Results 1 to 8 of 8
Thread: Honda CG125 Classic Rear Wheel problem
    raxaengineer's Avatar
    Jan 2012
    Okara
    197
    2 Post(s)
    Default Honda CG125 Classic Rear Wheel problem
    Dear All,
    I hve installed 18" rear rim in my honda cg125 classic bike with 90/90 18" tyre but problem is this the chain tightening very big issue. there is lot of setting required for it. for example kbi to wheel fron sy lagna shuru ho jata hy or kbi side sy even mein ny double stand b grind krwaya hy wo b sath lgta tha wheel k plz plz plz let me guide for this solution plz.
    Ali Raza ShahidHONDA CG125 CLASSIC Rear Wheel problem -1227597HONDA CG125 CLASSIC Rear Wheel problem -1227598HONDA CG125 CLASSIC Rear Wheel problem -1227599HONDA CG125 CLASSIC Rear Wheel problem -1227600HONDA CG125 CLASSIC Rear Wheel problem -1227601
    Jan 2012
    Okara
    197
    2 Post(s)
    koi expert aadvice ni hy?
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,303
    49 Post(s)
    reduce the tire size to original spec???
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    90/90 R18 can be installed on CG:
    90/90 R18 can be installed on the CG125 without any alteration. Its the same rear wheel size as the Deluxe has.
    Check your chain and sprocket:
    What usually happens when you install bigger rear wheel is the it puts pressure on sprocket and chain of the bike and if they were already weak they give up easy. Do get you sprocket and chain set checked. Im sure chain has worn off.
    How to Check Chain and Sprocket
    You can check the chain yourself. Put the bike on double stand and put it in neutral, and rotate the rear wheel slowly. Keep a close eye on the wheel......see if its rotates smoothly or stop or slows down abruptly. If you see any abrupt stoppage or slowing down it means sprocket and chain needs to be replaced.
    Bikes don't leak oil, they mark their territory.
    Jan 2012
    Okara
    197
    2 Post(s)
    Quote Originally Posted by aximaxim View Post
    First of all i want to clarify that HONDA CG125 Rear wheel is 3.00 17
    on the other hand 125 DELUXE rear wheel is 90/90 18
    so there is 1 inch difference of rim size.
    2ndly i already installed new chain & sprocket set.
    if i tightented full chain the tyre touches with chimta at front side.
    so i need to increase the length of chain & then tighten it so its able to drive.
    i want to confirm that is there any chance to change rear chimta of bike with any other bike like kawasaki or 125 deluxe?
    aximaxim's Avatar
    Dec 2012
    1,086
    74 Post(s)
    3 Thread(s)
    Quote Originally Posted by raxaengineer View Post
    As I said earlier 90/90 R18 is what comes in deluxe so I knew what i was talkin abt.
    If you cant adjust the chain properly then its better to increase a link in the chain. Thats the more sensible approach to attend the problem rather than replace the swing arm or chimta
    Jan 2012
    Okara
    197
    2 Post(s)
    Which Swingarm or chimta fitted on cg125?
    faizan_jani's Avatar
    Feb 2016
    111
    2 Post(s)
    i have cg 125 clasic which tyre is best for me ,is delux tyre fit on clasic
