Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Like Tree15Likes
Thread: Honda CG125 Deluxe Headlight
    Mirr's Avatar
    Dec 2010
    215
    Default Honda CG125 Deluxe Headlight
    I wanted to ask you all a question about the headlight on my CG125 Deluxe;
    I have a Honda 2012 CG125 Deluxe, and the wiring for the head light is wired in such a way that when you rev up the engine, the light gets brighter, and when you let the RPMs drop and let the engine idle, the light dims to the point it is non-existent.
    Can the wiring be corrected, or changed, so that the headlight is directly connected to the battery, and thus is not dependent on the engine?
    Can I also get the bulb replaced with something better and stronger? Like those HID lights perhaps? Will they work with the housing? Or be too hot and cause the housing and fitting to melt/etc?
  2. #21
    naseer_jaan's Avatar
    Sep 2012
    Gujrat
    34
    797
    12 Post(s)
    Quote Originally Posted by djasif43 View Post
    Salam,
    HID light is best source for more brightness nd visibilty nd make your Vehicle sexy, bt its costly if u bear all chargis then u must install in your bike,
    HID light ( High-intensity discharge lamp ) consume 35 watt same like as Orignal deluxe bulb also consume power 12 volt 35 watt. But orignal light runing through MAGINET. thats y it will b not effect to battry. HID runing through Battry, This tube is filled with Neon gas and metal salts need hight voltage to arc nd heat the gas, and Orignal bike battray not enough for HID . Because this battry only 12volt and 2.5A
    Hid light need high voltage using Blaster. i also installed Hid in my Honda Deluxe 125. And its work perfectly and work up to 2 hours and more then.
    installation parts for HID..
    (1)
    buy ( 8000K H4 Temperature HID light+blaster) . its cost about 2k with 6 month warranty,
    ( This is a pair of 2 lights) 1 HID or 2nd is incandescent flament tube ) Incandescent Tube same like as Default honda bulb yellow light, it will work on low beam through MAGINET current. and HID work on high beam button through Battry currnet. when u use high beam Incandescent Tube automaticaly will b off nd HID will b work,
    This pair will b adjust in place of Orignal bulb holder in 30 sec. Deluxe light body is very biger like car light body, it bear the HID Heat easily no modification needed.
    (2)
    Install 12 volt 9Ah National battray, its easily available in market with 3 monts warranty cost about 1.5k. its adjust very easily because deluxe has biger space in battry panel, no need to modification.
    Use china Road prince Rectifier. its provide auto current Ah 2.5 Ah to 7Ah step by step when battary needed,
    (NOTE)
    (1)
    Always use ( 8000K H4 ) temperature HID light. This colour temprature is white+blue. This temp never too much blind to other Drivers. Dont use HID Dipper (flash) on single road but trafic runing on both sides' it will be blind to other nd dangarious like a road accident, but if you use HID continusely without dipper then no problem. better option is Try to use only one way Roads.
    Use HID Only when bike engine in start position, it will b battray backup increase,
    (2)
    Installation HID to only expert electrician. because this is very inteligent work. Many Relays, junctions cut out and reactifier put in this circuit, every electrician not knowledge about how HID perfect work in bikes, dts y result will b shown also in bad experience like hid burn,blaster burn,battray not proper charging, battary over charging, bike current problems, MAGINET problems etc etc,
    i have contact number of a expert Electrician sepcialy for Deluxe nd other bikes, His shop in mecload Road lahore, he installed many HID lights in deluxe nd also normal cg honda 125 nd 70 cc bikes bt no complain,
    Here is contact number: 0307 6176832, Refer to ( Asif Aslam )
    if u want to further information then text me. My email ID is ( Asifaslam_43@yahoo.com)
    Dua mai Yaad rakhiye ga... Allah Nigheban
    realy very very thanks brother,,,, main ne isi Electrician se apni pridor main hid install karwai hai, mind blowing karigar hai,main specialy gujrat se lahore gaya tha is kaam k leay , pehly main ne gujrat markeet main cheak kiya to mujhe koi khas karigar nazar nhi aya, phir main ne lahore macklord road per ja ker in se contect kiya , phir in se mill ker sari detail main baat ki, bohat achi turah se inhon ne mujhe guide kiya aur finaly main ne inhi se apni pridor main hid install karwa li, bohat awasom karigar hai, jisturah se kaam kar raha tha main ne pehly kisi Electrician ko itna acha kaam karty nhi dekha, main itni jaldi kisi kaam per mutmain nhi hota lakin jisturah se is Electrician ne hid install kar k di hai main 100% mutmain ho gaya hon
    GO__ HONDA __ GO
  3. #22
    djasif43's Avatar
    May 2013
    8
    Welcome my dear...!
    Hope you enjoy with HiD :-)
    Sent from my iPhone using PW Forums mobile app
    !!! You must continue to gain expertise, but avoid thinking like an expert !!!
  4. #23
    imranafzal4's Avatar
    Sep 2011
    336
    33 Post(s)
    Salam, <br>
    HID light is best source for more brightness nd visibilty nd make your Vehicle sexy, bt its costly if u bear all chargis then u must install in your bike,<br>
    HID light ( High-intensity discharge lamp ) consume 35 watt same like as Orignal deluxe bulb also consume power 12 volt 35 watt. But orignal light runing through MAGINET. thats y it will b not effect to battry. HID runing through Battry, This tube is filled with Neon gas and metal salts need hight voltage to arc nd heat the gas, and Orignal bike battray not enough for HID . Because this battry only 12volt and 2.5A<br>
    Hid light need high voltage using Blaster. i also installed Hid in my Honda Deluxe 125. And its work perfectly and work up to 2 hours and more then.<br>
    installation parts for HID..<br>
    (1)<br>
    buy ( 8000K H4 Temperature HID light+blaster) . its cost about 2k with 6 month warranty,<br>
    ( This is a pair of 2 lights) 1 HID or 2nd is incandescent flament tube ) Incandescent Tube same like as Default honda bulb yellow light, it will work on low beam through MAGINET current. and HID work on high beam button through Battry currnet. when u use high beam Incandescent Tube automaticaly will b off nd HID will b work,<br>
    This pair will b adjust in place of Orignal bulb holder in 30 sec. Deluxe light body is very biger like car light body, it bear the HID Heat easily no modification needed.<br>
    (2) <br>
    Install 12 volt 9Ah National battray, its easily available in market with 3 monts warranty cost about 1.5k. its adjust very easily because deluxe has biger space in battry panel, no need to modification.<br>
    Use china Road prince Rectifier. its provide auto current Ah 2.5 Ah to 7Ah step by step when battary needed,<br>
    (NOTE) <br>
    (1)<br>
    Always use ( 8000K H4 ) temperature HID light. This colour temprature is white+blue. This temp never too much blind to other Drivers. Dont use HID Dipper (flash) on single road but trafic runing on both sides' it will be blind to other nd dangarious like a road accident, but if you use HID continusely without dipper then no problem. better option is Try to use only one way Roads.<br>
    Use HID Only when bike engine in start position, it will b battray backup increase,<br>
    (2)<br>
    Installation HID to only expert electrician. because this is very inteligent work. Many Relays, junctions cut out and reactifier put in this circuit, every electrician not knowledge about how HID perfect work in bikes, dts y result will b shown also in bad experience like hid burn,blaster burn,battray not proper charging, battary over charging, bike current problems, MAGINET problems etc etc,<br>
    i have contact number of a expert Electrician sepcialy for Deluxe nd other bikes, His shop in mecload Road lahore, he installed many HID lights in deluxe nd also normal cg honda 125 nd 70 cc bikes bt no complain,<br>
    Here is contact number: 0307 6176832, Refer to ( Asif Aslam )<br>
    if u want to further information then text me. My email ID is ( <a href="mailto:Asifaslam_43@yahoo.com">Asifaslam_43@ yahoo.com</a>)<br>
    <br>
    <br>
    Quote Originally Posted by hs9syed View Post
    <strong><u>Honda Deluxe Headlight Problem</u></strong> <br>
    i have same problem with my Deluxe. HID light is not solution because its high point function only for a limited time such as 7 to 10 minutes and after this light dead.<br>
    Deluxe headLight is not compatible with its speed.<br>
    There is no verity of bulb/tube present in market for deluxe.
    <br>
    <br>
    <br>
    <br>
    Quote Originally Posted by makniazi View Post
    will post the pictures and vid of light working on battery
    <br>
    <br>
    <strong><a href="https://www.pakwheels.com/forums/user/getscorpion" target="_blank">getscorpion</a></strong> lol yes it is a 5 min job <img src="https://www.pakwheels.com/forums/images/smilies/smiley-wink.gif" border="0" alt="" title="Wink" smilieid="27" class="inlineimg"> did this in my 70
    <br>
    <br>
    Quote Originally Posted by getscorpion View Post
    its better be as easy as it sounds ..<img src="https://www.pakwheels.com/forums/images/smilies/smiley-tongue-out.gif" border="0" alt="" title="Tongue Out" smilieid="26" class="inlineimg"> i will try it on sunday ..<br>
    <br>
    Sent from my HTC One X using Tapatalk 2
    <br>
    <br>
    Quote Originally Posted by racer7 View Post
    Wow thats so simple but remember before doing this, your battery should have proper inspection after every 15 days to avoid any unavodable circumstances in future. <br>
    Piaggio storm 125 people are facing such problems and they have to look after more their battery for smooth operations.
    <br>
    <br>
    a bit late but want to share this with you people open the headlight in wiring you will find a yellow wire that is the head light power disconnect the yellow wire and connect it to black wire from switch now your head light is on battery <img src="https://www.pakwheels.com/forums/images/smilies/smiley-smile.gif" border="0" alt="" title="Smile" smilieid="24" class="inlineimg">
    <br>
    <br>
    Quote Originally Posted by Juste View Post
    @mirr and kashif<br>
    <br>
    Yes it is possible just discuss this thing with any good electrician. He will change ur headlight wiring or all lights of ur bike direct to battery. I was asking same question to some of my friends they also said it is possible and meanwhile I saw a pizza delivery guy on his cd70, his lights work working via battery not engine. <br>
    <br>
    But you have to maintain and take cakre of battery more like checking battery water, health e.g. because battery will be use more with lights.<br>
    <br>
    You can also use bigger batteries or maintaince free batteries like DRY CELL batteries.
    <br>
    <br>
    Quote Originally Posted by farisriaz View Post
    Here <a href="http://www.khyberkidunya.com/bike/honda-cg-125-new-model-price-in-pakistan-2013-171.html#.UFL9yI0gejk" target="_blank">Honda CG125</a> is Pic<img src="https://www.pakwheels.com/forums/attachment.php?attachmentid=1&amp;stc=1" attachmentid="1" alt="" id="vbattach_1" class="previewthumb">
    <br>
    <br>
    Quote Originally Posted by mqsdrana View Post
    I am also have honda 125 deluxe (2010), 7.2amp dry battery, HID installed yesterday, result was awesome, <br>
    <br>
    u can set your bike light on battery, when u switch off engine your light on, until u switch off the ignation or light, its better use dry battery for that purpose.<br>
    <br>
    i'll upload my pic soon.<br>
    Thanks
    <br>
    <br>
    Quote Originally Posted by mehmood115 View Post
    Default housing of CG 125 Deluxe can bear the HID heat no need to change it.
    <br>
    <br>
    Quote Originally Posted by Mirr View Post
    <font color="#555555">I wanted to ask you all a question about the headlight on my CG125 Deluxe;</font><br>
    <br>
    <font color="#555555">I have a Honda 2012 CG125 Deluxe, and the wiring for the head light is wired in such a way that when you rev up the engine, the light gets brighter, and when you let the RPMs drop and let the engine idle, the light dims to the point it is non-existent.</font><br>
    <br>
    <font color="#555555">Can the wiring be corrected, or changed, so that the headlight is directly connected to the battery, and thus is not dependent on the engine?<br>
    <br>
    Can I also get the bulb replaced with something better and stronger? Like those HID lights perhaps? Will they work with the housing? Or be too hot and cause the housing and fitting to melt/etc?</font>
    <br>
    <br>
    welcome @<a href="https://www.pakwheels.com/forums/member.php?u=16278" target="_blank">baby</a>_Xaarak, i collect these all info after waisted to much time nd money.<br>
    want to help those brothers who realy love HID nd also want to real visibility on the road while driving, bt they have no proper guidness. seen many threads in this fourm many brothers miss guiding to HID lovers ,i dont know Reason why ppl spread false information, i think they have lakie info nd no experience about HID :/
    <br><br>I think I just waste my 2000 Rupees after installation a 6000K HID on my Honda Pridor..<br>Electrician said it will work with stock battery but Light immediate off after some minutes..<br>Now He said change the Battery and recommend &nbsp;7 AH Dry cell (I don't know how its Fits in Pridor Because of large size)<br>I paid 1550 for HID (Including Labour)<br>300 for extra Charger (For charge quickly)<br><br>Now After reading thread people said HID will only work Continuously 10-15 minutes&nbsp;<br>Why its not working continuously 1 hour At least ?<br><br>Whats the ultimate solution for bad light of Pridor? I am agree to pay 1500 2000 for Dry battery but not sure after spending 4000 of light assembly I will got my desire result?<br><br>Please Help me in this regard (ASAP_<br>Waiting for answers<br><br><br>
    <br>
  5. #24
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Go for led plug & play bulb not for HID. led will work very well on stock battery
  6. #25
    mum65's Avatar
    Oct 2004
    Al-Ain/multan/bwp
    34
    1,591
    2 Post(s)
    Quote Originally Posted by imranafzal4 View Post
    <br>
    <br>
    Dear bro imranafzal4, Hid can work in pridor. u have to install dry battery costing approx 1500 and for installing that u will have to take it to some good electrician who can work on it and can install the battery with expertise. i am using Hid in my 125 for last 5 years. and i just change battery rest Hid is still the same working fine. all u have to do is install battery first then the rectifier to charge battery sufficiently and then u will have to install hid and run it through battery. and yes use Hid while driving as it uses battery alot. and like hamikhan said nowadays there r LED lights also available which can work on stock battery. so any further help u need feel free to ask. thanks.
    psychohate@hotmail.com
    Life Goes ON........
  7. #26
    Sep 2011
    336
    33 Post(s)
    Quote Originally Posted by mum65 View Post
    Brother Yesterday I visit most of the batteries shop, they only had 7 Ah Chinese brand and used one...
    I found a thread about a good brand battery which is bought by some member, I search that brand and got good info
    Kung Long Batteries Industrial Co., Ltd ,
    BUT The question is that after installation this branded 5AH battery what is the timing of HID for continuous ON?
  8. #27
    Sep 2011
    336
    33 Post(s)
    1 Electronics shop had this brand but only 4AH battery and the price was 1350 Full and final and the batteries dimentions are similar to stock battery which means that battery with fit perfect in existing space but I didn't consider because of 4AH, I and searching 5 AH battery,
    7 AH batteries lengh Is 6" so difficult to accommodate in existing space and I avoid the YOUGUARD
  9. #28
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Plug & play Led runs on from 5 Volts to 12V
    Honda CG125 Deluxe Headlight -1625008
  10. #29
    mum65's Avatar
    Oct 2004
    Al-Ain/multan/bwp
    34
    1,591
    2 Post(s)
    Dear yes i installed same brand in 9 or 7ah. And believe me its been 1.5 years and still battery is working fine. And i almost run the hid for 30 mins or so. And there is no issue. It works fine. And with 5 ah i think so that it will easily work for and hour or so. If the battery is charging good then might be more.
  11. #30
    Sep 2011
    336
    33 Post(s)
    Can you please guide me where to buy this Battery because I checked 2 markets but not available...
  12. #31
    mum65's Avatar
    Oct 2004
    Al-Ain/multan/bwp
    34
    1,591
    2 Post(s)
    Dear the i bought the battery in Multan. Now i dont know where u live. Let me know if u dont find it. Try electronics market in ur area. Where do u live??
  13. #32
    Sep 2011
    336
    33 Post(s)
    Lahore, I'll Visit Hall Road ASAP
  14. #33
    adeeljatoi's Avatar
    Jan 2015
    Multan
    23
    18
    can you please tell me where did you buy that battery? and led or hid? market name and place?
  15. #34
    mum65's Avatar
    Oct 2004
    Al-Ain/multan/bwp
    34
    1,591
    2 Post(s)
    Dear i bought the battery from multan. Now i dont remember the shop name. But i just told him dry battery and 7 or 9amp battery and he gave me one. And for Hid u can get any good car Hid. I live in bahawalpur now if u were living there i would have surely helped u out. Where do u live??
