MashAllah no doubt pridor is very good bike and excellent photos by you
you seem pro photographer kindly share more pics with complete bike
visible from front side both right & left and also from rear too
- Replaced oil on 100 km - very important
now change another after 300km or 400km than on 1000km
- replaced tyre 90 90 18 Service (far better than stock tyre)
90/90 is huge tyre you should have stick with stock it work fine
if you were to change tyre than you should have upgraded to 3.00
big tyre would stress on engine and specially in running period atleast
you should have stick with stock personally i would not recommend even
after running period
- Installed LED light (stock bulb was useless) - dont install on battery it will drain battery
that is excellent modification yeah stock bulb is low in light
- Overall very good bike (only compalint of gearbox noise if reducing speed in 2nd or 3rd gear while clutch is pressed)
This is strange issue there is complain of higher khattak sound when shifting to 2nd gear
what kinda noise do you listen
