Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 42
Like Tree15Likes
Thread: Confused what to do with my Honda 70
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Question Confused what to do with my Honda 70
    i have a honda 70 1999 engine never overhauled till date its mileage is 1 lakh 14 thousand the problem i am getting since few days is that high fuel consumption black smoke occasionally and plug get black very quickly the other thing is that it does missing on high speed did tuning oil change plug changed etc showed it to few mechanics some one is saying head problem other saying nothing wrong it normal i need help on what to should i go for opening the head or not ?
    Regards
    Abbas Khan
    All you need in this life is ignorance and confidence, and then success is sure.
  2. #21
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    got timing chain replace around 10k km ago never adjusted the timing again had replaced it from some other mechanic but now when my mechanic open it he said it needs replacing waiting for it to be back on road
  3. #22
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    @aximaxim yes i think engine was running rough because bike had a lot of vibration hope it will be fine now
  4. #23
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Confused what to do with my Honda 70 -1132234Confused what to do with my Honda 70 -1132235Confused what to do with my Honda 70 -1132236Confused what to do with my Honda 70 -1132237Confused what to do with my Honda 70 -1132238
  5. #24
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Quote Originally Posted by makniazi View Post
    Head is in very bad shape.. a lot of carbon deposit in it... the head is totally black! valves are bad too....
    After cleaning the head and fitting new valves.. u will see a shiney clean engine!
  6. #25
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    Bike is running fine now and is back on road this is how it looks nowConfused what to do with my Honda 70 -1132442Confused what to do with my Honda 70 -1132443Confused what to do with my Honda 70 -1132444Confused what to do with my Honda 70 -1132445Confused what to do with my Honda 70 -1132446Confused what to do with my Honda 70 -1132447Confused what to do with my Honda 70 -1132449Confused what to do with my Honda 70 -1132453Confused what to do with my Honda 70 -1132454Confused what to do with my Honda 70 -1132455
  7. #26
    waseem88's Avatar
    Nov 2009
    Faisalabad
    28
    1,172
    18 Post(s)
    today got time and went to mechanic as bike had also started a little bit of white smoke so he opened the engine starting form head we found that valves had been worn out and engine had alot of work apart from head the things needed to change were
    1. valve =Rs 450
    2. valve seal =RS 180
    3. timing chain sprockets =Rs 180
    4. timing chain =Rs 220
    5. oil pump sprocket =Rs 250
    6. piston ring (Atlas Honda)=Rs 400
    7. kick lever=Rs 150
    8. oil seals=Rs 200
    9. gas kits=Rs 150
    10. Timing Chain spring=Rs 50
    total= Rs 2230
    + did tuning oil change and kairad work on head with labor and every thing it costed 3300
    will get the bike tomorrow as it was too late to assemble it so the mechanic said that will continue tomorrow will update the result of spending 3300
    mein ny apko phly hi clear bata dia tha....but shaid apki samj mein late aeyi..any how keep enjoying
    Intelligence without ambition is a bird without wings.....!!!
  8. #27
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by waseem88 View Post
    kya baat hai sir aap ki
    Bikes don't leak oil, they mark their territory.
  9. #28
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    Quote Originally Posted by devilskreed View Post
    Now you need to complete the break in period cautiously..No hard accelerations and speed above 35km/he atleast for some 700 Kms
    cmon man 35kmph ? seriously
    legend will revive soon
  10. #29
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by hidalgo View Post
    Sir gee all for the sake of better sealing of pistons in the combustion chamber..When they have sealed in then he cna do whatever he like
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  11. #30
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    he can strech it upto 45 plus kmph if he give rest it after intervals on 10 to 15kmph . chaskay laga laga k running kre agar
  12. #31
    talhabinomar's Avatar
    May 2011
    26
    2,469
    38 Post(s)
    In the running process the speed can be reach till 50 km/h but you have to use all four gears
  13. #32
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    rest after 10-15 km hmm that's nice cuz its almost 14 km to uni from home means 14 in the morning and then 3-7hrs rest and again 14 km back home matlab i can go upto 45-50
  14. #33
    May 2011
    26
    2,469
    38 Post(s)
    yes but you have to use all four gears.
  15. #34
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    plz keep thiking , do google n utube , wait for an appropriate derision to come in ur mind make a budget. engrave ur statistics . than perhaps wait at least a year . then do what u want to do with ur honda 70cc uncle.
    regards
  16. #35
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    AOA all posting here after completing the running period and bike is running fine actually more than 1000 km done i guess around 2k bike is running awesome pick and power is good touches 100 gps speed not the speed on meter tuning done recently now the problem is that when the bike's engine is hot bike does not idle yesterday i opened the plug to check if its rich or lean but the plug was brown means it is running fine giving and average of 45 km/lt at an average speed of 75 to 80 i was thinking that is there something wrong with the carb ? if yes should i go for a new one or get it repaired
  17. #36
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    I guessing while you were breaking-in your newly built engine, the metal shavings from the engine could have clogged up the idle jet in your carb. I think a blast of compressed air will suffice. No need to change the carb.
  18. #37
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    aximaxim cleaned the jets yesterday one thing i forgot to mention is that crab needle was no straight the guy did some hammering to straighten it and then smoothed it with sandpaper could it be the problem or electrical problem ?
  19. #38
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    anyone ??
  20. #39
    hidalgo's Avatar
    Mar 2011
    Rawalpindi
    26
    6,627
    148 Post(s)
    16 Thread(s)
    anyone ??
    its not v costly item replace it , better milage is what you will get.
  21. #40
    makniazi's Avatar
    Oct 2010
    Peshawar
    428
    26 Post(s)
    @hidalgo talking about the carb ? if yes how much does it cost
