Results 1 to 8 of 8
Like Tree6Likes
  • 1 Post By Silver_Knife
  • 4 Post By omer85
  • 1 Post By omer85
Thread: Need Tubeless tyre and rims for Honda cg 125 Deluxe
    faisal_giali's Avatar
    Jul 2006
    29
    83
    Default Need Tubeless tyre and rims for Honda cg 125 Deluxe
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    You have to visit Lahore to get rims and tyres in good rates..But keep in mind they will reduce Acceleration and Topspeed
    omer85's Avatar
    Nov 2012
    31
    616
    65 Post(s)
    6 Thread(s)
    Yes its definitely possible, but requires a lot of mods and depends on what types of rims and tires you want to go for, here's a short list
    there are chinese rims available in 18 inch with rear drum and front disk brake (not very expensive) same original tires currently installed on deluxe can be used with these rims,
    and then if you go for some heavy bike rims and tires these would be in 17 inch both front and rear (Ziyada kharcha), both rims and tires will be used not new
    then bushes and bearings and spacers would be changed (for both 17 and 18 inch rims)
    rear brake setup would also be changed to disk and if you are lucky maybe you may get a hold of a rim with rear drum brake,
    If switching to rear disk whole disk setup which includes the caliper, tawa, oil bottle, pipe, cylinder etc would be required most preferably of nissin from some heavy bike
    Then proper fitting of the brake cylinder will have to be made (for rear disk only)
    changes in rear brake hub and sprocket,
    remove chain cover,
    for a better look will have to raise the bike from behind
    will have to check the speedometer gharari for the particular rim installed and speedometer cable availability for that gharari for proper working of speedometer
    and rear brake pedal setting
    and alingment, balancing and positioning of the rear tire and front tire for smooth running
    and proper positioning of both front and rear brake calipers for noise free braking with an excellent response (sometimes difficult to achieve specially for front disk brake needs an expert mechanic other wide it will make noise)
    and yes the front mudguard will also have to be changed with a custom made bracket for fitting
    front and rear rims will have to be repainted as the old ones are not in good paint mostly
    Here is link to the chinese 18 inch rims in deluxe (Click)
    & here is the link to the original heavy bike 17 inch rims in deluxe (click)
    Hope this helps
    The cost of chinese rims with tires would be from 10K to 15K.
    Cost of original heavy bike rims with tires would be around 25K to 30K.
    omer85's Avatar
    Nov 2012
    31
    616
    65 Post(s)
    6 Thread(s)
    Quote Originally Posted by Silver_Knife View Post
    wont have any effect on acceleration if you move to 17 inch will not reduce acceleration, top speed will decrease and fuel consumption will increase.
    Newbie Follow
    asad.malik.79677's Avatar
    Feb 2014
    23
    sallam
    Bhai koi bta sakta hai k Chinna k rims*17inch aur Tyre lahore main kon c shop say milain gey ???
    Jul 2006
    29
    83
    mcleod road is best option
    javed_0007's Avatar
    Oct 2014
    30
    14
    Bilal Gang
    faisalwho's Avatar
    Nov 2016
    6
    Can i use 110/90- in deluxe 125 without changing the original rims
