Results 1 to 10 of 10
Thread: Need Honda CD100 Carburettor hose pipe
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Angry Need Honda CD100 Carburettor hose pipe
    hi
    i Need Honda CD100 Carburettor hose pipe .but cant find it anywhere in pindi islamabad searched it a lot but cant find one.. every shopekeeper says company supply nai karthi..
    the hose pipe is the rubber pipe that connects the air filter box to the carburettor. in cd 70 it is called carburetor lota as is shown in pic below
    Need Honda CD100 Carburettor hose pipe -251600
    amnd the pic of carb air intake side
    Need Honda CD100 Carburettor hose pipe -251601
    as u can see the lota pipe is small one i get biger pipe it will hold the cab ,, now the carb is holding it ,, lolz
    Need Honda CD100 Carburettor hose pipe -251604
    Need Honda CD100 Carburettor hose pipe -251605
    .. in 100 there is no lota it is pipe and box..
    my purpose is actually to install a cd 100 carb on 70 but cant supply it with air as the default 70 lota size is 28mm and the carb air filter side is 38 mm so .. any help ..also how is the cg 125 setup like ? i mean how the carb is connected to filter . some pics will be great..
    for refrence here is the pics of a hose pipe
    Carburettor Hose Sales, Buy Carburettor Hose Products from alibaba.com
    please if some one can find it in their city i will send u all the cost plze send it to me.. will be very thankful
    i m searching it for the past 2 weeks but no succeessNeed Honda CD100 Carburettor hose pipe -251593
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    bro can t u get a custom made for it?????
    rubber pipe he hta ha na wo?
    or plastic either?
    legend will revive soon
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by hidalgo View Post
    or plastic either?
    thanks for the reply .
    what do u mean custom made ?
    can u refer me to any source that makes custom.. ya its rubber .. the one that can be depressed ... it is not like plastic like pvc pipe...
    yar i cant find it in pindi islamabad..
    plze if anyone in karachi or lahore can get it for me .. i will bear all expenses.. do me a favour...
    thanks a lot
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Quote Originally Posted by asjdsm View Post
    thanks a lot
    sir why don t you attach an other rubber tube
    i mean if that lota part only ???
    cut from an other n fix with it for adjustment you can use heat to extend that???????rubber n plastic expands na??????
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    yar rubber does expands but there is a huge difference,, i,e 26mm to 38mm is a huge diff,,
    i tried but failed ,, if some one in khi/lahore can find and ship it i will b grate full,,
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    sir pm me ur numb
    will tell you
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    i m uploading the pic of 70 setup.. the filter lota highlighted is of 28mm but i need of 38-40mm to properly attach cd100 carb,, help me out,,
    Need Honda CD100 Carburettor hose pipe -255889
    followingg is the pic of the hose pipe
    Need Honda CD100 Carburettor hose pipe -255945
    and here is it installed on jialing jh70
    Need Honda CD100 Carburettor hose pipe -255958
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Need Honda CD100 Carburettor hose pipe -256020
    the circled area is air filter box
    the piece of rubber high lighted connects that air filter n carbi
    its almost 4 to 5 inches nd width is also big
    go to any shop having yamaha parts n ask for this
    use ring type clps to tighten the both ends it will do the trick for sure
    if still not happens consult fc or members from khi
    best of luck
    asjdsm's Avatar
    Apr 2009
    30
    3,478
    57 Post(s)
    3 Thread(s)
    it is way way way too much big,,
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    ouh
