Page 31 of 35 FirstFirst ... 212930313233 ... LastLast
Results 601 to 620 of 687
Like Tree395Likes
Thread: Ravi piaggio storm 125 vs honda cg125 dlx
    adeel060's Avatar
    Aug 2009
    27
    515
    Default Ravi piaggio storm 125 vs honda cg125 dlx
    Guys plz share ur ideas there.as it become necessory.
    @Mod plz keep it alive as its very helpfull for the purshasers of these bikes.they get info under one roof.
    Ravi piaggio storm 125 vs honda cg125 dlx -14674 Ravi piaggio storm 125 vs honda cg125 dlx -14675
  2. #601
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    ye hui na baat
    Quote Originally Posted by abobobilly View Post
    @amjad635! @vickytulla!
    Sub batein choro. LOOK HERE.
    Tire Size Conversions|
    Focus on table and this line ONLY.
    Look in the column of:
    2.75/3.00 - 18
    3.00/3.25 - 18
    3.25/3.50 - 18
    ... ab tension lena choro and trust that shopkeeper
  3. #602
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    You enlighted me bro! I was more confused then amjad
    so from your explaination what I am understanding is that paigo tyre is wide then delux but has the same 3 inch hieght right ?
    Quote Originally Posted by gull_s_777 View Post
    3.00-18 is not same as 90/90-18.
    If we talk in inches,
    3.00-18 is 3 inch wide and most probably 3 inch high
    90/90-18 is 3.54 inch wide and 3.18 inch high
    Now in that chart , why these two are considered same... i think it is to maintain the height. A 90/90 tyre will be as wide as a 3.50 tyre but only as high as about 3.00 tyre.
  4. #603
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Ok , did a bit more reading and this is what i got...
    piaggio tyre is old inch based design... 3.50-18, in old inch based designs , tyre width and height are same, so Piaggio has the tyre which is 3.50 inch wide and 3.50 inch high.
    While delux 90/90-18 tyre is 3.54 inch wide and 3.18 inch high as i mentioned above.
    So both are about same width, but delux tyre is a bit low on sidewall height. Now this might make you wonder what to choose if you want a new metric based tyre and don't want to loose height also.
    First option is straight forward , get a 100/90-18 tyre. It will be 3.93 inch wide and 3.54 inch high.
    If its too wide , and you want slimmer yet higher sidewall tyre then you can try to find a 90/100-18 tyre which should be same as piaggio tyre , aka 3.54 inch wide and 3.54 inch high , but i am not sure this is easily available or not.
  5. #604
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    100/90-18 will be the best bet ... but right now my stock tyre is working fine, may be in near future when it rips apart will think to put a 100/90-18
    after reading these details Amjad will get more confused and jump into river ... .. by the way not going to change the tyre until it rips apart ** THINKING PAKISTANI ** then after that I will think which one to install ...
  6. #605
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Finding tube is a nightmare.. Not easily available
  7. #606
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    i think 90/90-18 is perfect for delux, its just a 125cc after all, bigger tyre will look cool but will increase burden on engine and will result in reduced mileage (but might also result in slightly more top speed due to increased height )
  8. #607
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Yaar yeh tyre sizes ne dimaag ghumaa diya do din se ............
    aur aaj vicky bhai aap bhi en tyroo ke chakar mein parh gaye
    thanks to all fellows & Gull sahab for explaining
    So Gull bro means 3.00 18 & 90/90 18 has same height too
    but in width 90/90 would be wider as @ shop shop waala
    compared it with 90/90 it was exactly same in diameter or
    it was exactly round as 90/90 tyre but as i had been understanding while purchasing
    3.00 18 was looking definitely looking thin to me 90/90 was looking wider
    and that was probably the reason which confused me and i thought this was CG tyre
  9. #608
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by amjad635 View Post
    10 on 10
  10. #609
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    10 on 10
  11. #610
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    I think top speed would increase with that Ghauri 3.00 18 tyre
    as that tyre felt light weight as compare to deluxe stock tyre & it is same height
    shop waala was admiring deluxe original tyre he was saying even without air
    this gives feel as its filled with air deluxe tyre is pretty stiff & also don't gets puncture easily
  12. #611
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    yes, top speed will increase a bit with 3.00 18 tyre, but grip is gonna be horrible for delux, not advisable at all.
    GS150 comes with stock 3.00 18 tyre and i haven't seen a single user admiring it, most of them upgrade to 90/90 or 100/90 right away.
  13. #612
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Agree, very correct it would effect grip as deluxe is heavier
    it may trouble while turning @ good speed
    and it would kill looks of bike too a slightly slim tyre would ruin deluxe looks
  14. #613
    Newbie Follow
    hassansalman1's Avatar
    Nov 2012
    Default yar as compared to style the best bike in pakistan is ravi piaggo storm 125
    Quote Originally Posted by adeel060 View Post
    yar as compared to style the best bike in pakistan is ravi piaggo storm 125 but it is chinese so not reliable so deluxe 125 is reliable but i personaly like piaggo
  15. #614
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    Indeed, CG/Deluxe has an engine which is tested accross times ...
    Quote Originally Posted by hassansalman1 View Post
  16. #615
    Newbie Follow
    redbull1's Avatar
    Nov 2012
    Talking
    why honda is faster
  17. #616
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    being fast is not a good thing to to sell for a commuter bike even I dont agree that its faster, but real Good thing about HONDA is that it has a very Good service network.
    Quote Originally Posted by redbull1 View Post
    why honda is faster
  18. #617
    Hassan39's Avatar
    Dec 2010
    15
    Default hassan
    If v r disscussing about the price n performance so I think dat suzuki GS 150 is best. Ravi never meet it in speed n performance honda is also far away.
  19. #618
    Hassan39's Avatar
    Dec 2010
    15
    Yup viki u r right that honda has good service network just bcz of dis they r blkmling da pepl. The prices thy r offring r so high as u compare wid quality
  20. #619
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    actually honda itself is getting blackmailed from Mr Khappay, recently Yamaha showed interest to launch international models in Pakistan but failed becoz of stuburn govt. policies.. bussinees kahan hai PAkistan men... so in the end awam he rulti hai.
    Quote Originally Posted by Hassan39 View Post
  21. #620
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Gs-150 has reliability + quality issues..Thats not a customer seeks when he buys a 0 meter bike..But AHL shines in reliability and service areas.
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
