As you guyz live in lahore i would strongly advise you NOT to install the HID Neons in Bikes because of the following reasons.
- It is banned in Lahore, and you WILL get a spicy chalaan by Traffic Wardens because of that light.
- It literally blinds the opposing person (if any traffic coming from opposite direction), which is another main reason for its BAN.
- It costs too much for just a light (Nearly 5k - for LIGHT ONLY). PLUS, you will have to change your Battery to a bigger one (Take nearly 2k into account), which also require some modification done by some expert dentor (in location where you put your battery). Also, you will have to change your Head Light completely and will have to look for OLDER MODEL head lights which have STEEL Chassis Inside (silver wali jaga) instead of current PLASTIC Silver. Why? Because the Heat Intensity of HID.
If you still want to buy one, then there are several shops in McLoad Road Lahore. You can go there to buy one.
But my advice to you would be, incase you just want to increase the Light Intensity/Strength of your Headlight, then just look for Older Model Headlights (Which still are pretty obsolete and HARD to find - and you wont find it in Brand New either), which have STEEL silver chassis inside 'em instead of Plastic, and use Stanley's Bulbs ... ask some electrician if it require an increase in the Current for Headlight (if he says its necessary, but its not actually).
P.S. I am no expert, but a while back, i was also in Same Dilemma as yours. But after a couple of bad experiences, i strongly advise people NOT to go for HID, because its really dangerous on Road, might not be for yourself, but IT IS for other people as it temporary BLINDS other people. I also oppose Neon Lights which are being used in Cars and they use it 24/7 (in nights), and sonay pay sohaga, kameenay HIGH BEAM use karte hain <_<
