Results 1 to 6 of 6
Thread: honda CD 70 dosent feel the way it used to be
    shahabkb's Avatar
    May 2009
    Peshawar
    26
    48
    Default honda CD 70 dosent feel the way it used to be
    my honda CD 70 used to be great while driving but now it feels lose, grip is gone, the pic of the bike is gone, and even the speed aint that great. i do tuening and change my oil regularly (use honda atlas engine oile) any suggestions guys
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    bro which model cd 70 you own
    check the rims and wheel bearings
    they might have got damaged
    shahabkb's Avatar
    May 2009
    Peshawar
    26
    48
    i have 2009 model
    i have straightned the rims the other day it got better but still dosent feel like it used to be.
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    kitna chala ha?
    have u tried with different companies petrol?
    also use havoline ..
    filter original lagaya karo,,
    plug kaisa ha? kis cmpany ka ha? kitna chala hay? if it has done 15000km then change it with genuine ngk c7hsa
    lube ur chain
    check air pressure in tyre,
    clean and readjust ur carb,, clean its jets with coompressed air,, jo moun sa phonk mar ka saaf kartha hain that not always works, or use really thin wires to clean the jets..
    asjdsm's Avatar
    Apr 2009
    30
    3,466
    57 Post(s)
    3 Thread(s)
    agar acha mechanic mila jis ka pas compression gauge ho jo reliable ho then u can take compression readings so agar engine ma koi masla ho tho patha chal jaya ga,,
    SDF38's Avatar
    Jan 2012
    509
    time to sell it
Tags for this Thread
