stator by looking closely you will see 2 marks, you need the "T" Mark which is top dead center, turn the engine over by the stator and align it with the T mark.. the T mark on the stator should be in line with the timing pointer pin.. once the T is in line with the pointer unscrew the tappet cover and adjust all tappets/rockers by losening them enough that they move sideways by hand, only sideways, no up and down play or movement should be there. once adjusted tighten the 10mm nut down, be careful with those nuts when applying torque cause they have a habbit of breaking if there is too much force applied. after doing that recheck the side movement on all the tappets by turning the engine over a full 360 degrees (counter clock) check if the side movement is still there with no up and down play, you need a little side movement, no side movement will most likely cause the valve to remain open and lose compression. once done install everything back on and you should be good to go.
    roadrasher's Avatar
    Aug 2009
    25
    6
    thanku very much mr yamaha......the real prob is every tym i adjust the rocker after 2 or 3,....360 degree rotations it lossen up....i have got its original guide book....4m where i have learnt it....everything about it.....i have done it 3 or 4 tyms before......bt now i had give up....thts y im takin it to a mechanic....in 26 years for the first tym this bike is goin to a mechanic....this is the major reason it retains its looks.......well thnkx 4 ur advice ......i have tried it numerous tyms before...
    Oblivious's Avatar
    Jan 2007
    44
    52
    2 Post(s)
    @roadrasher - your bike looks amazing - mashaAllah - Well kept
    ya_ah_na's Avatar
    Jun 2009
    31
    26
    A Vary Nice Bike Janab
    Love for All Hatred for None!
  12. #12
    badboykool's Avatar
    Aug 2006
    colombo
    30
    581
    wana sell it
    (@rs4lyf3
  13. #13
    roadrasher's Avatar
    Aug 2009
    25
    6
    sorry bro not forsale....its a gift as well as inheritance...
