Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Like Tree9Likes
Thread: Neon Lights For Honda 125...and modifications...?
    Stalker24's Avatar
    Mar 2010
    30
    17
    Default Neon Lights For Honda 125...and modifications...?
    Salaam....
    Guys help chaye ....i want to install Neon Lights On my Honda 125 (2010)..But i cant find any shops in lahore..
    Kisi ko pta ho to kindly btaye....
    Any ideas u want to share for modifications...
    Any ones knows how to increase the top speed...???
    Regards..
    STALKER BEHIND U. . .
  2. #21
    Meeteepao's Avatar
    Mar 2005
    29
    178
    Thumbs up
    Quote Originally Posted by Stalker24 View Post
    Salaam....
    Regards..
    By "Neon Lights" do you mean something like this:
    http://www.youtube.com/user/Meeteepa.../0/-YhnriblhVY
    And if you meant HID headlights....I was in Lahore last week and went to Township to get some info as it was near my uncle's house. I found an HID kit at Al Makkah Auto Store (Abu Bakhar Road, Township, Lahore). The complete HID Kit costs around Rs3,200. But for that you need a high capacity battery, for which the guy at the shop said you'll need a 7Amp battery which costs around Rs830 (I think its the same battery that is fitted in a Suzuki GS150 or in those mini UPS systems).
    I have a Deluxe myself, and the electrician at that shop guarenteed me that he can easily install the battery within the side cover neatly. So I suggest you to go and visit the shop.
    Here are the contact details, if you are interested.
    Kamran Zaka (prop.)
    0300-9411100, 0322-9411100, 0333-4411109
    042-6141240,
    6141241,6141242
    All the best!
    Rollin' on a hundred chromed spokes
  3. #22
    alizees's Avatar
    Jan 2010
    35
    103
    2 Post(s)
    Where can i get HID's lights done in Karachi? Location and contact no would be gr8!
  4. #23
    djasif43's Avatar
    May 2013
    8
    Salaam....
    Regards..
    Salam,
    HID light is best source for more brightness nd visibilty nd make your Vehicle sexy, bt its costly if u bear all chargis then u must install in your bike,
    HID light ( High-intensity discharge lamp ) consume 35 watt same like as Orignal deluxe bulb also consume power 12 volt 35 watt. But orignal light runing through MAGINET. thats y it will b not effect to battry. HID runing through Battry, This tube is filled with Neon gas and metal salts need hight voltage to arc nd heat the gas, and Orignal bike battray not enough for HID . Because this battry only 12volt and 2.5A
    Hid light need high voltage using Blaster. i also installed Hid in my Honda Deluxe 125. And its work perfectly and work up to 2 hours and more then.
    installation parts for HID..
    (1)
    buy ( 8000K H4 Temperature HID light+blaster) . its cost about 2k with 6 month warranty,
    ( This is a pair of 2 lights) 1 HID or 2nd is incandescent flament tube ) Incandescent Tube same like as Default honda bulb yellow light, it will work on low beam through MAGINET current. and HID work on high beam button through Battry currnet. when u use high beam Incandescent Tube automaticaly will b off nd HID will b work,
    This pair will b adjust in place of Orignal bulb holder in 30 sec. Deluxe light body is very biger like car light body, it bear the HID Heat easily no modification needed.
    (2)
    Install 12 volt 9Ah National battray, its easily available in market with 3 monts warranty cost about 1.5k. its adjust very easily because deluxe has biger space in battry panel, no need to modification.
    Use china Road prince Rectifier. its provide auto current Ah 2.5 Ah to 7Ah step by step when battary needed,
    (NOTE)
    (1)
    Always use ( 8000K H4 ) temperature HID light. This colour temprature is white+blue. This temp never too much blind to other Drivers. Dont use HID Dipper (flash) on single road but trafic runing on both sides' it will be blind to other nd dangarious like a road accident, but if you use HID continusely without dipper then no problem. better option is Try to use only one way Roads.
    Use HID Only when bike engine in start position, it will b battray backup increase,
    (2)
    Installation HID to only expert electrician. because this is very inteligent work. Many Relays, junctions cut out and reactifier put in this circuit, every electrician not knowledge about how HID perfect work in bikes, dts y result will b shown also in bad experience like hid burn,blaster burn,battray not proper charging, battary over charging, bike current problems, MAGINET problems etc etc,
    i have contact number of a expert Electrician sepcialy for Deluxe nd other bikes, His shop in mecload Road lahore, he installed many HID lights in deluxe nd also normal cg honda 125 nd 70 cc bikes bt no complain,
    Here is contact number: 0307 6176832, Refer to ( Asif Aslam )
    if u want to further information then text me. My email ID is ( Asifaslam_43@yahoo.com)
    Dua mai Yaad rakhiye ga... Allah Nigheban
    !!! You must continue to gain expertise, but avoid thinking like an expert !!!
  5. #24
    junaidakhtar01's Avatar
    Mar 2010
    37
    1,026
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by mqsdrana View Post
    Is That Exhaust Can Install in Deluxe
    Neon Lights For Honda 125...and modifications...? - 2008CBR1000RR Exhaust
    install to hojayega lekin phr deluxe kon dekhega ?
  6. #25
    macrocks's Avatar
    Dec 2010
    63
    projection light for bike for sale if interested pm me with 6000k hid colour temp
    Neon Lights For Honda 125and modifications? -1325706Neon Lights For Honda 125and modifications? -1325707Neon Lights For Honda 125and modifications? -1325708Neon Lights For Honda 125and modifications? -1325709Neon Lights For Honda 125and modifications? -1325710Neon Lights For Honda 125and modifications? -1325711Neon Lights For Honda 125and modifications? -1325712Neon Lights For Honda 125and modifications? -1325713
  7. #26
    mqsdrana's Avatar
    Mar 2010
    557
    118 Post(s)
    9 Thread(s)
    Quote Originally Posted by macrocks View Post
    Used or new?
    deluxe main fitting ho skti hy is ke, kisi modification ke zarurat to nye ho ge
  8. #27
    anwarriaz1's Avatar
    Dec 2010
    1,121
    20 Post(s)
    9 Thread(s)
    Yee kia bula hai
  9. #28
    Bajwa2's Avatar
    Apr 2011
    415
    i have complete hid set up for cg 125(BALASTER,BIG BATTERY HEAD LIGHT) only one week use if any one wants this plz contact me demand 2200 fnf wid complete wiring my cell no is 0308 4283076 thx
    Life is 2 short so enjoy ur life...
  10. #29
    macrocks's Avatar
    Dec 2010
    63
    new hai battery change kerne paday ge i think 12v9amp.
  11. #30
    Bajwa2's Avatar
    Apr 2011
    415
    battery change krni parti hae 7 to 9amp
  12. 07-09-2014, 10:38 PM
    Site Banned
    Reason
    spammer
  13. #31
    tahakhan125's Avatar
    May 2014
    21
    14
    8
    Guys you can buy a hid combination of yellow and blue light in just
    1500 pkr and
    1400 pkr battery other charges will be around
    1500 pkr
    total = 4300 pkr and after six months you will need to replace the battery cuz of electrolyte. I had it installed in my honda 70. from macleod road lahore
