Results 1 to 17 of 17
Like Tree5Likes
  • 2 Post By navidhashmi
  • 2 Post By Tabish1
  • 2 Post By r1
  • 2 Post By r1
Thread: 2009 Honda CG 125 Clutch and Gear
    navidhashmi's Avatar
    Apr 2011
    Multan
    213
    3 Post(s)
    Default 2009 Honda CG 125 Clutch and Gear
    Dear All,
    I just purchased 2009 model cg 125 in its genuine condition, it is 20,000 km Milage. I need few suggestions from experts
    1. Which steps i should follow for preventative maintenance of 125 Bike
    2. I am feeling while shifting gear and pressing clutch, what to do to make them just like new
    3. Which mobil oil you preffered however i have put shell yellow box 10 w 40
    4. Can i use Delux Tyres in it ?
    Appreciate your suggestions in advance
    Thanks
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    Personally I dont like delux`s tyres..
    Change clutch plate and pressure plate.. this turn make your bike just like a new..
    Pakistan <3
    Apr 2011
    Multan
    213
    3 Post(s)
    Default Thanks bro for the reply
    Quote Originally Posted by Tabish1 View Post
    Can you please tell me how much cost for clutch and pressure plate ?
    Thanks
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Quote Originally Posted by navidhashmi View Post
    Can you please tell me how much cost for clutch and pressure plate ?Thanks
    Agree with Tabish, change clutch plates genuine plates with charges would cost Rupees 900-1000. Caltex Havoline is best oil for CG. Do not use Deluxe tyre and try to get Servis tyre for bike don't go for Panther. It has no grip rubber is very soft would get puncture early.
    Dream is not that which you see while sleeping it is something that does not let you sleep.
    Apr 2011
    Multan
    213
    3 Post(s)
    Default Thanks
    Quote Originally Posted by r1 View Post
    hmmmm...... Gear shifting and play which i am feeling now in riding my cg would be clear after replacing Clutch and Pressure Plate ?
    R1 kindly please let me know what type of maintenance CG requires for smooth and long run engine ?
    Thanks you so much for your information
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    hmmmm...... Gear shifting and play which i am feeling now in riding my cg would be clear after replacing Clutch and Pressure Plate ? R1 kindly please let me know what type of maintenance CG requires for smooth and long run engine ?Thanks you so much for your information
    Yes the play will remove and it would enhance pick and acceleration but don't go to some choto or chonda mechanic. Purchase clutch plates from AHL Antenna Shop and find some good AHL mechanic who can work good. Tune up your bike and do change oil after every 800kms.
    Apr 2011
    Multan
    213
    3 Post(s)
    Default Cg125
    Thanks you so much R1, just few more questions
    1. After how many Kms we have to change Timing chain, ring piston, connecting rod etc... like things ?
    2. Would you suggest good front tyre for cg , which holds good grip and smooth ride
    3. I heard from few peoples that after overhaling cg 125 engine it wont works like before ?
    4. Do you have any idea how much CG125 model 2009 , 20,000 km milage would cost ? (in good condition)
    Thanks in advance
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    I have no idea about rings, pistons, timing chain when you have to change, but when your bike start giving smoke then it means bike needs new rings and pistons.Front tyre same Servis brand is best. 2009 CG with 22k driven would cost around 65-68k.
    Apr 2011
    Multan
    213
    3 Post(s)
    Default Cg125
    Dear R1 changing clutch and pressure plate would bring effect on resale value of motor bike ?
    Regards
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Regards
    Yes buddy it will, only if you mention that it has been replaced... By the way, what kind of problems are you facing with the current condition of clutch?
    Sent from my HTC One X using Tapatalk 2
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    I don't think so that Change of Clutch Plates creates any issue. Look the Traffic Situation in Pakistan. At every signal and every time changing of gears. The efficiency of Clutch will reduce. I have Honda cd 70 model 2010. I have replaced its clutch plates twice because of the fact i roughly use it. by the way the clutch plates works fine unless you are careful driver.
  12. #12
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Clutch plates itni asaani se nahi farigh hoti. . .
  13. #13
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Regards
    No it would not..
  14. #14
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    Quote Originally Posted by ha125 View Post
    Agree!! My CG has faced so many tough times. On and off road, water streams, extreme snow areass, high altitude areas but pick and acceleration and clutch is working still like new.
  15. #15
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    clutch plates itni jaldi kabi bhi kharab nai hothi.. agar normal tareeqa sa chalai jaya..
    settings check karoo..
  16. #16
    ha125's Avatar
    Oct 2008
    21
    3,132
    83 Post(s)
    10 Thread(s)
    Quote Originally Posted by asjdsm View Post
    Agree with asjdsm...
    You're clutch needs adjustment via cable aur nut
  17. #17
    Newbie Follow
    idj129cycle's Avatar
    Dec 2014
    Rawalpindi
    17
    Default Clutch and pressure plate honda cg 125
    What is the prize of orignal clutch and pessure plate of honda cg 125 . How to know that the clutch plate is orignal
    Thanks in advance
Tags for this Thread
