Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By talhaahmed921
Thread: [HELP] Honda 125
    coolmisa's Avatar
    Jan 2013
    27
    27
    Talking [HELP] Honda 125
    Now, after bored from Unique UD-70, i m planning to buy USED HONDA 125. but i want ur precious advice. if i buy other than Karachi registration no bike ( i m from karachi ) what will be advantage or disadvantage? plz share ur expertise.
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Khi reg bike has a better resale. Traffic police will try to harrass you a bit if you own a out of city bike. Wesay itna koi khaas masla nahi hota. A punjab reg bike will cost to less to buy. If i were you.......i would prefer a punjab reg bike as its better bang for your bucks.
    Bikes don't leak oil, they mark their territory.
    coolmisa's Avatar
    Jan 2013
    27
    27
    Thanks for ur reply..
    talhaahmed921's Avatar
    Nov 2012
    14
    CHASSIS,CHAMBER SEALED ENGINE (PREFERRED),TRANSMISSION are the first priority...Personally I would suggest you to go for a brand new 125 ...somfor checking the engine go with a trusted mechanic,listen to the engine's sound carefully rev it up a little ignore the if the noise is of tappet and spark plug its ok.Go and test the bike slowly in a silent street so that you can check all the noises.check the gear if they are making noise or slipping,in short transmission should be perfect.Check the chassis thoroughly and also check for accidents welding.DO NOT GO FOR GOOD LOOKS for eg.chrome,fuel tanks and things like that.TO CHECK THE CPLC GO TO THE NEAREST POLICE STATION OR ONLINE VEHICLE VARIFICATION WEBSITE.
