Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By talhabinomar
Thread: Honda cd 70 speed prob,, plz help
    KaaasH's Avatar
    Aug 2011
    43
    Default Honda cd 70 speed prob,, plz help
    Salam..
    My bike (Honda cd 70) iz 9 years old and is well maintained,, 1year before one of engine's main bearing was stucked and i replaced it wid new Japanese genuine bearing.. (also changed timing chain, clutch plates, piston rings, and valve wid new one)
    after that engine's pick was good and had smooth running,,,
    but problem iz that speed of my bike is little reduced after engine was opened,, I also tried 15 teeth gear on chain but all in vain..
    plz help to increase speed of bike.
    Thanks
    asjdsm's Avatar
    Apr 2009
    30
    3,482
    57 Post(s)
    3 Thread(s)
    kitni speed thi?
    ab kitni ha?
    d u think r meter is ok?
    can u trust it?
    also how much u expect?
    get genuine engine oil, properly tune ur bike and carb,,
    KaaasH's Avatar
    Aug 2011
    43
    pehly 90-95 thi
    ab 70-75 hai,,
    meter theek hai ku k ab main kisi ko b full speed main overtake nahin kr pata..
    thats mean meter theek hai spped kam hoi hai,,,
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    It could be your Pressure Plate or Clutch Plate.
    What is the condition of Engine Oil ? Bike decrease it or not ?
    KaaasH's Avatar
    Aug 2011
    43
    Quote Originally Posted by talhabinomar View Post
    oil 1mnth k baad black ho jata hai aur main change krwa deta hun,,, decrease hota hai lekin bht kam,, leakage nahin hai thori bht same aa jati ha engine ki sides per...
    pressure plates ka mjy idea nahin plz explain...
    asjdsm's Avatar
    Apr 2009
    30
    3,482
    57 Post(s)
    3 Thread(s)
    when u tune it ask ur mechanic about it,, srf hath sa chk karna k baad hi banda kch kah saktha hay,,
    it could be clutch plates ( pressure plates actually) be worn out,,
    plates cost 40-1300 rs depending on quality,,may be u got something ofbad quality last time,,
    use original engine oil better havolie from pump itself,,
    lube chain, adjust carb, tune tappats,, and check for any leaks on the place where the carburetors pipe meets the cylinder head engine)
    fhdviper's Avatar
    Dec 2015
    Default About your Honda CD 70 problem kaaash.
    Hey Bro don't worry if the bike is not speeding up,your bike is wholly OK don't damage the engine calm down or in other words ye jang nai he Bhai bike ko bike ki tarah chalao us per zulm hargiz mat dhao.
